 Post subject: sata convert pcb usb wd 2060800040-003
PostPosted: February 16th, 2022, 15:20
Hi guys do you have scheme to convert usb pcb in sata ? TKS
 Post subject: Re: sata convert pcb usb wd 2060800040-003
PostPosted: February 16th, 2022, 15:29
40 or 41?
https://www.dolphindatalab.com/how-to-convert-wd-usb-pcb-2060-800041-to-sata-interface/
PostPosted: February 17th, 2022, 4:31
sorry 41, but i have follow this guide first but led on mrt for sata don't powero on.
Have suggestion ?
PostPosted: February 17th, 2022, 5:02
I know it's been a few years - perhaps you have forgotten?
https://forum.hddguru.com/viewtopic.php?f=1&t=37929
PostPosted: February 17th, 2022, 5:55
no I did not forget, in this case the hdd is encrypted with an encryption that mrt is not able to remove. I therefore need to use the original converted usb pcb to create a map of the heads and read only what I can.
PostPosted: February 17th, 2022, 6:06
Have you removed the caps?
PostPosted: February 17th, 2022, 6:41
in the guide only remove component near usb power. But don.t see any activity on sata port
PostPosted: February 17th, 2022, 6:49
Are you getting power?
I don't have that PCB at the moment to test for you but check you're getting power to the board by connecting up the USB for power rather than the sata power, check the 0 ohm resistor near the usb connector there have been lots of posts about dry solder joints. I believe that's a crystal, AFAIK removing the caps should remove the need to remove the crystal.
PostPosted: February 17th, 2022, 7:22
yes when connect usb cable withe led poer on and motor spin but on sata port nothing, i have check the solder with tester but nothing the connection are good, I have retry on another pcb (same pcb) and same situation. The guide are this https://www.dolphindatalab.com/how-to-c ... interface/
Users browsing this forum: Google [Bot] and 225 guests
