Post new topic Reply to topic  [ 32 posts ]  Go to page Previous  1, 2
 Post subject: Re: Crucial MX300 - No SATA connection
PostPosted: March 21st, 2022, 11:25
Yep - Vcc from MSP is connected to Out of NL
PostPosted: March 21st, 2022, 11:50
Changed MSP430 - and what should i say - i'm IN ;)
Thx for everything
PostPosted: March 21st, 2022, 12:04
outbreak198x wrote:
in any case, NL is not dead :D - working on donorpcb
it's not easy to find out, because both sides...
i think i know where the 1,8V came from
maybe this should be just a 0-Ohm Resistor? should i try to short it :D - i'm so shy
No, don't short it yet. You still haven't told us where the diode is connected. Is there a marking code on it? Where is the 4.4V coming from?
Measure the resistance of the resistor on your patient and donor.
PostPosted: March 21st, 2022, 12:18
Finally it already works :)
but i can check when cloned if you want ;)
PostPosted: March 21st, 2022, 12:19
That must mean that the "NL" LDO must getting its power from 5Vin rather than 5Vout. I wonder if the heating that you sensed was actually coming from the resistor rather than the diode. On another Crucial SSD there was a 10 ohm resistor in series with the supply to the MSP430.
Here is another soft start thread:
https://forum.hddguru.com/viewtopic.php?f=10&t=33908&p=269986#p269986
PostPosted: March 21st, 2022, 12:21
That must mean that the "NL" LDO must getting its power from 5Vin rather than 5Vout. I wonder if the heating that you sensed was actually coming from the resistor rather than the diode. On another Crucial SSD, there was a 10 ohm resistor in series with the supply to the MSP430.
it's a 10 Ohm restistor, and yes, i think that's what was hot - but my FLIR cam is on the way, so in future, i can send you thermal pics ;)
PostPosted: March 21st, 2022, 15:23
Read the ROM on the programmer and put it here, there may be problems with it.
PostPosted: March 22nd, 2022, 4:45
no - i already changed ROM before ;)
but as written, Problem is solved by changing MSP Chip
PostPosted: March 22nd, 2022, 7:12
The ROM is unique, for each SSD, it cannot be changed, and it has a block that is responsible for the MSP
PostPosted: March 22nd, 2022, 7:15
i know that it is unique, it was just a Test to find out if the ROM Chip was faulty.
but as told - i already have all the data
PostPosted: March 22nd, 2022, 8:33
FLIR arrived :D
have to play around with it, but first images shows me, that i'm not that bad at guessing temperatures :D
PostPosted: March 22nd, 2022, 8:51
Not sure what your calibration is like, but flip the pcb over and check it again.
