 Post subject: Need Urgent Help for ST3500418AS CC46
PostPosted: May 6th, 2022, 12:19
Hello
I have a seagate drive ST3500418AS and firmware version is CC46. Hdd is not detected at all. Power on smoothly and no clicking noise. I start the terminal and following output come in terminal. Can anybody help me? i have not MRT and PC3000 like expensive tool. I think some of sys file is damage. Please see my terminal output and how to solve the problem and can anyone tell me which sys file is damage? Only following command applied till now.
Hard Disk Details:
Seagate ST3500418AS
FW: CC46
S/N: 9VMXPPJ9
P/N: 9SL142-303
Date Code: 11285
Site Code: TK
Terminal output:
Rst 0x10M
Servo Processor Is Reset.
RW: Disc Ctlr Initialization Completed.
ExecuteSpinRequest
vYvYvYvYvYvYvYvYvYvYvYvYvYvYvYvYvYvYvYvY
SIM Error 1002
(P) SATA Reset
SIM Error 1002 PASSvYvYvYvYvYvYvYvYvYvYvYvYvYvYvYvYvYvYvYvY
SIM Error 1002vYvYvYvYvYvYvYvYvYvYvYvYvYvYvYvYvYvYvYvY
SIM Error 1002WriteDCOInfo FAILED during Initialization
RW: Error processing Performance Parameter File: 203C
(P) SATA Reset
SIM Error 3005vYvYvYvYvYvYvYvYvYvYvYvYvYvYvYvYvYvYvYvY
SIM Error 1002
No HOST FIS-ReadyStatusFlags 2002A1A5
ASCII Diag mode
F3 T>
ASCII Diag mode
F3 T>
Model : ST3500418AS Barracuda 7200.12
Family : YETIST_3_*/4_0(649B)(3-12-3-3)
Admin : PH0G2D.CCD4.GZ0E9Y.CC46
Firmware : CC46
Speed : 7201 RPM
Head : 2
Capacity : 976773168 (500G)
S/N : 9VMXPPJ9
F3 T>
ASCII Diag mode
F3 T>m0,2,2,,,,,22
RW subfile error 201FMax Wr Retries = 00, Max Rd Retries = 00, Max ECC T-Level = 16, Max Certify Rewrite Retries = not supported
SIM Error 1002
DiagError 0000500D
User Partition Format Failed - Elapsed Time 0 mins 00 secs
R/W Sense 00000002, R/W Error 00000084, File Error 00001002
Blk Addr 000071030001, Blk Addr Type D0, Cyl 00000000, Hd 02
F3 T>
ASCII Diag mode
F3 T>m0,2,2,,,,,22
SIM Error 1002
DiagError 0000500D
Blk Addr 000071030001, Blk Addr Type D0, Cyl 00000000, Hd 00
F3 T>
ASCII Diag mode
F3 T>F,,22
SIM Error 1002
DiagError 00000018
F3 T>
ASCII Diag mode
F3 T>F,,22
SIM Error 1002
DiagError 00000018
F3 T>
ASCII Diag mode
F3 T>/7
F3 7>X
Head 00 Resistance 00F6
Head 01 Resistance 011F
F3 7>
 Post subject: Re: Need Urgent Help for ST3500418AS CC46
PostPosted: May 7th, 2022, 4:03
Sim 1002 is usually a problem with defect lists, possibly P.
But I've also seen it related to heads problem.
You can see which sysfile is bad with CTRL+X.
PostPosted: May 10th, 2022, 5:30
Hello Northwind,
Sorry for late becauseof out of city.
This is my ctrl+x log in terminal. can you please tell me which sysfile is bad? please help me.
Rst 0x10M
ExecuteSpinRequest
SIM Error 1002
RW subfile error 2044
(P) SATA Reset
(P) SATA Reset
SIM Error 1002
ASCII Diag mode
F3 T>
ATA 15 Cmds
Ts(ms) dT(ms) Op Cnt LBA
0 99999999 00 0000 000000000000
0 0 00 0000 000000000000
RW 32 Cmds
Ts(ms) dT(ms) xT(ms) Type Option Mode St EC Info
10144 99999999 3 02 002241 000000 1 00000080 XFR RD SYS LBA B 000000008E55 L 00000001 BO 000000 BES 006D800.006DCFF.006D800
10148 4 4 02 005041 000000 1 00000080 XFR WR SYS LBA B 0000000075AA L 00000001 BO 000000 BES 0061A7E.0061AFD.0061A7E
10152 4 9 02 002241 000000 1 00000080 XFR RD SYS LBA B 000000009067 L 00000014 BO 000000 BES 00C17F6.02FFFFF.00C17F6
10162 10 6 02 002241 000000 1 00000080 XFR RD SYS LBA B 0000000075AB L 00000001 BO 000000 BES 00618FE.006197D.00618FE
10170 8 2 02 002241 000000 1 00000080 XFR RD SYS LBA B 000000008E54 L 00000001 BO 000000 BES 006D800.006DCFF.006D800
10173 3 8 02 005041 000000 1 00000080 XFR WR SYS LBA B 000000008E54 L 00000001 BO 000000 BES 006D800.006D87F.006D800
10181 8 625 02 005041 000000 2 C4440080 XFR WR SYS LBA B 00000002EB08 L 00000001 BO 000000 BES 006D800.006D87F.006D800
10807 626 1598 02 005041 000000 2 C4440080 XFR WR SYS LBA B 00000002EB08 L 00000001 BO 000000 BES 006D800.006D87F.006D800
12405 1598 624 02 005041 000400 2 C4440080 XFR WR SYS LBA B 00000002EB08 L 00000001 BO 000000 BES 006D800.006D87F.006D800
13034 629 4 02 002241 000000 1 00000080 XFR RD SYS LBA B 0000000060A4 L 00000006 BO 000000 BES 006D800.006DAFF.006D800
13039 5 8 02 005041 000000 1 00000080 XFR WR SYS LBA B 0000000060A4 L 0000000A BO 000000 BES 006D800.006DCFF.006D800
13047 8 5 02 005041 000000 1 00000080 XFR WR SYS LBA B 0000000055B4 L 00000008 BO 000000 BES 0061BFE.0061FFD.0061BFE
13052 5 625 02 005041 000000 2 C4440080 XFR WR SYS LBA B 00000002B268 L 00000008 BO 000000 BES 0061BFE.0061FFD.0061BFE
13678 626 1598 02 005041 000000 2 C4440080 XFR WR SYS LBA B 00000002B268 L 00000001 BO 000000 BES 0061BFE.0061FFD.0061BFE
15276 1598 624 02 005041 000400 2 C4440080 XFR WR SYS LBA B 00000002B268 L 00000008 BO 000000 BES 0061BFE.0061FFD.0061BFE
15915 639 1 27 005041 000400 1 00000080 SND_SRV 0C01 0000 0000 0000 0000 0000 0000 0000 0001 D26C 00D0
0D5C 0400 0000 0000 0002 1250 FE20 0000 12F1 0000 0000 0000 0000 0000 0000 0000
15930 15 3 02 002241 000000 1 00000080 XFR RD SYS LBA B 00000002B278 L 00000009 BO 000000 BES 006ED80.006F1FF.006ED80
15936 6 0 42 002241 000000 1 00000080 SWD
15945 9 4 02 005041 000000 1 00000080 XFR WR SYS LBA B 0000000055B4 L 00000008 BO 000000 BES 0061BFE.0061FFD.0061BFE
15950 5 625 02 005041 000000 2 C4440080 XFR WR SYS LBA B 00000002B268 L 00000008 BO 000000 BES 0061BFE.0061FFD.0061BFE
16575 625 1598 02 005041 000000 2 C4440080 XFR WR SYS LBA B 00000002B268 L 00000001 BO 000000 BES 0061BFE.0061FFD.0061BFE
18174 1599 624 02 005041 000400 2 C4440080 XFR WR SYS LBA B 00000002B268 L 00000008 BO 000000 BES 0061BFE.0061FFD.0061BFE
18813 639 0 27 005041 000400 1 00000080 SND_SRV 0C01 0000 0000 0000 0000 0000 0000 0000 0001 D26C 00D0
18837 24 10 02 002241 000000 1 00000080 XFR RD SYS LBA B 000000008A0C L 000000C8 BO 000000 BES 006207E.006847D.006207E
18848 11 4 02 005041 000000 1 00000080 XFR WR SYS LBA B 0000000075AA L 00000001 BO 000000 BES 0061A7E.0061AFD.0061A7E
18853 5 5 02 002241 000000 1 00000080 XFR RD SYS LBA B 0000000060A4 L 00000006 BO 000000 BES 006D800.006DAFF.006D800
18858 5 8 02 005041 000000 1 00000080 XFR WR SYS LBA B 0000000060A4 L 0000000A BO 000000 BES 006D800.006DCFF.006D800
18868 10 4 02 005041 000000 1 00000080 XFR WR SYS LBA B 0000000055B4 L 00000008 BO 000000 BES 0061BFE.0061FFD.0061BFE
18872 4 625 02 005041 000000 2 C4440080 XFR WR SYS LBA B 00000002B268 L 00000008 BO 000000 BES 0061BFE.0061FFD.0061BFE
19497 625 1599 02 005041 000000 2 C4440080 XFR WR SYS LBA B 00000002B268 L 00000001 BO 000000 BES 0061BFE.0061FFD.0061BFE
21096 1599 624 02 005041 000400 2 C4440080 XFR WR SYS LBA B 00000002B268 L 00000008 BO 000000 BES 0061BFE.0061FFD.0061BFE
21735 639 0 47 000000 000400 1 00000080 DISC_SLIP
PostPosted: May 10th, 2022, 6:52
There is a RW error on important sysfile (30A).
It can be fixed, but needs pro knowledge (and tools).
PostPosted: May 10th, 2022, 6:53
Hello Northwind
Its fixable via terminal program? can you guide me sir?
PostPosted: May 10th, 2022, 8:56
anybody help me please?
PostPosted: May 10th, 2022, 16:04
you got RW errors on H1, so i think it is weak and needs proper treatment. Not something for DIY if data is important.
PostPosted: May 11th, 2022, 1:35
Case solved. All data recovered. No head problem or anything releated to pcb. Sys files damage and user gps31 help me to solve this case. He provide me sys files and tell me how to solve case. Thanx @gps31
PostPosted: May 11th, 2022, 5:06
good. It's odd coz it could not write 30A copy1 on its own (C4440080 XFR WR SYS LBA B 00000002B268), which led me think it has problems with H1 despite the resistance being ok...
PostPosted: May 11th, 2022, 14:29
Pepe Sir ,
How does this text " C4440080 XFR WR SYS LBA B 00000002B268 " gave you the idea ,Are these strings of text documented someware
Hey ,
Which Sysfile was that ?
PostPosted: May 11th, 2022, 14:32
0xC4440080: RW_WRITE_PREAMP_UNSAFE_FAULT - Disc Xfr - Write during preamp unsafe fault.
PostPosted: May 11th, 2022, 17:23
Hey ,
3_30A, as been said above
PostPosted: May 11th, 2022, 17:24
Hey ,
PostPosted: May 14th, 2022, 8:05
Well,
there has to exist some documentation that should make a engineer understand how to parse this code ,i am asking about that
Users browsing this forum: Google [Bot] and 50 guests
