 Post subject: Marvel 88NV1120 Blueray SSD
PostPosted: August 14th, 2020, 11:26
Hi
I have this SSD with this controller that get's full ID with full LBA, but when I try to view the sectors, I can only see sector 0.
I can go to the end of the drive, but it shows always the same as sector 0.
Does anyone have any solution for this? Quote me if you can solve it.
Thank You
ACELab partner
 Post subject: Re: Marvel 88NV1120 Blueray SSD
PostPosted: August 16th, 2020, 3:20
My solution works for some cases, but not for all. I can check, but need have drive on table.
PostPosted: November 13th, 2021, 7:56
I have an identical case, someone found the solution
PostPosted: February 23rd, 2022, 16:00
Hey Guys,
i have a ADATA SP580 with the same behavior.
Gets Full ID, access is a little bit weak and shown sectors are empty.
Any advice to fix?
PostPosted: February 24th, 2022, 9:38
Hi friends, about my case I forgot to comment with you, I can recover a week later with the ROCKET software and tool and the Hardware Challenger PCIe Board 6GB Pro version with a configuration of Power On and Power OFF every 2 seconds, I have the time a basic article made that I will make available on the forums about the tool https://www.recoveryitalia.it/products/
PostPosted: February 26th, 2022, 10:18
Does that tool clone the data first? Or is it direct file extraction?
Users browsing this forum: No registered users and 124 guests
