 Post subject: Intel DC S4500 1.92TB (HPE branded) BAD_CONTEXT_2020
PostPosted: July 24th, 2021, 12:28
Hi All,
I've got 2 Intel SSD DC S4500 1.92TB, they are HPE branded. When I put them in the computer they are correctly recognized but cannot be formatted, they will be block on un-initialized, when trying to initialize I will get different error one being "the device cannot find the requested sector". I tried from MacOs, Windows, Ubuntu, it will always fail.I did some research online, and found out that these drive with the firmware they have from HPE (HPG2) may have an issue where they will stop working after a certain time because of firmware issue (https://support.hpe.com/hpesc/public/do ... 72768en_us). So I tried to update the firmware to latest one (HPG5 or HPG3) but it will always fail on Windows. And on Ubuntu it says : "deferred flash,reboot required to apply" but even after reboot it will never do the update. So second step I tried to check from the intel-cli tool and got the following :
-1 Intel SSD DC S4500 Series -
Capacity : 1920,38 GB
DevicePath : /dev/sgl
DeviceStatus : *BAD_CONTEXT_2020 PG
Firmware : 4IYVHPG2
FirmwareUpdateAvailable:Please contact Intel Customer Support for further assistance at the following website: http://www.intel.com/go/ssdsupport
Index : 1
MaximumLBA:3750748847
Model Number : VK001920GWJPH
Percent@verProvisioned : Property not found
ProductFamily : Intel SSD DC S4500 Series
SMARTEnabled : True
SectorDataSize: 512
Obviously the intel-cli refuses to do anything on the drive and says : "selected drive is in a disabled logical state". I also believe that the intel-cli tool would never flash anything on it since it's an HPE branded drive. Checking crystaldiskinfo, it sees the drive and gives some info about it, but no smart attribute, nothing (might be due to HPE firmware).
Here are the pictures of the pcb of this drive :
I believe this is more a firmware issue than an hardware issue, so I was wondering if someone new of a way to put these drive into recovery,rom or any specific mode that would allow for a new firmware to be flashed successfully on it (either the HPE one or the intel firmware) or at least remove that disabled logical state. I don't mind losing all the data on the drives.
Thanks in advance,
 Post subject: Re: Intel DC S4500 1.92TB (HPE branded) BAD_CONTEXT_2020
PostPosted: February 16th, 2022, 23:35
Re-upping the subject in case someone has an idea on how to fix these. I don't need whats on the drive, just need them to work.
Thanks,
PostPosted: February 23rd, 2022, 22:44
Try running secure erase with password like with the 8mb error on intel ssd
PostPosted: March 8th, 2022, 1:58
Thanks for your reply. Sadly i already tried secure erase with password, it doesn't work.
i also tried to flash directly from esxi using latest available firmware from some months ago from HP in an hp server, i get the following error :
Executing ESXi70 binaries and copying to current directory
Online HDD/SSD Flash Component for VMware ESXi - VK000240GWJPD, VK000480GWJPE, VK000960GWJPF, VK001920GWJPH, VK003840GWJPK, MK000240GWKVK, MK000480GWJPN, MK000960GWJPP and MK001920GWJPQ Drives (HPG5), searching...
1) VK001920GWJPH Drive 1I:0:7 (Smart Array P420i in Slot 0) (HPG2)
2) VK001920GWJPH Drive 1I:0:8 (Smart Array P420i in Slot 0) (HPG2)
Select which devices to flash [#,#-#,(A)ll,(N)one]> A
Flashing Drive 1I:0:7 (Smart Array P420i in Slot 0) [ HPG2 -> HPG5 ]
Command failed
   Device AC:3855155103,PD:2 of type 4 failed BMIC WriteDeferredUpdate
Flashing Drive 1I:0:8 (Smart Array P420i in Slot 0) [ HPG2 -> HPG5 ]
Command failed
   Device AC:3855155103,PD:3 of type 4 failed BMIC WriteDeferredUpdate
Maybe it will help.. but doesn't say much...
Thanks,
