 Post subject: External hard disk showing unallocated after plugging to Win
PostPosted: February 9th, 2022, 1:06
I have a 1TB Buffalo HD-PCU2 hard disk which was working perfectly.
Today for the first time I inserted it into a windows 11 system. It showed the new drive in the file explorer for a few minutes (though not accessible). After that I could not see the drive.
After that checking from the disk management, it is showing uninitiated & unallocated. Also the 1TB drive is showing up as a 2TB drive.
I tried with other machines having windows 10. But it is not working.
Can anybody help me find how I can recover the data from the drive.
The driver events are given below
Device USBSTOR\Disk&Ven_BUFFALO&Prod_HD-PCU2&Rev_0108\303030514234443137303734&0 was configured.
Driver Name: disk.inf
Class Guid: {4d36e967-e325-11ce-bfc1-08002be10318}
Driver Date: 06/21/2006
Driver Version: 10.0.22000.1
Driver Provider: Microsoft
Driver Section: disk_install.NT
Driver Rank: 0xFF0006
Matching Device Id: GenDisk
Outranked Drivers: disk.inf:GenDisk:00FF2002
Device Updated: false
Parent Device: USB\VID_0411&PID_01D9\303030514234443137303734
-0
Device USBSTOR\Disk&Ven_BUFFALO&Prod_HD-PCU2&Rev_0108\303030514234443137303734&0 was started.
Service: disk
Lower Filters:
Upper Filters:
-0
Device USBSTOR\DISK&VEN_BUFFALO&PROD_HD-PCU2&REV_0108\303030514234443137303734&0 was deleted.
-0
Device settings for USBSTOR\Disk&Ven_BUFFALO&Prod_HD-PCU2&Rev_0108\303030514234443137303734&0 were not migrated from previous OS installation due to partial or ambiguous device match.
Last Device Instance Id: USBSTOR\Disk&Ven_SanDisk&Prod_Extreme&Rev_0001\AA010116131122394547&0
Location Path:
Migration Rank: 0xF000FC000000F120
Present: false
Status: 0xC0000719
 Post subject: Re: External hard disk showing unallocated after plugging to
PostPosted: February 9th, 2022, 6:29
Buffalo HD-PCU2 is just the enclosure. Open it up, connect the drive direct to the PC to check if you have an enclosure or drive problem.
PostPosted: February 9th, 2022, 6:38
I tried that. But then it will be showing as unknown device in the device manager.
PostPosted: February 10th, 2022, 4:17
Any odd noise from the drive, is it spinning does it spin down after a while? Make and model of the drive rather than the enclosure?
If the drive is spinning and is not shown in the bios, (don't bother with windows device manager) with the correct capacity when directly connected there is very little you can do without professional tools. If the data is important find a local DR pro.
Users browsing this forum: Google [Bot] and 242 guests
