 Post subject: Removal of Head
PostPosted: January 17th, 2022, 10:28
Hi Guys,
I have started learning about Data Recovery and practicing opening Hard drives.
Currently, I am struggling to remove the Head. I need to know what tool do i need to use to remove the Head?
Please see attached picture ending with WA0006
Also, please can someone tell me where the ROM is located on this PCB
Please see attached picture ending with WA0003.
Thank you for the support.
File comment: Please someone tell me where the ROM is located on this PCB
File comment: Currently, I am struggling to remove the Head. I need to know what tool do i need to remove the Head.
 Post subject: Re: Removal of Head
PostPosted: January 18th, 2022, 4:22
The "ROM" is in the big Marvel CHIP.
There must be a screw under the head assembly.
PS: you must first remove the head-ramp and use some jig (bought ar DIY) to prevent damage to heads.
PostPosted: January 18th, 2022, 4:32
This looks like an old Tornado drive.
They don't have screw underneath, you just need to lift the heads.
PostPosted: January 19th, 2022, 7:33
Just remember - not to try to boot the drive as is (with the cover off).
In such a disc, the cover - at this model - stabilizes the positioner and the heads (together with the head mounting screw).
Without this stabilization, the heads will scratch the ferromagnetic surface.
Users browsing this forum: No registered users and 50 guests
