 Post subject: ST9500424AS - LED:00000067 FAddr:00380338 = BAD ROM?
PostPosted: January 11th, 2022, 12:33
Hey guys,
I've came across a ST9500424AS that when connected to terminal displays LED:00000067 FAddr:00380338.
Spin up is normal, no strange noises. I've managed to find a donor and patient heads read well on donor platters. Donor heads produce the same LED:00000067 FAddr:00380338 issue.
Can the ROM be damaged?
If so, can someone point me to a possible work around?
I'll attach a copy of the rom if someone want's to take a look.
P.S: On F3 Explorer i get a CRC error on IAP but fzbakar told me it's normal.
All ideas are welcome.
ROM6WS.txt [512 KiB]
Downloaded 310 times
 Post subject: Re: ST9500424AS - LED:00000067 FAddr:00380338 = BAD ROM?
PostPosted: January 11th, 2022, 13:35
Same error with the pcb disconnected?
PostPosted: January 11th, 2022, 16:36
Yes, I've swapwed PCB + ROM IC and same result...
PostPosted: January 12th, 2022, 10:03
Does it stay spinning or spin down, any clue from the registers. I'd be thinking heads still.
PostPosted: January 12th, 2022, 10:15
it cannot load ovl, that's why it fails with LED:00000067...
PostPosted: January 12th, 2022, 16:53
Is it time to try a loader?
PostPosted: January 12th, 2022, 18:26
not sure it is the perfect idea. It might not be the OVL that is bad, more probably something else is causing the fw to call something in the ovl before it is loaded. I have cure for such thing...
PostPosted: February 15th, 2022, 9:11
Could you inform the patient and donor PCB number
Compatible PCBs for this model are 100620560 REV.A 100619769 100610953
if you have these PCBs in good condition in your labs, you could see which terminal output to the PCB connecting the HDD and separate from the HDD if F3 T> stable without restarting and crashing
or
EarlySpinup Enabled
Rst 0x10M
ExecuteSpinRequest
LED:00000067
Users browsing this forum: No registered users and 285 guests
