Post new topic Reply to topic  [ 32 posts ]  Go to page Previous  1, 2
 Post subject: Re: WD - HGST 18TB HELIUM - ROM?
PostPosted: April 19th, 2022, 13:33
DRUG wrote:
Already done some measurements, both fuses read 0.00V
Volts or ohms?
What about the rest?
What model is it?
Model is:
WD Ultrastar® DC HC550
PostPosted: April 19th, 2022, 15:55
AFAICT, your ROM has a width of 3mm and a pin pitch of 0.8mm. I haven't been able to find a breakout PCB or DIP-to-smt adaptor that has these dimensions. :-(
PostPosted: April 20th, 2022, 6:40
According to a pcb vendor only both rom chips should be changed.
Will try soon and report back.
PostPosted: April 20th, 2022, 10:21
https://pt.aliexpress.com/item/4000594884381.html
3x2 and pitch 0.5mm
VEXUS Data Recovery
PostPosted: April 20th, 2022, 10:56
ops, adapter wrong...
VEXUS Data Recovery
PostPosted: April 20th, 2022, 15:18
I've been examining the firmware updates for this family.
He16 & He18 Ultrastar DC HC550 Firmware Update:
https://support-en.westerndigital.com/app/answers/detail/a_id/29514
PCM R270 SATA 4kn&512e
https://download.wdc.com/hdd/PCGAW270.zip
PCM R232 SAS 4kn&512e
https://download.wdc.com/hdd/PCM_R232_SAS_4kn%26512e.zip
PCM R232 SATA 4kn&512e
https://download.wdc.com/hdd/PCM_R232_SATA_4kn%26512e.zip
PCM R120 SAS 4kn&512e
https://download.wdc.com/hdd/PCM_R120_SAS_4kn%26512e.zip
PCM R120 SATA 4kn&512e
https://download.wdc.com/hdd/PCM_R120_SATA_4kn&512e.zip
I have extracted the individual firmware modules from each of the payloads (see attachment). I notice that there is an RSIG module (ID = 0x16). This consists of a 0x100-byte signature plus a 32-bit checksum. The little-endian sum of the dwords in the signature plus the checksum dword is 0x00000000.
I don't recall seeing this module in earlier He firmwares, so perhaps WD has tightened the security.
He16_He18_Ultrastar_DC_HC550.7z [7.15 MiB]
Downloaded 411 times
PostPosted: April 26th, 2022, 17:56
Here are the package dimensions.
DIP adapter (not cheap):
https://www.reveltronics.com/en/shop/76/7/chip-programmers/adapter-dfn8-3x4-udfn8-vson8-uson8-dil8-dip8-76-detail
https://forum.reveltronics.com/viewtopic.php?t=79
PostPosted: April 27th, 2022, 6:24
Thank you, Reveltronics is great.
PostPosted: May 2nd, 2022, 18:28
I managed to find a slighty cheaper one.
https://a.aliexpress.com/_mOLkv0Q
About the case, it was solved, only 2 rom swapped.
HOWEVER, today I got exactly the same model coming in, same issue, and since i had a spare pcb i quickly jumped to be a rom jockey to find out it didnt work. Upon further inspection I decided to swap the controller, and data is being cloned right now.
PostPosted: May 2nd, 2022, 19:20
Are you saying that two PCBs from the same model behaved differently, one with a unique key in the MCU, the other without???
PostPosted: May 2nd, 2022, 19:58
Yes... When the data is cloned i'll test if the donor mcu was damaged by any chance.
PostPosted: May 13th, 2025, 1:14
sorry for asking you about this old post .
did you swapped the controller and roms to donor board? could you get the data?
Users browsing this forum: No registered users and 394 guests
cron
