Post new topic Reply to topic  [ 32 posts ]  Go to page 1, 2  Next
 Post subject: WD2500JB change PCB U12.
PostPosted: May 18th, 2022, 16:13
I tested with a heat gun that was a little bigger, around 2.5cm in circumference. Got both U12 off smoothly. But the card now does not seem to start or give any start to the disk. They look completely except slightly burnt on contact plastic. Guess you should have a smaller one as indeed surrounding components are sensitive to heat? Tested another card and they became the same. But without anything burned.
 Post subject: Re: WD2500JB change PCB U12.
PostPosted: May 18th, 2022, 19:05
I tried the card without the pcb connected and it didn't start. Do i need it just for the disk to start? Have i burnt the 2 cards for using a to big heat gun? I only had it for max 6 to 10 seconds.
PostPosted: May 18th, 2022, 20:19
Is this a data recovery task, or are you just practising? Do you have an SPI flash reader?
PostPosted: May 18th, 2022, 20:36
Yes from a drive with a broken power card. I had 1 broken drive that worked when i switched the card from one of the working. The only thing was i forgot to switch the pcb from the working. When i had done it the drive won't even start. Can i have burned something? It was my first time.
PostPosted: May 18th, 2022, 21:09
No flash reader unfortunately
PostPosted: May 18th, 2022, 21:30
Is it possible that the original fault on the original PCB damaged U12? Is the SMOOTH chip burnt?
PostPosted: May 18th, 2022, 21:44
Smooth chip? I am a beginner. The original pcb didn't even gave any power to the drive. I tried with my other working card and then it worked. But i forgot to change the U12. When i had changed U12 the card didn't gave any power to the disk. Have i burned any sensitive parts? Should the pcb start the disk without U12? I tried but no power.
PostPosted: May 18th, 2022, 21:50
Oldschool297 wrote:
Smooth chip?
Sorry, it appears you may have an older PCB. I was asking whether the motor controller chip (SMOOTH) was burnt, but this may not be relevant in your case.
Are either of these boards yours?
https://sep.yimg.com/ay/yhst-14437584971410/wd-2060-001265-001266-701265-701266-hard-drive-controller-card-pcb-circuit-board-firmware-transfer-3.gif
https://sep.yimg.com/ay/yhst-14437584971410/wd-caviar-wd1600bb-00fta0-wd1600bb-00ftao-160gb-ide-pcb-circuit-board-3.gif
PostPosted: May 18th, 2022, 22:00
Sorry i should have posted. I tried with the second card and right U12 but it don't even start the disk. Shouldn't the disk start without U12? https%3A%2F%2Fwww.imagebam.com%2Fview%2FMEAKAKB
PostPosted: May 18th, 2022, 22:01
https://www.imagebam.com/view/MEAKAKB
PostPosted: May 18th, 2022, 22:08
Nothing will happen if U12 is not present.
PostPosted: May 18th, 2022, 22:18
Thank you. I suspected that. And the disk cannot even spinup without it? Can i use some glue to the U12 to get it in right place? It looks to be a little misplaced.
PostPosted: May 18th, 2022, 23:02
U12 contains the boot firmware. It's like a BIOS. The motor won't do anything if U12 is not present.
PostPosted: May 18th, 2022, 23:07
I will try to get another try with the heat gun. I will post a detailed photo after.
PostPosted: May 18th, 2022, 23:28
Maybe you should invest in a proper hot air station. Heat guns are more appropriate for stripping paint.
PostPosted: May 19th, 2022, 0:49
The best photos i could get. No motor response. https://www.imagebam.com/view/MEAMTWC
PostPosted: May 19th, 2022, 2:25
I guess it is important that the U12 is exactly on the right place? I have tried 3 different. Still the same. No hard drive motor response. It don't even start.
PostPosted: May 19th, 2022, 4:15
Does the U12 need to be attached in a certain way. With the text in front or backwards?
PostPosted: May 19th, 2022, 4:37
There's an indent on the chip this is pin 1. It goes to pin 1 on the pcb, your pictures are not clear enough to see if there are any marking (a dot, triangle etc) or a pin number. Looking at the last picture you took Id say it was bottom left.
PostPosted: May 19th, 2022, 6:20
Thank you. So there are a No 1 pin on the U12 that should be on no 1 on the pcb?
Users browsing this forum: Hotaru and 74 guests
