 Post subject: Need loader
PostPosted: March 16th, 2022, 12:34
Spyg2
Ver : 00000008
Thanks in advance
 Post subject: Re: Need loader
PostPosted: March 16th, 2022, 14:31
Anyone know the two points of read channel (TV9&TV10) for (2060-810035) ?
Much appreciated
PostPosted: March 16th, 2022, 15:42
Hope this helps
11.zip [684.07 KiB]
Downloaded 340 times
PostPosted: March 16th, 2022, 21:21
Much appreciated
Yes. If you upload a photo, I'll show you.
PostPosted: March 17th, 2022, 9:37
Cleanroom wrote:
Hope this helps
Many thanks
Much appreciated
Sorry for the bad quality of the photos :
PostPosted: March 17th, 2022, 10:34
Drive model : WD50NDZW-11BCSS1
Tried different loaders without luck. (reset power and not accepted loader)
The drive is always busy, tried loader with and without SA access in ROM but no luck.
PostPosted: March 17th, 2022, 12:50
The photos are too small. Sorry.
PostPosted: March 17th, 2022, 15:24
Anyone got resources for this drive?
PostPosted: March 17th, 2022, 16:52
With the PCB removed from the HDA, measure the voltages at the indicated read/write channel test points (with respect to ground).
I expect that the read channel will measure 0V.
PostPosted: March 21st, 2022, 7:37
Thanks a lot Mr. Franc for your efforts. Much appreciated.
Case closed.
PostPosted: June 10th, 2022, 14:01
Hello there,
I have a wd Drive model : WD50NDZW-11BCSS1, rom version 00000008, same as your recent case.
Drive was dropped and was opened by another lab, after head change, no spin down, however drive canot be id fully.
Have you recovered your case and would like to share the rom and loader? Thanks.
Have a good day.
Eug
