Forum rules
 Post subject: Mod Compare
PostPosted: May 20th, 2022, 18:29
Hi I have a new mod compare program coming up as OpenSource. I will be posting the source code soon for dissection and improvement.
Here's the output
Number of modules in A.txt is 482
Number of modules in B.txt is 503
B has more files than A
Number_Of_Same_Files 479
01.rpm UNIQUE Length in A is 12288 bytes and B is 11984 bytes
02.rpm UNIQUE Length in A is 2560 bytes and B is 2560 bytes
03.rpm UNIQUE Length in A is 167936 bytes and B is 167936 bytes
04.rpm UNIQUE Length in A is 14420992 bytes and B is 14420992 bytes
0C.rpm UNIQUE Length in A is 6144 bytes and B is 6144 bytes
1000.rpm UNIQUE Length in A is 14848 bytes and B is 14848 bytes
1001.rpm UNIQUE Length in A is 13312 bytes and B is 13312 bytes
1002.rpm UNIQUE Length in A is 18944 bytes and B is 18944 bytes
1003.rpm UNIQUE Length in A is 18432 bytes and B is 18432 bytes
1004.rpm UNIQUE Length in A is 21504 bytes and B is 21504 bytes
1005.rpm UNIQUE Length in A is 16384 bytes and B is 16384 bytes
1007.rpm UNIQUE Length in A is 13312 bytes and B is 13312 bytes
1008.rpm UNIQUE Length in A is 18432 bytes and B is 18432 bytes
1009.rpm UNIQUE Length in A is 16896 bytes and B is 17408 bytes
100A.rpm UNIQUE Length in A is 19456 bytes and B is 19456 bytes
100B.rpm UNIQUE Length in A is 12288 bytes and B is 12288 bytes
100C.rpm UNIQUE Length in A is 13824 bytes and B is 13824 bytes
100E.rpm UNIQUE Length in A is 12288 bytes and B is 12288 bytes
100F.rpm UNIQUE Length in A is 15360 bytes and B is 15360 bytes
1010.rpm UNIQUE Length in A is 12288 bytes and B is 12288 bytes
1011.rpm UNIQUE Length in A is 19968 bytes and B is 19968 bytes
***************102.rpm file is identical***************
***************103.rpm file is identical***************
***************104.rpm file is identical***************
***************105.rpm file is identical***************
***************106.rpm file is identical***************
108.rpm UNIQUE Length in A is 19456 bytes and B is 21504 bytes
109.rpm UNIQUE Length in A is 524800 bytes and B is 524800 bytes
11.rpm UNIQUE Length in A is 682496 bytes and B is 701440 bytes
1100.rpm UNIQUE Length in A is 8192 bytes and B is 8192 bytes
1101.rpm UNIQUE Length in A is 65536 bytes and B is 65536 bytes
***************1102.rpm file is identical***************
***************1105.rpm file is identical***************
***************1106.rpm file is identical***************
1121.rpm UNIQUE Length in A is 65536 bytes and B is 65536 bytes
115.rpm UNIQUE Length in A is 289280 bytes and B is 221696 bytes
116.rpm UNIQUE Length in A is 3072 bytes and B is 3072 bytes
118.rpm UNIQUE Length in A is 17920 bytes and B is 18432 bytes
119.rpm UNIQUE Length in A is 2560 bytes and B is 2560 bytes
120.rpm UNIQUE Length in A is 558080 bytes and B is 670208 bytes
120F.rpm UNIQUE Length in A is 8704 bytes and B is 8704 bytes
***************121.rpm file is identical***************
121F.rpm UNIQUE Length in A is 8192 bytes and B is 8192 bytes
***************122.rpm file is identical***************
123.rpm UNIQUE Length in A is 512 bytes and B is 512 bytes
124.rpm UNIQUE Length in A is 512 bytes and B is 512 bytes
125.rpm UNIQUE Length in A is 512 bytes and B is 512 bytes
126.rpm UNIQUE Length in A is 512 bytes and B is 512 bytes
***************127.rpm file is identical***************
***************128.rpm file is identical***************
***************12A.rpm file is identical***************
12D.rpm UNIQUE Length in A is 153600 bytes and B is 153600 bytes
131.rpm UNIQUE Length in A is 258048 bytes and B is 258048 bytes
132.rpm UNIQUE Length in A is 32768 bytes and B is 32768 bytes
13F5.rpm UNIQUE Length in A is 13312 bytes and B is 13312 bytes
1400.rpm UNIQUE Length in A is 8704 bytes and B is 8704 bytes
1410.rpm UNIQUE Length in A is 8704 bytes and B is 8704 bytes
144.ERR UNIQUE Length in A is 262144 bytes and B is 262144 bytes
148.rpm UNIQUE Length in A is 1024 bytes and B is 1024 bytes
149.rpm UNIQUE Length in A is 130560 bytes and B is 130560 bytes
14A.rpm UNIQUE Length in A is 154112 bytes and B is 241664 bytes
1530.rpm UNIQUE Length in A is 2048 bytes and B is 2048 bytes
***************1531.rpm file is identical***************
16F.rpm UNIQUE Length in A is 1536 bytes and B is 1536 bytes
1800.rpm UNIQUE Length in A is 10752 bytes and B is 10752 bytes
1801.rpm UNIQUE Length in A is 10752 bytes and B is 10752 bytes
1802.rpm UNIQUE Length in A is 10752 bytes and B is 10752 bytes
1803.rpm UNIQUE Length in A is 10752 bytes and B is 10752 bytes
1804.rpm UNIQUE Length in A is 10752 bytes and B is 10752 bytes
1810.rpm UNIQUE Length in A is 10752 bytes and B is 10752 bytes
1811.rpm UNIQUE Length in A is 10752 bytes and B is 10752 bytes
1812.rpm UNIQUE Length in A is 10752 bytes and B is 10752 bytes
1813.rpm UNIQUE Length in A is 10752 bytes and B is 10752 bytes
1814.rpm UNIQUE Length in A is 10752 bytes and B is 10752 bytes
1900.rpm UNIQUE Length in A is 16384 bytes and B is 16384 bytes
1901.rpm UNIQUE Length in A is 16384 bytes and B is 16384 bytes
21.rpm UNIQUE Length in A is 103424 bytes and B is 104960 bytes
22D.rpm UNIQUE Length in A is 19456 bytes and B is 19456 bytes
23.rpm UNIQUE Length in A is 103424 bytes and B is 104960 bytes
24.rpm UNIQUE Length in A is 103424 bytes and B is 104960 bytes
2401.rpm UNIQUE Length in A is 265216 bytes and B is 272896 bytes
2403.rpm UNIQUE Length in A is 203264 bytes and B is 213504 bytes
2404.rpm UNIQUE Length in A is 178688 bytes and B is 188416 bytes
2407.rpm UNIQUE Length in A is 249856 bytes and B is 264192 bytes
2408.rpm UNIQUE Length in A is 186368 bytes and B is 202752 bytes
2409.rpm UNIQUE Length in A is 263168 bytes and B is 282624 bytes
240A.rpm UNIQUE Length in A is 164352 bytes and B is 166400 bytes
240B.rpm UNIQUE Length in A is 152576 bytes and B is 162304 bytes
240C.rpm UNIQUE Length in A is 187392 bytes and B is 196608 bytes
240E.rpm UNIQUE Length in A is 192512 bytes and B is 203264 bytes
2410.rpm UNIQUE Length in A is 139264 bytes and B is 130560 bytes
2413.rpm UNIQUE Length in A is 151552 bytes and B is 145408 bytes
2414.rpm UNIQUE Length in A is 200704 bytes and B is 212992 bytes
2415.rpm UNIQUE Length in A is 147968 bytes and B is 144384 bytes
241A.rpm UNIQUE Length in A is 174080 bytes and B is 183808 bytes
241D.rpm UNIQUE Length in A is 171520 bytes and B is 186880 bytes
241E.rpm UNIQUE Length in A is 179200 bytes and B is 188416 bytes
241F.rpm UNIQUE Length in A is 180736 bytes and B is 192000 bytes
2420.rpm UNIQUE Length in A is 324608 bytes and B is 342528 bytes
2422.rpm UNIQUE Length in A is 179200 bytes and B is 188416 bytes
2423.rpm UNIQUE Length in A is 89600 bytes and B is 98304 bytes
2424.rpm UNIQUE Length in A is 178176 bytes and B is 187904 bytes
2427.rpm UNIQUE Length in A is 148992 bytes and B is 142848 bytes
2429.rpm UNIQUE Length in A is 181760 bytes and B is 193024 bytes
242A.rpm UNIQUE Length in A is 157184 bytes and B is 154112 bytes
242C.rpm UNIQUE Length in A is 189440 bytes and B is 202752 bytes
242D.rpm UNIQUE Length in A is 194560 bytes and B is 212480 bytes
2432.rpm UNIQUE Length in A is 194560 bytes and B is 207872 bytes
25.rpm UNIQUE Length in A is 131584 bytes and B is 131584 bytes
2503.rpm UNIQUE Length in A is 290816 bytes and B is 337408 bytes
2504.rpm UNIQUE Length in A is 3072 bytes and B is 3072 bytes
2507.rpm UNIQUE Length in A is 257024 bytes and B is 257024 bytes
2509.rpm UNIQUE Length in A is 21504 bytes and B is 21504 bytes
250A.rpm UNIQUE Length in A is 113152 bytes and B is 139264 bytes
250B.rpm UNIQUE Length in A is 118784 bytes and B is 145920 bytes
250C.rpm UNIQUE Length in A is 1831424 bytes and B is 2093568 bytes
250E.rpm UNIQUE Length in A is 147456 bytes and B is 208896 bytes
2513.rpm UNIQUE Length in A is 69632 bytes and B is 84992 bytes
2514.rpm UNIQUE Length in A is 809984 bytes and B is 936960 bytes
251A.rpm UNIQUE Length in A is 88576 bytes and B is 89088 bytes
251E.rpm UNIQUE Length in A is 320512 bytes and B is 377856 bytes
2520.rpm UNIQUE Length in A is 3379200 bytes and B is 1843200 bytes
2522.rpm UNIQUE Length in A is 208384 bytes and B is 268288 bytes
2529.rpm UNIQUE Length in A is 833024 bytes and B is 1543680 bytes
252C.rpm UNIQUE Length in A is 1132032 bytes and B is 1136128 bytes
252D.rpm UNIQUE Length in A is 325120 bytes and B is 1264128 bytes
26.rpm UNIQUE Length in A is 66048 bytes and B is 66048 bytes
2640.rpm UNIQUE Length in A is 17920 bytes and B is 17920 bytes
2641.rpm UNIQUE Length in A is 17920 bytes and B is 17920 bytes
2642.rpm UNIQUE Length in A is 17920 bytes and B is 17920 bytes
2643.rpm UNIQUE Length in A is 17920 bytes and B is 17920 bytes
2644.rpm UNIQUE Length in A is 17920 bytes and B is 17920 bytes
2645.rpm UNIQUE Length in A is 17920 bytes and B is 17920 bytes
2670.rpm UNIQUE Length in A is 230400 bytes and B is 162816 bytes
2671.rpm UNIQUE Length in A is 230912 bytes and B is 161792 bytes
2672.rpm UNIQUE Length in A is 231424 bytes and B is 152064 bytes
2673.rpm UNIQUE Length in A is 231424 bytes and B is 161792 bytes
2674.rpm UNIQUE Length in A is 231424 bytes and B is 152064 bytes
2675.rpm UNIQUE Length in A is 230912 bytes and B is 151552 bytes
2690.rpm UNIQUE Length in A is 55808 bytes and B is 53760 bytes
2691.rpm UNIQUE Length in A is 54784 bytes and B is 53760 bytes
2692.rpm UNIQUE Length in A is 55296 bytes and B is 53760 bytes
2693.rpm UNIQUE Length in A is 55296 bytes and B is 53760 bytes
2694.rpm UNIQUE Length in A is 55808 bytes and B is 53760 bytes
2695.rpm UNIQUE Length in A is 55296 bytes and B is 53760 bytes
26D0.rpm UNIQUE Length in A is 270336 bytes and B is 316416 bytes
26D1.rpm UNIQUE Length in A is 287744 bytes and B is 313856 bytes
26D2.rpm UNIQUE Length in A is 288768 bytes and B is 291328 bytes
26D3.rpm UNIQUE Length in A is 257024 bytes and B is 302592 bytes
26D4.rpm UNIQUE Length in A is 289280 bytes and B is 347136 bytes
26D5.rpm UNIQUE Length in A is 267264 bytes and B is 313856 bytes
26E0.rpm UNIQUE Length in A is 2560 bytes and B is 2560 bytes
26E1.rpm UNIQUE Length in A is 2560 bytes and B is 2560 bytes
26E2.rpm UNIQUE Length in A is 2560 bytes and B is 2560 bytes
26E3.rpm UNIQUE Length in A is 2560 bytes and B is 2560 bytes
26E4.rpm UNIQUE Length in A is 2560 bytes and B is 2560 bytes
26E5.rpm UNIQUE Length in A is 2560 bytes and B is 2560 bytes
2700.rpm UNIQUE Length in A is 1536 bytes and B is 1536 bytes
2701.rpm UNIQUE Length in A is 1536 bytes and B is 1536 bytes
2702.rpm UNIQUE Length in A is 1536 bytes and B is 1536 bytes
2703.rpm UNIQUE Length in A is 1536 bytes and B is 1536 bytes
2704.rpm UNIQUE Length in A is 1536 bytes and B is 1536 bytes
2705.rpm UNIQUE Length in A is 1536 bytes and B is 1536 bytes
***************28.rpm file is identical***************
***************29.rpm file is identical***************
2A.rpm UNIQUE Length in A is 5632 bytes and B is 5632 bytes
2D.rpm UNIQUE Length in A is 409600 bytes and B is 409600 bytes
2D03.rpm UNIQUE Length in A is 1024000 bytes and B is 1024000 bytes
2D04.rpm UNIQUE Length in A is 1024000 bytes and B is 1024000 bytes
2D07.rpm UNIQUE Length in A is 1024000 bytes and B is 1024000 bytes
2D09.rpm UNIQUE Length in A is 1024000 bytes and B is 1024000 bytes
2D0A.rpm UNIQUE Length in A is 1024000 bytes and B is 1024000 bytes
2D0B.rpm UNIQUE Length in A is 1024000 bytes and B is 1024000 bytes
2D0C.rpm UNIQUE Length in A is 1024000 bytes and B is 1024000 bytes
2D0E.rpm UNIQUE Length in A is 1024000 bytes and B is 1024000 bytes
2D13.rpm UNIQUE Length in A is 1024000 bytes and B is 1024000 bytes
2D14.rpm UNIQUE Length in A is 1024000 bytes and B is 1024000 bytes
2D1A.rpm UNIQUE Length in A is 1024000 bytes and B is 1024000 bytes
2D1E.rpm UNIQUE Length in A is 1024000 bytes and B is 1024000 bytes
2D20.rpm UNIQUE Length in A is 1024000 bytes and B is 1536000 bytes
2D22.rpm UNIQUE Length in A is 1024000 bytes and B is 1024000 bytes
2D29.rpm UNIQUE Length in A is 1024000 bytes and B is 1024000 bytes
2D2C.rpm UNIQUE Length in A is 1024000 bytes and B is 1024000 bytes
2D2D.rpm UNIQUE Length in A is 1024000 bytes and B is 1024000 bytes
2E.rpm UNIQUE Length in A is 409600 bytes and B is 409600 bytes
2E00.rpm UNIQUE Length in A is 1024 bytes and B is 1024 bytes
2F.rpm UNIQUE Length in A is 2560 bytes and B is 2560 bytes
2FF0.rpm UNIQUE Length in A is 2041856 bytes and B is 1298432 bytes
31.rpm UNIQUE Length in A is 1377280 bytes and B is 1377280 bytes
32.rpm UNIQUE Length in A is 30720 bytes and B is 30720 bytes
33.rpm UNIQUE Length in A is 2099200 bytes and B is 2099200 bytes
3300.rpm UNIQUE Length in A is 122880 bytes and B is 137728 bytes
3301.rpm UNIQUE Length in A is 141312 bytes and B is 157184 bytes
3302.rpm UNIQUE Length in A is 142848 bytes and B is 161280 bytes
3303.rpm UNIQUE Length in A is 114688 bytes and B is 129024 bytes
3304.rpm UNIQUE Length in A is 123904 bytes and B is 142848 bytes
3305.rpm UNIQUE Length in A is 118272 bytes and B is 155648 bytes
3307.rpm UNIQUE Length in A is 143872 bytes and B is 161280 bytes
3309.rpm UNIQUE Length in A is 116224 bytes and B is 130048 bytes
3310.rpm UNIQUE Length in A is 114176 bytes and B is 128000 bytes
3311.rpm UNIQUE Length in A is 110592 bytes and B is 124928 bytes
3312.rpm UNIQUE Length in A is 110592 bytes and B is 124928 bytes
***************34.rpm file is identical***************
3400.rpm UNIQUE Length in A is 178176 bytes and B is 194048 bytes
3401.rpm UNIQUE Length in A is 169472 bytes and B is 185344 bytes
3402.rpm UNIQUE Length in A is 172544 bytes and B is 187904 bytes
3405.rpm UNIQUE Length in A is 173056 bytes and B is 189440 bytes
3406.rpm UNIQUE Length in A is 171008 bytes and B is 186368 bytes
3407.rpm UNIQUE Length in A is 171008 bytes and B is 186880 bytes
3408.rpm UNIQUE Length in A is 169984 bytes and B is 185856 bytes
3411.rpm UNIQUE Length in A is 110080 bytes and B is 124416 bytes
3413.rpm UNIQUE Length in A is 176640 bytes and B is 192512 bytes
3414.rpm UNIQUE Length in A is 112128 bytes and B is 125952 bytes
3416.rpm UNIQUE Length in A is 120320 bytes and B is 134144 bytes
3417.rpm UNIQUE Length in A is 174080 bytes and B is 189952 bytes
3421.rpm UNIQUE Length in A is 173056 bytes and B is 190976 bytes
3422.rpm UNIQUE Length in A is 134656 bytes and B is 149504 bytes
3423.rpm UNIQUE Length in A is 131072 bytes and B is 146432 bytes
3424.rpm UNIQUE Length in A is 129024 bytes and B is 152064 bytes
3425.rpm UNIQUE Length in A is 134656 bytes and B is 150016 bytes
3426.rpm UNIQUE Length in A is 133632 bytes and B is 148480 bytes
3429.rpm UNIQUE Length in A is 111104 bytes and B is 124928 bytes
3430.rpm UNIQUE Length in A is 177152 bytes and B is 194560 bytes
3431.rpm UNIQUE Length in A is 178688 bytes and B is 196096 bytes
34D1.rpm UNIQUE Length in A is 200192 bytes and B is 218112 bytes
34D2.rpm UNIQUE Length in A is 205312 bytes and B is 223232 bytes
34D3.rpm UNIQUE Length in A is 206336 bytes and B is 224256 bytes
34D4.rpm UNIQUE Length in A is 211456 bytes and B is 229888 bytes
34D5.rpm UNIQUE Length in A is 185856 bytes and B is 201728 bytes
34D6.rpm UNIQUE Length in A is 214528 bytes and B is 232960 bytes
34D7.rpm UNIQUE Length in A is 214016 bytes and B is 232448 bytes
34D8.rpm UNIQUE Length in A is 118272 bytes and B is 133120 bytes
34E7.rpm UNIQUE Length in A is 16384 bytes and B is 16384 bytes
35.rpm UNIQUE Length in A is 5120 bytes and B is 5120 bytes
3500.rpm UNIQUE Length in A is 171008 bytes and B is 186880 bytes
3501.rpm UNIQUE Length in A is 176128 bytes and B is 192512 bytes
3502.rpm UNIQUE Length in A is 170496 bytes and B is 186368 bytes
3503.rpm UNIQUE Length in A is 170496 bytes and B is 185856 bytes
3504.rpm UNIQUE Length in A is 176640 bytes and B is 192512 bytes
3511.rpm UNIQUE Length in A is 110592 bytes and B is 124416 bytes
3513.rpm UNIQUE Length in A is 201728 bytes and B is 219648 bytes
3514.rpm UNIQUE Length in A is 208384 bytes and B is 226816 bytes
3551.rpm UNIQUE Length in A is 119808 bytes and B is 136704 bytes
36.rpm UNIQUE Length in A is 7168 bytes and B is 7168 bytes
360.rpm UNIQUE Length in A is 786944 bytes and B is 787968 bytes
3604.rpm UNIQUE Length in A is 8192 bytes and B is 8192 bytes
3605.rpm UNIQUE Length in A is 110080 bytes and B is 124416 bytes
***************37.rpm file is identical***************
3700.rpm UNIQUE Length in A is 170496 bytes and B is 186368 bytes
3703.rpm UNIQUE Length in A is 132096 bytes and B is 146432 bytes
38.rpm UNIQUE Length in A is 131584 bytes and B is 131584 bytes
3801.rpm UNIQUE Length in A is 17920 bytes and B is 24064 bytes
3802.rpm UNIQUE Length in A is 1024 bytes and B is 1024 bytes
***************3803.rpm file is identical***************
39.rpm UNIQUE Length in A is 8704 bytes and B is 8704 bytes
3A.rpm UNIQUE Length in A is 6144 bytes and B is 6144 bytes
***************3B.rpm file is identical***************
***************3C.rpm file is identical***************
***************3C00.rpm file is identical***************
3C10.rpm UNIQUE Length in A is 53760 bytes and B is 53760 bytes
3C11.rpm UNIQUE Length in A is 53760 bytes and B is 53760 bytes
3C12.rpm UNIQUE Length in A is 53760 bytes and B is 53760 bytes
3C13.rpm UNIQUE Length in A is 53760 bytes and B is 53760 bytes
3C14.rpm UNIQUE Length in A is 53760 bytes and B is 53760 bytes
3C15.rpm UNIQUE Length in A is 53760 bytes and B is 53760 bytes
3C20.rpm UNIQUE Length in A is 53760 bytes and B is 53760 bytes
3C21.rpm UNIQUE Length in A is 53760 bytes and B is 53760 bytes
3C22.rpm UNIQUE Length in A is 53760 bytes and B is 53760 bytes
3C23.rpm UNIQUE Length in A is 53760 bytes and B is 53760 bytes
3C24.rpm UNIQUE Length in A is 53760 bytes and B is 53760 bytes
3C25.rpm UNIQUE Length in A is 53760 bytes and B is 53760 bytes
***************3D.rpm file is identical***************
***************3E.rpm file is identical***************
***************3E00.rpm file is identical***************
3E01.rpm UNIQUE Length in A is 433664 bytes and B is 433664 bytes
***************3F.rpm file is identical***************
3F00.rpm UNIQUE Length in A is 512 bytes and B is 512 bytes
3F01.rpm UNIQUE Length in A is 4096 bytes and B is 4096 bytes
3F03.rpm UNIQUE Length in A is 25600 bytes and B is 25600 bytes
3F04.rpm UNIQUE Length in A is 8704 bytes and B is 8704 bytes
3FF0.rpm UNIQUE Length in A is 2099200 bytes and B is 2099200 bytes
40.rpm UNIQUE Length in A is 258048 bytes and B is 258048 bytes
4002.rpm UNIQUE Length in A is 512 bytes and B is 512 bytes
***************41.rpm file is identical***************
411.rpm UNIQUE Length in A is 118784 bytes and B is 119296 bytes
***************42.rpm file is identical***************
***************43.rpm file is identical***************
49.rpm UNIQUE Length in A is 2048 bytes and B is 2048 bytes
4A.rpm UNIQUE Length in A is 12800 bytes and B is 12800 bytes
***************4D.rpm file is identical***************
4E.rpm UNIQUE Length in A is 337920 bytes and B is 337920 bytes
50.rpm UNIQUE Length in A is 2048 bytes and B is 2048 bytes
51.rpm UNIQUE Length in A is 2048 bytes and B is 2048 bytes
52.rpm UNIQUE Length in A is 2048 bytes and B is 2048 bytes
53.rpm UNIQUE Length in A is 2048 bytes and B is 2048 bytes
5C.rpm UNIQUE Length in A is 217088 bytes and B is 155136 bytes
***************600.rpm file is identical***************
***************601.rpm file is identical***************
***************62.rpm file is identical***************
68.rpm UNIQUE Length in A is 103424 bytes and B is 104960 bytes
69.rpm UNIQUE Length in A is 103424 bytes and B is 104960 bytes
6A.rpm UNIQUE Length in A is 103424 bytes and B is 104960 bytes
6B.rpm UNIQUE Length in A is 2560 bytes and B is 2560 bytes
***************6D.rpm file is identical***************
6E.rpm UNIQUE Length in A is 1024 bytes and B is 1024 bytes
6F.ERR UNIQUE Length in A is 2250752 bytes and B is 2250752 bytes
8000.rpm UNIQUE Length in A is 1024 bytes and B is 1024 bytes
***************8001.rpm file is identical***************
8002.rpm UNIQUE Length in A is 1024 bytes and B is 1024 bytes
8003.rpm UNIQUE Length in A is 1536 bytes and B is 2048 bytes
8004.rpm UNIQUE Length in A is 1536 bytes and B is 1536 bytes
8005.rpm UNIQUE Length in A is 1024 bytes and B is 1024 bytes
***************8006.rpm file is identical***************
***************8007.rpm file is identical***************
***************8008.rpm file is identical***************
8009.rpm UNIQUE Length in A is 1024 bytes and B is 1024 bytes
***************800A.rpm file is identical***************
800B.rpm UNIQUE Length in A is 1024 bytes and B is 1024 bytes
800C.rpm UNIQUE Length in A is 1024 bytes and B is 1024 bytes
800D.rpm UNIQUE Length in A is 2560 bytes and B is 2560 bytes
***************800E.rpm file is identical***************
800F.rpm UNIQUE Length in A is 2560 bytes and B is 2560 bytes
***************8010.rpm file is identical***************
***************8011.rpm file is identical***************
8012.rpm UNIQUE Length in A is 2560 bytes and B is 2560 bytes
***************8013.rpm file is identical***************
***************8014.rpm file is identical***************
8015.rpm UNIQUE Length in A is 1024 bytes and B is 1024 bytes
***************8016.rpm file is identical***************
8017.rpm UNIQUE Length in A is 2560 bytes and B is 2560 bytes
***************8018.rpm file is identical***************
***************8019.rpm file is identical***************
***************801A.rpm file is identical***************
***************801B.rpm file is identical***************
***************801C.rpm file is identical***************
***************801D.rpm file is identical***************
801E.rpm UNIQUE Length in A is 76288 bytes and B is 76288 bytes
***************801F.rpm file is identical***************
***************8020.rpm file is identical***************
8021.rpm UNIQUE Length in A is 1536 bytes and B is 1536 bytes
8022.rpm UNIQUE Length in A is 2560 bytes and B is 2560 bytes
8023.rpm UNIQUE Length in A is 1536 bytes and B is 1536 bytes
***************8024.rpm file is identical***************
8025.rpm UNIQUE Length in A is 1024 bytes and B is 1024 bytes
8026.rpm UNIQUE Length in A is 7680 bytes and B is 9216 bytes
***************8027.rpm file is identical***************
8028.rpm UNIQUE Length in A is 1536 bytes and B is 2048 bytes
***************8029.rpm file is identical***************
***************802A.rpm file is identical***************
***************802B.rpm file is identical***************
***************802C.rpm file is identical***************
***************802D.rpm file is identical***************
***************802E.rpm file is identical***************
***************802F.rpm file is identical***************
***************8030.rpm file is identical***************
***************8031.rpm file is identical***************
***************8032.rpm file is identical***************
***************8033.rpm file is identical***************
8034.rpm UNIQUE Length in A is 6656 bytes and B is 6656 bytes
8035.rpm UNIQUE Length in A is 8192 bytes and B is 8192 bytes
8036.rpm UNIQUE Length in A is 8192 bytes and B is 8192 bytes
***************8037.rpm file is identical***************
***************8038.rpm file is identical***************
***************8039.rpm file is identical***************
***************803A.rpm file is identical***************
***************803B.rpm file is identical***************
***************803C.rpm file is identical***************
***************803D.rpm file is identical***************
***************803E.rpm file is identical***************
***************803F.rpm file is identical***************
***************8040.rpm file is identical***************
***************8041.rpm file is identical***************
***************8042.rpm file is identical***************
8043.rpm UNIQUE Length in A is 1024 bytes and B is 1024 bytes
8044.rpm UNIQUE Length in A is 1024 bytes and B is 1024 bytes
***************8045.rpm file is identical***************
8046.rpm UNIQUE Length in A is 1024 bytes and B is 1024 bytes
***************8047.rpm file is identical***************
8048.rpm UNIQUE Length in A is 6656 bytes and B is 11264 bytes
***************8049.rpm file is identical***************
804A.rpm UNIQUE Length in A is 2560 bytes and B is 2560 bytes
804B.rpm UNIQUE Length in A is 26112 bytes and B is 31744 bytes
***************804C.rpm file is identical***************
804D.rpm UNIQUE Length in A is 6656 bytes and B is 6656 bytes
***************804E.rpm file is identical***************
***************804F.rpm file is identical***************
***************8050.rpm file is identical***************
***************8051.rpm file is identical***************
***************8052.rpm file is identical***************
***************8053.rpm file is identical***************
***************8054.rpm file is identical***************
***************8055.rpm file is identical***************
***************8056.rpm file is identical***************
***************8057.rpm file is identical***************
***************8058.rpm file is identical***************
***************8059.rpm file is identical***************
***************805A.rpm file is identical***************
***************805B.rpm file is identical***************
***************805C.rpm file is identical***************
***************805D.rpm file is identical***************
***************805E.rpm file is identical***************
***************805F.rpm file is identical***************
***************8060.rpm file is identical***************
***************8061.rpm file is identical***************
***************8062.rpm file is identical***************
***************8063.rpm file is identical***************
***************8064.rpm file is identical***************
***************8065.rpm file is identical***************
***************8066.rpm file is identical***************
***************8067.rpm file is identical***************
***************8068.rpm file is identical***************
8069.rpm UNIQUE Length in A is 12800 bytes and B is 12800 bytes
806A.rpm UNIQUE Length in A is 1536 bytes and B is 1536 bytes
806B.rpm UNIQUE Length in A is 10752 bytes and B is 10752 bytes
***************806C.rpm file is identical***************
***************806D.rpm file is identical***************
806E.rpm UNIQUE Length in A is 16896 bytes and B is 16896 bytes
***************806F.rpm file is identical***************
8074.rpm UNIQUE Length in A is 2560 bytes and B is 2560 bytes
80FC.rpm UNIQUE Length in A is 1024 bytes and B is 1024 bytes
***************80FE.rpm file is identical***************
80FF.rpm UNIQUE Length in A is 25600 bytes and B is 25600 bytes
81.rpm UNIQUE Length in A is 4608 bytes and B is 4608 bytes
***************8FFC.rpm file is identical***************
***************8FFD.rpm file is identical***************
***************8FFE.rpm file is identical***************
9A.rpm UNIQUE Length in A is 30720 bytes and B is 51200 bytes
AC55.rpm UNIQUE Length in A is 512 bytes and B is 512 bytes
B1.rpm UNIQUE Length in A is 15872 bytes and B is 15872 bytes
B2.rpm UNIQUE Length in A is 19968 bytes and B is 19968 bytes
B5.rpm UNIQUE Length in A is 1048064 bytes and B is 1048064 bytes
B6.rpm UNIQUE Length in A is 169984 bytes and B is 185856 bytes
***************B7.rpm file is identical***************
B8.rpm UNIQUE Length in A is 1024 bytes and B is 1536 bytes
B9.rpm UNIQUE Length in A is 175616 bytes and B is 193024 bytes
BA.rpm UNIQUE Length in A is 177664 bytes and B is 195072 bytes
BC.rpm UNIQUE Length in A is 171520 bytes and B is 187392 bytes
BD.rpm UNIQUE Length in A is 184320 bytes and B is 201216 bytes
BE.rpm UNIQUE Length in A is 10752 bytes and B is 10752 bytes
BF.rpm UNIQUE Length in A is 4096 bytes and B is 4096 bytes
C5.rpm UNIQUE Length in A is 397824 bytes and B is 660992 bytes
***************D000.rpm file is identical***************
***************D001.rpm file is identical***************
D002.rpm UNIQUE Length in A is 512 bytes and B is 512 bytes
D003.rpm UNIQUE Length in A is 512 bytes and B is 512 bytes
D004.rpm UNIQUE Length in A is 512 bytes and B is 512 bytes
D005.rpm UNIQUE Length in A is 512 bytes and B is 512 bytes
***************D006.rpm file is identical***************
D1.rpm UNIQUE Length in A is 190464 bytes and B is 206848 bytes
D3.rpm UNIQUE Length in A is 108544 bytes and B is 122880 bytes
D4.rpm UNIQUE Length in A is 119296 bytes and B is 133632 bytes
D5.rpm UNIQUE Length in A is 179712 bytes and B is 195072 bytes
D7.rpm UNIQUE Length in A is 169472 bytes and B is 184832 bytes
D8.rpm UNIQUE Length in A is 111616 bytes and B is 125440 bytes
DB.rpm UNIQUE Length in A is 175616 bytes and B is 191488 bytes
DC.rpm UNIQUE Length in A is 144384 bytes and B is 162304 bytes
DD.rpm UNIQUE Length in A is 168448 bytes and B is 183808 bytes
DE.rpm UNIQUE Length in A is 176128 bytes and B is 192000 bytes
DF.rpm UNIQUE Length in A is 188928 bytes and B is 205312 bytes
E0.rpm UNIQUE Length in A is 3276800 bytes and B is 3276800 bytes
E1.rpm UNIQUE Length in A is 3276800 bytes and B is 3276800 bytes
E2.rpm UNIQUE Length in A is 3276800 bytes and B is 3276800 bytes
E3.rpm UNIQUE Length in A is 3276800 bytes and B is 3276800 bytes
E4.rpm UNIQUE Length in A is 3276800 bytes and B is 3276800 bytes
E5.rpm UNIQUE Length in A is 3276800 bytes and B is 3276800 bytes
E6.rpm UNIQUE Length in A is 78336 bytes and B is 80896 bytes
E8.rpm UNIQUE Length in A is 703488 bytes and B is 703488 bytes
E9.rpm UNIQUE Length in A is 703488 bytes and B is 703488 bytes
EA.rpm UNIQUE Length in A is 703488 bytes and B is 703488 bytes
EB.rpm UNIQUE Length in A is 703488 bytes and B is 703488 bytes
EC.rpm UNIQUE Length in A is 703488 bytes and B is 703488 bytes
ED.rpm UNIQUE Length in A is 703488 bytes and B is 703488 bytes
***************EE.rpm file is identical***************
F7.rpm UNIQUE Length in A is 166400 bytes and B is 181760 bytes
***************FA.rpm file is identical***************
***************FC.rpm file is identical***************
***************FD.rpm file is identical***************
FE.rpm UNIQUE Length in A is 1024000 bytes and B is 1024000 bytes
Total files compared 479
 Post subject: Re: Mod Compare
PostPosted: May 20th, 2022, 18:55
Could you differentiate between those instances where the two files have the same size or different sizes?
PostPosted: May 20th, 2022, 19:02
no not yet, i have not plotted the offsets where they differ.
if you mean same names and different sizes then i guess thats already done
the smaller file gets compared against the bigger one.
The next agenda is
make a txt for same length files
make a txt for unique files and identical files.
This program can be used for st or wd for that matter
helps find donor modules, modules with same file sizes.
Can help compre cpy 0 with cpy 1 etc...
some fun perhaps.
PostPosted: May 21st, 2022, 14:07
Hi Simran,
Good Work how about developing a gui and adding stuff to it slowly and slowly as you need and plan to release it ,So that lots of people can use it
PostPosted: May 21st, 2022, 14:22
Instead of this ...
... I'm thinking something like this might be easier to see ...
E0.rpm UNIQUE but equal length - 3276800 bytes
PostPosted: May 21st, 2022, 17:27
Instead of this ...
sure thing. I will keep that in mind. It will require a few if and else ifs here and there.
However, i will keep proceeding with the current control flow and have it out in a few days.
I have a few more ideas about % matches for unique modules. Which will just compare how many bytes out of total bytes are the same and that should yield how close match a module is even if that is unique.
ie same_bytes/file_length_in_bytes times 100.
Well, that should be another week to incorporate.
PS: There is a fab NAND bitmap viewer coming up. I wanted to write a nand bitmap viewer and Sourcerer expanded the concept with his crazy out of the world ideas. Under his mentorship, I have really learnt quite nice things.
PostPosted: May 21st, 2022, 17:30
Amarbir[CDR-Labs] wrote:
Hi Simran,
Hi, I would love to have a GUI. However, the command line suffices and is quite lightweight for my general survival.
Nonetheless, if a GUI can be associated, it will be easier for many to accomplish. Certain GUI based tools already exist and cost about 50-60USD.
PostPosted: May 22nd, 2022, 3:09
Hi Simran,
You have that in UFS , look for option : Compare .
You can add bunch of files, work with single, make report, find special location and highlight them and may more functions.
Angel Data Recovery
PostPosted: May 22nd, 2022, 8:16
Hi Simran,
Thanks ,
I left programming years ago ,But once i step into my next boat in life i will resume it to make few interesting programs ,I miss programming
PostPosted: May 22nd, 2022, 19:35
Here is the compiled version
Make a folder with any name and copy the file in the same folder rename to modcompare.exe ; apparently its easy to fool this website to allow txt
how will one cock block txt :D , i tried rpm, bin, jpeg(pretty cool stuff, it checks dimensions of the jpeg which are held at certain offsets of a standard jpeg header i believe)
any way LOL :)
Continuing...
in the same folder make folder A and B
A contains modules of SA1,cpy1 etc what ever you like
B contains modules of SA2,cpy2 etc what ever you like
go in CMD browse to the folder you have just created
once there do dir to see if you can find 2 folders A and B ; modcompare.exe
type: modcompare A B and press enter
else, if you have not bothered to rename, type : modcompare.txt A B and it should work too.
BOOM now your computer must have just crashed..You just release a few warheads here and there... Just kidding.
I bear no responsibility for your losses You are free to use at your own risk.
If you wish you can surely do a virus scan for the exe to help with paranoia, if any.
Use it at your own risk.
Hope the program worked.....Good luck.
PS: source code needs cleanup and I am getting too lazy.... :D :)
File comment: Compiled using GCC 4.9.2
ModCompare.txt [145.08 KiB]
Downloaded 816 times
PostPosted: May 22nd, 2022, 19:40
please do report bugs and errors. The broom is ever ready to clean them.
I have tried my level best to have things compared with other utilities and match up with the results of commercial comparing utilities.
So far so good.
PostPosted: May 22nd, 2022, 20:06
kindly do check for files in A == B condition.
i think it will fail there :)
PostPosted: May 22nd, 2022, 20:15
Try this one rather.
Forgot to mention the earlier one was also 64bit compiled.
File comment: V2. A==B condition fixed.
64bit
ModCompare.txt [144.87 KiB]
Downloaded 860 times
PostPosted: May 23rd, 2022, 17:49
We got parameters!
Number of modules in A.txt is 462
Number of modules in B.txt is 465
Number_Of_Same_Files 459
01.rpm UNIQUE Length in A is 12288 bytes and B is 12288 bytes 01.rpm bytewise same by 46.52 %
02.rpm UNIQUE Length in A is 2560 bytes and B is 2560 bytes 02.rpm bytewise same by 98.83 %
03.rpm UNIQUE Length in A is 96768 bytes and B is 96768 bytes 03.rpm bytewise same by 60.23 %
04.rpm UNIQUE Length in A is 21629952 bytes and B is 21629952 bytes 04.rpm bytewise same by 77.56 %
0C.rpm UNIQUE Length in A is 6144 bytes and B is 6144 bytes 0C.rpm bytewise same by 87.03 %
1000.rpm UNIQUE Length in A is 14336 bytes and B is 14336 bytes 1000.rpm bytewise same by 60.11 %
1001.rpm UNIQUE Length in A is 12800 bytes and B is 12800 bytes 1001.rpm bytewise same by 56.37 %
1002.rpm UNIQUE Length in A is 18432 bytes and B is 18432 bytes 1002.rpm bytewise same by 65.44 %
1003.rpm UNIQUE Length in A is 16896 bytes and B is 16896 bytes 1003.rpm bytewise same by 43.03 %
1004.rpm UNIQUE Length in A is 20992 bytes and B is 20992 bytes 1004.rpm bytewise same by 29.61 %
1005.rpm UNIQUE Length in A is 15872 bytes and B is 15872 bytes 1005.rpm bytewise same by 63.17 %
1007.rpm UNIQUE Length in A is 12800 bytes and B is 12800 bytes 1007.rpm bytewise same by 56.45 %
1008.rpm UNIQUE Length in A is 17920 bytes and B is 17920 bytes 1008.rpm bytewise same by 35.96 %
1009.rpm UNIQUE Length in A is 16896 bytes and B is 16896 bytes 1009.rpm bytewise same by 66.26 %
100A.rpm UNIQUE Length in A is 18944 bytes and B is 18944 bytes 100A.rpm bytewise same by 23.36 %
100B.rpm UNIQUE Length in A is 11776 bytes and B is 11776 bytes 100B.rpm bytewise same by 52.96 %
100C.rpm UNIQUE Length in A is 13312 bytes and B is 13312 bytes 100C.rpm bytewise same by 57.49 %
100E.rpm UNIQUE Length in A is 11776 bytes and B is 11776 bytes 100E.rpm bytewise same by 52.87 %
100F.rpm UNIQUE Length in A is 14848 bytes and B is 14848 bytes 100F.rpm bytewise same by 60.93 %
1010.rpm UNIQUE Length in A is 11776 bytes and B is 11776 bytes 1010.rpm bytewise same by 52.65 %
1011.rpm UNIQUE Length in A is 19456 bytes and B is 19456 bytes 1011.rpm bytewise same by 35.89 %
102.rpm bytewise same by 100.00 %
103.rpm bytewise same by 100.00 %
104.rpm bytewise same by 100.00 %
105.rpm bytewise same by 100.00 %
106.rpm bytewise same by 100.00 %
108.rpm UNIQUE Length in A is 18944 bytes and B is 18944 bytes 108.rpm bytewise same by 99.99 %
109.rpm UNIQUE Length in A is 524800 bytes and B is 524800 bytes 109.rpm bytewise same by 53.61 %
11.rpm UNIQUE Length in A is 661504 bytes and B is 663040 bytes 11.rpm bytewise same by 16.43 %
1100.rpm UNIQUE Length in A is 8192 bytes and B is 8192 bytes 1100.rpm bytewise same by 90.60 %
1101.rpm UNIQUE Length in A is 65536 bytes and B is 65536 bytes 1101.rpm bytewise same by 99.98 %
1102.rpm bytewise same by 100.00 %
1104.rpm UNIQUE Length in A is 65536 bytes and B is 65536 bytes 1104.rpm bytewise same by 97.00 %
1105.rpm bytewise same by 100.00 %
1106.rpm bytewise same by 100.00 %
1121.rpm UNIQUE Length in A is 65536 bytes and B is 65536 bytes 1121.rpm bytewise same by 98.95 %
115.rpm UNIQUE Length in A is 205824 bytes and B is 221184 bytes 115.rpm bytewise same by 14.52 %
116.rpm UNIQUE Length in A is 3072 bytes and B is 3072 bytes 116.rpm bytewise same by 99.97 %
118.rpm UNIQUE Length in A is 16896 bytes and B is 16896 bytes 118.rpm bytewise same by 99.99 %
119.rpm UNIQUE Length in A is 2560 bytes and B is 2560 bytes 119.rpm bytewise same by 99.88 %
120.rpm UNIQUE Length in A is 537088 bytes and B is 537088 bytes 120.rpm bytewise same by 0.47 %
120F.rpm UNIQUE Length in A is 8704 bytes and B is 8704 bytes 120F.rpm bytewise same by 95.06 %
121.rpm bytewise same by 100.00 %
121F.rpm UNIQUE Length in A is 8192 bytes and B is 8192 bytes 121F.rpm bytewise same by 99.96 %
122.rpm bytewise same by 100.00 %
123.rpm UNIQUE Length in A is 512 bytes and B is 512 bytes 123.rpm bytewise same by 99.80 %
124.rpm UNIQUE Length in A is 512 bytes and B is 512 bytes 124.rpm bytewise same by 99.80 %
125.rpm UNIQUE Length in A is 512 bytes and B is 512 bytes 125.rpm bytewise same by 99.80 %
126.rpm UNIQUE Length in A is 512 bytes and B is 512 bytes 126.rpm bytewise same by 99.80 %
127.rpm bytewise same by 100.00 %
128.rpm bytewise same by 100.00 %
12A.rpm bytewise same by 100.00 %
12D.rpm UNIQUE Length in A is 153600 bytes and B is 153600 bytes 12D.rpm bytewise same by 47.10 %
131.rpm UNIQUE Length in A is 257536 bytes and B is 257536 bytes 131.rpm bytewise same by 70.51 %
132.rpm UNIQUE Length in A is 32768 bytes and B is 32768 bytes 132.rpm bytewise same by 99.86 %
13F5.rpm UNIQUE Length in A is 13312 bytes and B is 13312 bytes 13F5.rpm bytewise same by 83.50 %
1410.rpm UNIQUE Length in A is 8704 bytes and B is 8704 bytes 1410.rpm bytewise same by 13.04 %
148.rpm UNIQUE Length in A is 1024 bytes and B is 1024 bytes 148.rpm bytewise same by 94.92 %
149.rpm UNIQUE Length in A is 130560 bytes and B is 130560 bytes 149.rpm bytewise same by 77.13 %
14A.rpm UNIQUE Length in A is 108544 bytes and B is 108544 bytes 14A.rpm bytewise same by 99.60 %
1530.rpm UNIQUE Length in A is 2048 bytes and B is 2048 bytes 1530.rpm bytewise same by 63.09 %
1531.rpm bytewise same by 100.00 %
16F.rpm UNIQUE Length in A is 1536 bytes and B is 1536 bytes 16F.rpm bytewise same by 96.29 %
1800.rpm UNIQUE Length in A is 10752 bytes and B is 10752 bytes 1800.rpm bytewise same by 70.43 %
1801.rpm UNIQUE Length in A is 10752 bytes and B is 10752 bytes 1801.rpm bytewise same by 70.90 %
1802.rpm UNIQUE Length in A is 10752 bytes and B is 10752 bytes 1802.rpm bytewise same by 70.62 %
1803.rpm UNIQUE Length in A is 10752 bytes and B is 10752 bytes 1803.rpm bytewise same by 70.07 %
1804.rpm UNIQUE Length in A is 10752 bytes and B is 10752 bytes 1804.rpm bytewise same by 70.94 %
1900.rpm UNIQUE Length in A is 16384 bytes and B is 16384 bytes 1900.rpm bytewise same by 84.19 %
1901.rpm UNIQUE Length in A is 16384 bytes and B is 16384 bytes 1901.rpm bytewise same by 89.62 %
21.rpm UNIQUE Length in A is 87552 bytes and B is 87552 bytes 21.rpm bytewise same by 95.80 %
22D.rpm UNIQUE Length in A is 19456 bytes and B is 19456 bytes 22D.rpm bytewise same by 30.44 %
***************23.rpm file is identical***************
23.rpm bytewise same by 100.00 %
24.rpm UNIQUE Length in A is 87552 bytes and B is 87552 bytes 24.rpm bytewise same by 96.00 %
2401.rpm UNIQUE Length in A is 247808 bytes and B is 258048 bytes 2401.rpm bytewise same by 10.89 %
2403.rpm UNIQUE Length in A is 188416 bytes and B is 195072 bytes 2403.rpm bytewise same by 18.04 %
2404.rpm UNIQUE Length in A is 169472 bytes and B is 171520 bytes 2404.rpm bytewise same by 22.25 %
2407.rpm UNIQUE Length in A is 229376 bytes and B is 244736 bytes 2407.rpm bytewise same by 11.03 %
2408.rpm UNIQUE Length in A is 178688 bytes and B is 181248 bytes 2408.rpm bytewise same by 19.52 %
2409.rpm UNIQUE Length in A is 203264 bytes and B is 218624 bytes 2409.rpm bytewise same by 10.36 %
240A.rpm UNIQUE Length in A is 146432 bytes and B is 158208 bytes 240A.rpm bytewise same by 12.62 %
240B.rpm UNIQUE Length in A is 135168 bytes and B is 146432 bytes 240B.rpm bytewise same by 17.66 %
240C.rpm UNIQUE Length in A is 167936 bytes and B is 180736 bytes 240C.rpm bytewise same by 11.57 %
240E.rpm UNIQUE Length in A is 170496 bytes and B is 184832 bytes 240E.rpm bytewise same by 12.44 %
2410.rpm UNIQUE Length in A is 129024 bytes and B is 133120 bytes 2410.rpm bytewise same by 23.62 %
2413.rpm UNIQUE Length in A is 136192 bytes and B is 145408 bytes 2413.rpm bytewise same by 12.50 %
2414.rpm UNIQUE Length in A is 176128 bytes and B is 194560 bytes 2414.rpm bytewise same by 14.46 %
2415.rpm UNIQUE Length in A is 129536 bytes and B is 140800 bytes 2415.rpm bytewise same by 18.44 %
241A.rpm UNIQUE Length in A is 156672 bytes and B is 167936 bytes 241A.rpm bytewise same by 17.62 %
241D.rpm UNIQUE Length in A is 151040 bytes and B is 164864 bytes 241D.rpm bytewise same by 12.14 %
241E.rpm UNIQUE Length in A is 161280 bytes and B is 172544 bytes 241E.rpm bytewise same by 12.28 %
241F.rpm UNIQUE Length in A is 164352 bytes and B is 174592 bytes 241F.rpm bytewise same by 18.01 %
2420.rpm UNIQUE Length in A is 303104 bytes and B is 315392 bytes 2420.rpm bytewise same by 12.88 %
2422.rpm UNIQUE Length in A is 163328 bytes and B is 172544 bytes 2422.rpm bytewise same by 18.18 %
2423.rpm UNIQUE Length in A is 79360 bytes and B is 82944 bytes 2423.rpm bytewise same by 20.87 %
2424.rpm UNIQUE Length in A is 157184 bytes and B is 172032 bytes 2424.rpm bytewise same by 15.99 %
2427.rpm UNIQUE Length in A is 125952 bytes and B is 141824 bytes 2427.rpm bytewise same by 17.30 %
2429.rpm UNIQUE Length in A is 164352 bytes and B is 175616 bytes 2429.rpm bytewise same by 12.38 %
25.rpm UNIQUE Length in A is 131584 bytes and B is 131584 bytes 25.rpm bytewise same by 99.99 %
2503.rpm UNIQUE Length in A is 283648 bytes and B is 290816 bytes 2503.rpm bytewise same by 95.85 %
2504.rpm UNIQUE Length in A is 2048 bytes and B is 3072 bytes 2504.rpm bytewise same by 98.14 %
2507.rpm UNIQUE Length in A is 472576 bytes and B is 257024 bytes 2507.rpm bytewise same by 21.81 %
2509.rpm UNIQUE Length in A is 222720 bytes and B is 5120 bytes 2509.rpm bytewise same by 76.76 %
250A.rpm UNIQUE Length in A is 79360 bytes and B is 113152 bytes 250A.rpm bytewise same by 91.86 %
250B.rpm UNIQUE Length in A is 84480 bytes and B is 118784 bytes 250B.rpm bytewise same by 93.41 %
250C.rpm UNIQUE Length in A is 1823232 bytes and B is 1831424 bytes 250C.rpm bytewise same by 96.32 %
250E.rpm UNIQUE Length in A is 94720 bytes and B is 147968 bytes 250E.rpm bytewise same by 72.22 %
2513.rpm UNIQUE Length in A is 28672 bytes and B is 69632 bytes 2513.rpm bytewise same by 99.22 %
2514.rpm UNIQUE Length in A is 469504 bytes and B is 809984 bytes 2514.rpm bytewise same by 88.10 %
251D.rpm UNIQUE Length in A is 117248 bytes and B is 167936 bytes 251D.rpm bytewise same by 96.22 %
251E.rpm UNIQUE Length in A is 279552 bytes and B is 320512 bytes 251E.rpm bytewise same by 55.25 %
2520.rpm UNIQUE Length in A is 3072000 bytes and B is 3072000 bytes 2520.rpm bytewise same by 93.68 %
2522.rpm UNIQUE Length in A is 167424 bytes and B is 208384 bytes 2522.rpm bytewise same by 96.37 %
2529.rpm UNIQUE Length in A is 819712 bytes and B is 833024 bytes 2529.rpm bytewise same by 97.39 %
26.rpm UNIQUE Length in A is 66048 bytes and B is 66048 bytes 26.rpm bytewise same by 100.00 %
2640.rpm UNIQUE Length in A is 15872 bytes and B is 17920 bytes 2640.rpm bytewise same by 61.78 %
2641.rpm UNIQUE Length in A is 15872 bytes and B is 17920 bytes 2641.rpm bytewise same by 60.65 %
2642.rpm UNIQUE Length in A is 15872 bytes and B is 17920 bytes 2642.rpm bytewise same by 60.98 %
2643.rpm UNIQUE Length in A is 15872 bytes and B is 17920 bytes 2643.rpm bytewise same by 60.53 %
2644.rpm UNIQUE Length in A is 15872 bytes and B is 17920 bytes 2644.rpm bytewise same by 60.62 %
2645.rpm UNIQUE Length in A is 15872 bytes and B is 17920 bytes 2645.rpm bytewise same by 58.07 %
2670.rpm UNIQUE Length in A is 179712 bytes and B is 231936 bytes 2670.rpm bytewise same by 28.18 %
2671.rpm UNIQUE Length in A is 179712 bytes and B is 232448 bytes 2671.rpm bytewise same by 29.59 %
2672.rpm UNIQUE Length in A is 180224 bytes and B is 231936 bytes 2672.rpm bytewise same by 31.31 %
2673.rpm UNIQUE Length in A is 180224 bytes and B is 231424 bytes 2673.rpm bytewise same by 29.97 %
2674.rpm UNIQUE Length in A is 179200 bytes and B is 231936 bytes 2674.rpm bytewise same by 27.24 %
2675.rpm UNIQUE Length in A is 180224 bytes and B is 231424 bytes 2675.rpm bytewise same by 28.22 %
2690.rpm UNIQUE Length in A is 71680 bytes and B is 59392 bytes 2690.rpm bytewise same by 43.52 %
2691.rpm UNIQUE Length in A is 71680 bytes and B is 51712 bytes 2691.rpm bytewise same by 46.22 %
2692.rpm UNIQUE Length in A is 71680 bytes and B is 51712 bytes 2692.rpm bytewise same by 46.41 %
2693.rpm UNIQUE Length in A is 74240 bytes and B is 51712 bytes 2693.rpm bytewise same by 45.61 %
2694.rpm UNIQUE Length in A is 71680 bytes and B is 51712 bytes 2694.rpm bytewise same by 46.14 %
2695.rpm UNIQUE Length in A is 71680 bytes and B is 51712 bytes 2695.rpm bytewise same by 46.26 %
26D0.rpm UNIQUE Length in A is 304128 bytes and B is 665600 bytes 26D0.rpm bytewise same by 28.74 %
26D1.rpm UNIQUE Length in A is 384000 bytes and B is 339968 bytes 26D1.rpm bytewise same by 27.67 %
26D2.rpm UNIQUE Length in A is 449536 bytes and B is 695296 bytes 26D2.rpm bytewise same by 27.74 %
26D3.rpm UNIQUE Length in A is 310784 bytes and B is 540160 bytes 26D3.rpm bytewise same by 27.66 %
26D4.rpm UNIQUE Length in A is 423936 bytes and B is 676352 bytes 26D4.rpm bytewise same by 27.47 %
26D5.rpm UNIQUE Length in A is 442880 bytes and B is 550912 bytes 26D5.rpm bytewise same by 27.71 %
26E0.rpm UNIQUE Length in A is 1536 bytes and B is 2560 bytes 26E0.rpm bytewise same by 88.87 %
26E1.rpm UNIQUE Length in A is 1536 bytes and B is 2560 bytes 26E1.rpm bytewise same by 88.48 %
26E2.rpm UNIQUE Length in A is 1536 bytes and B is 2560 bytes 26E2.rpm bytewise same by 88.80 %
26E3.rpm UNIQUE Length in A is 1536 bytes and B is 2560 bytes 26E3.rpm bytewise same by 88.61 %
26E4.rpm UNIQUE Length in A is 1536 bytes and B is 2560 bytes 26E4.rpm bytewise same by 88.67 %
26E5.rpm UNIQUE Length in A is 1536 bytes and B is 2560 bytes 26E5.rpm bytewise same by 88.74 %
29.rpm bytewise same by 100.00 %
2A.rpm UNIQUE Length in A is 5632 bytes and B is 5632 bytes 2A.rpm bytewise same by 99.98 %
2D.rpm UNIQUE Length in A is 409600 bytes and B is 409600 bytes 2D.rpm bytewise same by 67.95 %
2D03.rpm UNIQUE Length in A is 1024000 bytes and B is 1024000 bytes 2D03.rpm bytewise same by 99.51 %
2D04.rpm UNIQUE Length in A is 1024000 bytes and B is 1024000 bytes 2D04.rpm bytewise same by 98.41 %
2D07.rpm UNIQUE Length in A is 1024000 bytes and B is 1024000 bytes 2D07.rpm bytewise same by 95.26 %
2D09.rpm UNIQUE Length in A is 1024000 bytes and B is 1024000 bytes 2D09.rpm bytewise same by 98.91 %
2D0A.rpm UNIQUE Length in A is 1024000 bytes and B is 1024000 bytes 2D0A.rpm bytewise same by 99.51 %
2D0B.rpm UNIQUE Length in A is 1024000 bytes and B is 1024000 bytes 2D0B.rpm bytewise same by 99.61 %
2D0C.rpm UNIQUE Length in A is 1024000 bytes and B is 1024000 bytes 2D0C.rpm bytewise same by 99.58 %
2D0E.rpm UNIQUE Length in A is 1024000 bytes and B is 1024000 bytes 2D0E.rpm bytewise same by 98.89 %
2D13.rpm UNIQUE Length in A is 1024000 bytes and B is 1024000 bytes 2D13.rpm bytewise same by 99.89 %
2D14.rpm UNIQUE Length in A is 1024000 bytes and B is 1024000 bytes 2D14.rpm bytewise same by 99.13 %
2D1D.rpm UNIQUE Length in A is 1024000 bytes and B is 1024000 bytes 2D1D.rpm bytewise same by 98.90 %
2D1E.rpm UNIQUE Length in A is 1024000 bytes and B is 1024000 bytes 2D1E.rpm bytewise same by 99.64 %
2D20.rpm UNIQUE Length in A is 1024000 bytes and B is 1024000 bytes 2D20.rpm bytewise same by 84.30 %
2D22.rpm UNIQUE Length in A is 1024000 bytes and B is 1024000 bytes 2D22.rpm bytewise same by 99.52 %
2D29.rpm UNIQUE Length in A is 1024000 bytes and B is 1024000 bytes 2D29.rpm bytewise same by 99.55 %
2E.rpm UNIQUE Length in A is 409600 bytes and B is 409600 bytes 2E.rpm bytewise same by 68.93 %
2E00.rpm UNIQUE Length in A is 1024 bytes and B is 1024 bytes 2E00.rpm bytewise same by 94.43 %
2F.rpm UNIQUE Length in A is 2560 bytes and B is 2560 bytes 2F.rpm bytewise same by 99.65 %
2FF0.rpm UNIQUE Length in A is 1347584 bytes and B is 1410048 bytes 2FF0.rpm bytewise same by 89.22 %
31.rpm UNIQUE Length in A is 1377280 bytes and B is 1377280 bytes 31.rpm bytewise same by 96.15 %
32.rpm UNIQUE Length in A is 30720 bytes and B is 30720 bytes 32.rpm bytewise same by 99.50 %
33.rpm UNIQUE Length in A is 2099200 bytes and B is 2099200 bytes 33.rpm bytewise same by 96.92 %
3300.rpm UNIQUE Length in A is 117760 bytes and B is 118272 bytes 3300.rpm bytewise same by 15.50 %
3301.rpm UNIQUE Length in A is 135680 bytes and B is 136192 bytes 3301.rpm bytewise same by 8.72 %
3302.rpm UNIQUE Length in A is 137216 bytes and B is 137216 bytes 3302.rpm bytewise same by 14.05 %
3303.rpm UNIQUE Length in A is 105984 bytes and B is 106496 bytes 3303.rpm bytewise same by 15.68 %
3304.rpm UNIQUE Length in A is 119296 bytes and B is 119808 bytes 3304.rpm bytewise same by 15.00 %
3305.rpm UNIQUE Length in A is 112640 bytes and B is 112640 bytes 3305.rpm bytewise same by 15.62 %
3307.rpm UNIQUE Length in A is 138240 bytes and B is 138752 bytes 3307.rpm bytewise same by 7.43 %
3309.rpm UNIQUE Length in A is 111104 bytes and B is 111616 bytes 3309.rpm bytewise same by 7.89 %
3310.rpm UNIQUE Length in A is 109056 bytes and B is 109568 bytes 3310.rpm bytewise same by 7.75 %
3311.rpm UNIQUE Length in A is 105984 bytes and B is 105984 bytes 3311.rpm bytewise same by 15.91 %
3312.rpm UNIQUE Length in A is 105984 bytes and B is 105984 bytes 3312.rpm bytewise same by 16.09 %
34.rpm bytewise same by 100.00 %
3400.rpm UNIQUE Length in A is 170496 bytes and B is 172544 bytes 3400.rpm bytewise same by 5.19 %
3401.rpm UNIQUE Length in A is 161792 bytes and B is 163328 bytes 3401.rpm bytewise same by 5.43 %
3402.rpm UNIQUE Length in A is 165888 bytes and B is 166400 bytes 3402.rpm bytewise same by 5.47 %
3405.rpm UNIQUE Length in A is 164864 bytes and B is 166912 bytes 3405.rpm bytewise same by 5.26 %
3406.rpm UNIQUE Length in A is 162816 bytes and B is 164864 bytes 3406.rpm bytewise same by 5.38 %
3407.rpm UNIQUE Length in A is 163328 bytes and B is 165376 bytes 3407.rpm bytewise same by 5.40 %
3408.rpm UNIQUE Length in A is 163328 bytes and B is 163840 bytes 3408.rpm bytewise same by 5.33 %
3411.rpm UNIQUE Length in A is 105472 bytes and B is 105472 bytes 3411.rpm bytewise same by 16.15 %
3413.rpm UNIQUE Length in A is 168448 bytes and B is 170496 bytes 3413.rpm bytewise same by 5.08 %
3414.rpm UNIQUE Length in A is 107008 bytes and B is 107520 bytes 3414.rpm bytewise same by 16.07 %
3416.rpm UNIQUE Length in A is 115200 bytes and B is 115200 bytes 3416.rpm bytewise same by 15.11 %
3417.rpm UNIQUE Length in A is 166400 bytes and B is 167936 bytes 3417.rpm bytewise same by 5.38 %
3421.rpm UNIQUE Length in A is 166400 bytes and B is 167424 bytes 3421.rpm bytewise same by 5.22 %
3422.rpm UNIQUE Length in A is 128512 bytes and B is 129536 bytes 3422.rpm bytewise same by 5.46 %
3423.rpm UNIQUE Length in A is 125952 bytes and B is 126464 bytes 3423.rpm bytewise same by 14.77 %
3424.rpm UNIQUE Length in A is 123392 bytes and B is 124416 bytes 3424.rpm bytewise same by 15.38 %
3425.rpm UNIQUE Length in A is 129536 bytes and B is 130048 bytes 3425.rpm bytewise same by 14.55 %
3426.rpm UNIQUE Length in A is 128512 bytes and B is 129024 bytes 3426.rpm bytewise same by 16.21 %
3429.rpm UNIQUE Length in A is 105984 bytes and B is 106496 bytes 3429.rpm bytewise same by 16.11 %
3430.rpm UNIQUE Length in A is 168448 bytes and B is 170496 bytes 3430.rpm bytewise same by 5.31 %
3431.rpm UNIQUE Length in A is 170496 bytes and B is 172032 bytes 3431.rpm bytewise same by 5.40 %
34D1.rpm UNIQUE Length in A is 193536 bytes and B is 194048 bytes 34D1.rpm bytewise same by 5.13 %
34D2.rpm UNIQUE Length in A is 198656 bytes and B is 199168 bytes 34D2.rpm bytewise same by 5.25 %
34D3.rpm UNIQUE Length in A is 199680 bytes and B is 200192 bytes 34D3.rpm bytewise same by 5.02 %
34D4.rpm UNIQUE Length in A is 203776 bytes and B is 204800 bytes 34D4.rpm bytewise same by 4.97 %
34D5.rpm UNIQUE Length in A is 178688 bytes and B is 179200 bytes 34D5.rpm bytewise same by 5.48 %
34D6.rpm UNIQUE Length in A is 206848 bytes and B is 207872 bytes 34D6.rpm bytewise same by 4.91 %
34D7.rpm UNIQUE Length in A is 206336 bytes and B is 207360 bytes 34D7.rpm bytewise same by 5.01 %
34D8.rpm UNIQUE Length in A is 113152 bytes and B is 113664 bytes 34D8.rpm bytewise same by 16.27 %
34E7.rpm UNIQUE Length in A is 16384 bytes and B is 16384 bytes 34E7.rpm bytewise same by 99.98 %
35.rpm UNIQUE Length in A is 5120 bytes and B is 5120 bytes 35.rpm bytewise same by 99.51 %
3500.rpm UNIQUE Length in A is 162816 bytes and B is 164864 bytes 3500.rpm bytewise same by 5.29 %
3501.rpm UNIQUE Length in A is 165888 bytes and B is 167424 bytes 3501.rpm bytewise same by 5.22 %
3502.rpm UNIQUE Length in A is 162304 bytes and B is 164352 bytes 3502.rpm bytewise same by 5.30 %
3503.rpm UNIQUE Length in A is 162304 bytes and B is 164352 bytes 3503.rpm bytewise same by 5.36 %
3504.rpm UNIQUE Length in A is 167424 bytes and B is 169984 bytes 3504.rpm bytewise same by 5.00 %
3511.rpm UNIQUE Length in A is 105472 bytes and B is 105984 bytes 3511.rpm bytewise same by 15.95 %
3513.rpm UNIQUE Length in A is 195072 bytes and B is 195584 bytes 3513.rpm bytewise same by 5.07 %
3514.rpm UNIQUE Length in A is 201216 bytes and B is 202752 bytes 3514.rpm bytewise same by 5.01 %
3551.rpm UNIQUE Length in A is 115712 bytes and B is 116224 bytes 3551.rpm bytewise same by 8.03 %
36.rpm UNIQUE Length in A is 7168 bytes and B is 7168 bytes 36.rpm bytewise same by 87.00 %
360.rpm UNIQUE Length in A is 524800 bytes and B is 524800 bytes 360.rpm bytewise same by 85.90 %
3604.rpm UNIQUE Length in A is 8192 bytes and B is 8192 bytes 3604.rpm bytewise same by 97.72 %
3605.rpm UNIQUE Length in A is 104448 bytes and B is 104960 bytes 3605.rpm bytewise same by 16.37 %
37.rpm bytewise same by 100.00 %
3700.rpm UNIQUE Length in A is 163328 bytes and B is 164352 bytes 3700.rpm bytewise same by 5.28 %
38.rpm UNIQUE Length in A is 131584 bytes and B is 131584 bytes 38.rpm bytewise same by 99.99 %
3801.rpm UNIQUE Length in A is 17920 bytes and B is 17920 bytes 3801.rpm bytewise same by 99.93 %
3802.rpm UNIQUE Length in A is 1024 bytes and B is 1024 bytes 3802.rpm bytewise same by 99.71 %
3803.rpm bytewise same by 100.00 %
39.rpm UNIQUE Length in A is 8704 bytes and B is 8704 bytes 39.rpm bytewise same by 99.99 %
3A.rpm UNIQUE Length in A is 6144 bytes and B is 6144 bytes 3A.rpm bytewise same by 86.23 %
3B.rpm bytewise same by 100.00 %
3C.rpm bytewise same by 100.00 %
3C00.rpm bytewise same by 100.00 %
3C10.rpm UNIQUE Length in A is 53760 bytes and B is 53760 bytes 3C10.rpm bytewise same by 99.77 %
3C11.rpm UNIQUE Length in A is 53760 bytes and B is 53760 bytes 3C11.rpm bytewise same by 99.96 %
3C12.rpm UNIQUE Length in A is 53760 bytes and B is 53760 bytes 3C12.rpm bytewise same by 99.30 %
3C13.rpm UNIQUE Length in A is 53760 bytes and B is 53760 bytes 3C13.rpm bytewise same by 99.67 %
3C14.rpm UNIQUE Length in A is 53760 bytes and B is 53760 bytes 3C14.rpm bytewise same by 99.58 %
3C15.rpm UNIQUE Length in A is 53760 bytes and B is 53760 bytes 3C15.rpm bytewise same by 99.22 %
3C20.rpm UNIQUE Length in A is 53760 bytes and B is 53760 bytes 3C20.rpm bytewise same by 99.72 %
3C21.rpm UNIQUE Length in A is 53760 bytes and B is 53760 bytes 3C21.rpm bytewise same by 99.82 %
3C22.rpm UNIQUE Length in A is 53760 bytes and B is 53760 bytes 3C22.rpm bytewise same by 99.14 %
3C23.rpm UNIQUE Length in A is 53760 bytes and B is 53760 bytes 3C23.rpm bytewise same by 99.59 %
3C24.rpm UNIQUE Length in A is 53760 bytes and B is 53760 bytes 3C24.rpm bytewise same by 98.61 %
3C25.rpm UNIQUE Length in A is 53760 bytes and B is 53760 bytes 3C25.rpm bytewise same by 99.02 %
3D.rpm bytewise same by 100.00 %
3E.rpm bytewise same by 100.00 %
3E00.rpm bytewise same by 100.00 %
3E01.rpm UNIQUE Length in A is 433664 bytes and B is 433664 bytes 3E01.rpm bytewise same by 90.44 %
3F.rpm bytewise same by 100.00 %
3F00.rpm UNIQUE Length in A is 512 bytes and B is 512 bytes 3F00.rpm bytewise same by 99.41 %
3F01.rpm UNIQUE Length in A is 4096 bytes and B is 4096 bytes 3F01.rpm bytewise same by 99.93 %
3F03.rpm UNIQUE Length in A is 25600 bytes and B is 25600 bytes 3F03.rpm bytewise same by 99.94 %
3F04.rpm UNIQUE Length in A is 8704 bytes and B is 8704 bytes 3F04.rpm bytewise same by 99.84 %
3FF0.rpm UNIQUE Length in A is 2099200 bytes and B is 2099200 bytes 3FF0.rpm bytewise same by 98.85 %
40.rpm UNIQUE Length in A is 257536 bytes and B is 257536 bytes 40.rpm bytewise same by 70.51 %
4002.rpm UNIQUE Length in A is 512 bytes and B is 512 bytes 4002.rpm bytewise same by 96.48 %
41.rpm bytewise same by 100.00 %
411.rpm UNIQUE Length in A is 117760 bytes and B is 117760 bytes 411.rpm bytewise same by 98.05 %
42.rpm bytewise same by 100.00 %
43.rpm bytewise same by 100.00 %
49.rpm UNIQUE Length in A is 2048 bytes and B is 2048 bytes 49.rpm bytewise same by 85.45 %
4A.rpm UNIQUE Length in A is 12800 bytes and B is 12800 bytes 4A.rpm bytewise same by 33.09 %
4D.rpm bytewise same by 100.00 %
4E.rpm UNIQUE Length in A is 492544 bytes and B is 492544 bytes 4E.rpm bytewise same by 100.00 %
50.rpm UNIQUE Length in A is 2048 bytes and B is 2048 bytes 50.rpm bytewise same by 99.32 %
51.rpm UNIQUE Length in A is 2048 bytes and B is 2048 bytes 51.rpm bytewise same by 99.32 %
52.rpm UNIQUE Length in A is 2048 bytes and B is 2048 bytes 52.rpm bytewise same by 99.32 %
53.rpm UNIQUE Length in A is 2048 bytes and B is 2048 bytes 53.rpm bytewise same by 99.32 %
5C.rpm UNIQUE Length in A is 211456 bytes and B is 211968 bytes 5C.rpm bytewise same by 8.31 %
600.rpm bytewise same by 100.00 %
601.rpm bytewise same by 100.00 %
62.rpm bytewise same by 100.00 %
68.rpm UNIQUE Length in A is 87552 bytes and B is 87552 bytes 68.rpm bytewise same by 99.02 %
***************69.rpm file is identical***************
69.rpm bytewise same by 100.00 %
***************6A.rpm file is identical***************
6A.rpm bytewise same by 100.00 %
6B.rpm UNIQUE Length in A is 2560 bytes and B is 2560 bytes 6B.rpm bytewise same by 99.96 %
6D.rpm bytewise same by 100.00 %
6E.rpm UNIQUE Length in A is 1024 bytes and B is 1024 bytes 6E.rpm bytewise same by 95.80 %
8000.rpm UNIQUE Length in A is 1024 bytes and B is 1024 bytes 8000.rpm bytewise same by 93.55 %
8001.rpm bytewise same by 100.00 %
8002.rpm UNIQUE Length in A is 1024 bytes and B is 1024 bytes 8002.rpm bytewise same by 94.53 %
8003.rpm UNIQUE Length in A is 1536 bytes and B is 1536 bytes 8003.rpm bytewise same by 87.70 %
8004.rpm UNIQUE Length in A is 1536 bytes and B is 1536 bytes 8004.rpm bytewise same by 91.93 %
8005.rpm UNIQUE Length in A is 1024 bytes and B is 1024 bytes 8005.rpm bytewise same by 95.61 %
8006.rpm UNIQUE Length in A is 1024 bytes and B is 1024 bytes 8006.rpm bytewise same by 99.02 %
8007.rpm bytewise same by 100.00 %
8008.rpm bytewise same by 100.00 %
8009.rpm UNIQUE Length in A is 1024 bytes and B is 1024 bytes 8009.rpm bytewise same by 99.22 %
800A.rpm UNIQUE Length in A is 1024 bytes and B is 1024 bytes 800A.rpm bytewise same by 99.22 %
800B.rpm UNIQUE Length in A is 1024 bytes and B is 1024 bytes 800B.rpm bytewise same by 94.53 %
800C.rpm UNIQUE Length in A is 1024 bytes and B is 1024 bytes 800C.rpm bytewise same by 98.83 %
800D.rpm UNIQUE Length in A is 2560 bytes and B is 2560 bytes 800D.rpm bytewise same by 97.77 %
800E.rpm bytewise same by 100.00 %
800F.rpm UNIQUE Length in A is 2560 bytes and B is 2560 bytes 800F.rpm bytewise same by 96.41 %
8010.rpm bytewise same by 100.00 %
8011.rpm bytewise same by 100.00 %
8012.rpm UNIQUE Length in A is 2560 bytes and B is 2560 bytes 8012.rpm bytewise same by 88.95 %
8013.rpm bytewise same by 100.00 %
8014.rpm bytewise same by 100.00 %
8015.rpm UNIQUE Length in A is 1024 bytes and B is 1024 bytes 8015.rpm bytewise same by 99.22 %
8016.rpm bytewise same by 100.00 %
8017.rpm UNIQUE Length in A is 2560 bytes and B is 2560 bytes 8017.rpm bytewise same by 94.96 %
8018.rpm bytewise same by 100.00 %
8019.rpm bytewise same by 100.00 %
801A.rpm UNIQUE Length in A is 2560 bytes and B is 2560 bytes 801A.rpm bytewise same by 98.24 %
801B.rpm bytewise same by 100.00 %
801C.rpm bytewise same by 100.00 %
801D.rpm bytewise same by 100.00 %
801E.rpm UNIQUE Length in A is 62976 bytes and B is 51712 bytes 801E.rpm bytewise same by 37.55 %
801F.rpm bytewise same by 100.00 %
8020.rpm bytewise same by 100.00 %
8021.rpm UNIQUE Length in A is 1536 bytes and B is 1536 bytes 8021.rpm bytewise same by 92.97 %
8022.rpm UNIQUE Length in A is 2560 bytes and B is 2560 bytes 8022.rpm bytewise same by 99.61 %
8023.rpm UNIQUE Length in A is 1536 bytes and B is 1536 bytes 8023.rpm bytewise same by 99.48 %
8024.rpm bytewise same by 100.00 %
8025.rpm UNIQUE Length in A is 1024 bytes and B is 1024 bytes 8025.rpm bytewise same by 99.22 %
8026.rpm UNIQUE Length in A is 6656 bytes and B is 6656 bytes 8026.rpm bytewise same by 73.38 %
8027.rpm bytewise same by 100.00 %
8028.rpm UNIQUE Length in A is 1536 bytes and B is 1536 bytes 8028.rpm bytewise same by 87.70 %
8029.rpm bytewise same by 100.00 %
802A.rpm bytewise same by 100.00 %
802B.rpm bytewise same by 100.00 %
802C.rpm bytewise same by 100.00 %
802D.rpm bytewise same by 100.00 %
802E.rpm bytewise same by 100.00 %
802F.rpm bytewise same by 100.00 %
8030.rpm bytewise same by 100.00 %
8031.rpm bytewise same by 100.00 %
8032.rpm bytewise same by 100.00 %
8033.rpm bytewise same by 100.00 %
8034.rpm UNIQUE Length in A is 6656 bytes and B is 6656 bytes 8034.rpm bytewise same by 81.07 %
8035.rpm UNIQUE Length in A is 8192 bytes and B is 8192 bytes 8035.rpm bytewise same by 77.28 %
8036.rpm UNIQUE Length in A is 8192 bytes and B is 8192 bytes 8036.rpm bytewise same by 99.87 %
8037.rpm bytewise same by 100.00 %
8038.rpm bytewise same by 100.00 %
8039.rpm bytewise same by 100.00 %
803A.rpm bytewise same by 100.00 %
803B.rpm bytewise same by 100.00 %
803C.rpm bytewise same by 100.00 %
803D.rpm bytewise same by 100.00 %
803E.rpm bytewise same by 100.00 %
803F.rpm bytewise same by 100.00 %
8040.rpm bytewise same by 100.00 %
8041.rpm bytewise same by 100.00 %
8042.rpm bytewise same by 100.00 %
8043.rpm UNIQUE Length in A is 1024 bytes and B is 1024 bytes 8043.rpm bytewise same by 98.54 %
8044.rpm UNIQUE Length in A is 1024 bytes and B is 1024 bytes 8044.rpm bytewise same by 99.22 %
8045.rpm bytewise same by 100.00 %
8046.rpm UNIQUE Length in A is 1024 bytes and B is 1024 bytes 8046.rpm bytewise same by 98.93 %
8047.rpm bytewise same by 100.00 %
8048.rpm UNIQUE Length in A is 6656 bytes and B is 6656 bytes 8048.rpm bytewise same by 39.50 %
8049.rpm bytewise same by 100.00 %
804A.rpm UNIQUE Length in A is 2560 bytes and B is 2560 bytes 804A.rpm bytewise same by 86.95 %
804B.rpm UNIQUE Length in A is 6656 bytes and B is 22016 bytes 804B.rpm bytewise same by 40.58 %
804C.rpm bytewise same by 100.00 %
***************804D.rpm file is identical***************
804D.rpm bytewise same by 100.00 %
804E.rpm bytewise same by 100.00 %
804F.rpm bytewise same by 100.00 %
8050.rpm bytewise same by 100.00 %
8051.rpm bytewise same by 100.00 %
8052.rpm bytewise same by 100.00 %
8053.rpm bytewise same by 100.00 %
8054.rpm bytewise same by 100.00 %
8055.rpm bytewise same by 100.00 %
8056.rpm bytewise same by 100.00 %
8057.rpm bytewise same by 100.00 %
8058.rpm bytewise same by 100.00 %
8059.rpm bytewise same by 100.00 %
805A.rpm bytewise same by 100.00 %
805B.rpm bytewise same by 100.00 %
805C.rpm bytewise same by 100.00 %
805D.rpm bytewise same by 100.00 %
805E.rpm bytewise same by 100.00 %
805F.rpm bytewise same by 100.00 %
8060.rpm bytewise same by 100.00 %
8061.rpm bytewise same by 100.00 %
8062.rpm bytewise same by 100.00 %
8063.rpm bytewise same by 100.00 %
8064.rpm bytewise same by 100.00 %
8065.rpm bytewise same by 100.00 %
8066.rpm bytewise same by 100.00 %
8067.rpm bytewise same by 100.00 %
8068.rpm bytewise same by 100.00 %
8069.rpm UNIQUE Length in A is 7680 bytes and B is 10752 bytes 8069.rpm bytewise same by 51.73 %
806A.rpm UNIQUE Length in A is 1536 bytes and B is 1536 bytes 806A.rpm bytewise same by 99.67 %
806B.rpm UNIQUE Length in A is 10752 bytes and B is 10752 bytes 806B.rpm bytewise same by 93.72 %
806C.rpm bytewise same by 100.00 %
806D.rpm bytewise same by 100.00 %
***************806E.rpm file is identical***************
806E.rpm bytewise same by 100.00 %
806F.rpm bytewise same by 100.00 %
80FC.rpm UNIQUE Length in A is 1024 bytes and B is 1024 bytes 80FC.rpm bytewise same by 99.71 %
80FE.rpm UNIQUE Length in A is 16384 bytes and B is 16384 bytes 80FE.rpm bytewise same by 94.71 %
80FF.rpm UNIQUE Length in A is 25600 bytes and B is 25600 bytes 80FF.rpm bytewise same by 99.96 %
81.rpm UNIQUE Length in A is 4608 bytes and B is 4608 bytes 81.rpm bytewise same by 99.98 %
8FFC.rpm bytewise same by 100.00 %
8FFD.rpm bytewise same by 100.00 %
8FFE.rpm bytewise same by 100.00 %
9A.rpm UNIQUE Length in A is 30720 bytes and B is 30720 bytes 9A.rpm bytewise same by 99.97 %
AC55.rpm UNIQUE Length in A is 512 bytes and B is 512 bytes AC55.rpm bytewise same by 99.80 %
B1.rpm UNIQUE Length in A is 15360 bytes and B is 15360 bytes B1.rpm bytewise same by 23.79 %
B2.rpm UNIQUE Length in A is 19456 bytes and B is 19456 bytes B2.rpm bytewise same by 70.71 %
B5.rpm UNIQUE Length in A is 1048064 bytes and B is 1048064 bytes B5.rpm bytewise same by 99.97 %
B6.rpm UNIQUE Length in A is 163840 bytes and B is 164352 bytes B6.rpm bytewise same by 5.53 %
B7.rpm bytewise same by 100.00 %
B8.rpm UNIQUE Length in A is 1024 bytes and B is 1024 bytes B8.rpm bytewise same by 99.71 %
B9.rpm UNIQUE Length in A is 167424 bytes and B is 168960 bytes B9.rpm bytewise same by 5.35 %
BA.rpm UNIQUE Length in A is 169472 bytes and B is 171008 bytes BA.rpm bytewise same by 5.37 %
BB.rpm UNIQUE Length in A is 128512 bytes and B is 129024 bytes BB.rpm bytewise same by 7.99 %
BC.rpm UNIQUE Length in A is 163328 bytes and B is 165376 bytes BC.rpm bytewise same by 5.31 %
BD.rpm UNIQUE Length in A is 178176 bytes and B is 178688 bytes BD.rpm bytewise same by 5.11 %
BE.rpm UNIQUE Length in A is 10752 bytes and B is 10752 bytes BE.rpm bytewise same by 82.35 %
BF.rpm UNIQUE Length in A is 4096 bytes and B is 4096 bytes BF.rpm bytewise same by 99.93 %
C5.rpm UNIQUE Length in A is 267264 bytes and B is 278016 bytes C5.rpm bytewise same by 22.43 %
D0.rpm UNIQUE Length in A is 126464 bytes and B is 126976 bytes D0.rpm bytewise same by 14.07 %
D000.rpm UNIQUE Length in A is 512 bytes and B is 512 bytes D000.rpm bytewise same by 99.02 %
D001.rpm bytewise same by 100.00 %
D002.rpm UNIQUE Length in A is 512 bytes and B is 512 bytes D002.rpm bytewise same by 84.18 %
D003.rpm UNIQUE Length in A is 512 bytes and B is 512 bytes D003.rpm bytewise same by 84.18 %
D004.rpm UNIQUE Length in A is 512 bytes and B is 512 bytes D004.rpm bytewise same by 84.77 %
D005.rpm UNIQUE Length in A is 512 bytes and B is 512 bytes D005.rpm bytewise same by 84.77 %
D006.rpm UNIQUE Length in A is 512 bytes and B is 512 bytes D006.rpm bytewise same by 96.88 %
D1.rpm UNIQUE Length in A is 183808 bytes and B is 184320 bytes D1.rpm bytewise same by 5.06 %
D3.rpm UNIQUE Length in A is 103936 bytes and B is 103936 bytes D3.rpm bytewise same by 16.21 %
D4.rpm UNIQUE Length in A is 114176 bytes and B is 114688 bytes D4.rpm bytewise same by 16.17 %
D5.rpm UNIQUE Length in A is 172544 bytes and B is 173056 bytes D5.rpm bytewise same by 5.44 %
D7.rpm UNIQUE Length in A is 163328 bytes and B is 163840 bytes D7.rpm bytewise same by 5.39 %
D8.rpm UNIQUE Length in A is 106496 bytes and B is 107008 bytes D8.rpm bytewise same by 15.84 %
D9.rpm UNIQUE Length in A is 161280 bytes and B is 161792 bytes D9.rpm bytewise same by 5.33 %
DB.rpm UNIQUE Length in A is 169472 bytes and B is 169984 bytes DB.rpm bytewise same by 5.20 %
DC.rpm UNIQUE Length in A is 138240 bytes and B is 138752 bytes DC.rpm bytewise same by 14.05 %
DD.rpm UNIQUE Length in A is 161792 bytes and B is 162304 bytes DD.rpm bytewise same by 5.32 %
DE.rpm UNIQUE Length in A is 169472 bytes and B is 169984 bytes DE.rpm bytewise same by 5.28 %
DF.rpm UNIQUE Length in A is 180224 bytes and B is 180736 bytes DF.rpm bytewise same by 5.27 %
E0.rpm UNIQUE Length in A is 3276800 bytes and B is 3276800 bytes E0.rpm bytewise same by 99.50 %
E1.rpm UNIQUE Length in A is 3276800 bytes and B is 3276800 bytes E1.rpm bytewise same by 99.62 %
E2.rpm UNIQUE Length in A is 3276800 bytes and B is 3276800 bytes E2.rpm bytewise same by 98.53 %
E3.rpm UNIQUE Length in A is 3276800 bytes and B is 3276800 bytes E3.rpm bytewise same by 99.81 %
E4.rpm UNIQUE Length in A is 3276800 bytes and B is 3276800 bytes E4.rpm bytewise same by 97.29 %
E5.rpm UNIQUE Length in A is 3276800 bytes and B is 3276800 bytes E5.rpm bytewise same by 98.64 %
E6.rpm UNIQUE Length in A is 77312 bytes and B is 77312 bytes E6.rpm bytewise same by 93.24 %
E7.rpm UNIQUE Length in A is 16384 bytes and B is 16384 bytes E7.rpm bytewise same by 97.22 %
E8.rpm UNIQUE Length in A is 703488 bytes and B is 703488 bytes E8.rpm bytewise same by 33.47 %
E9.rpm UNIQUE Length in A is 703488 bytes and B is 703488 bytes E9.rpm bytewise same by 33.53 %
EA.rpm UNIQUE Length in A is 703488 bytes and B is 703488 bytes EA.rpm bytewise same by 33.26 %
EB.rpm UNIQUE Length in A is 703488 bytes and B is 703488 bytes EB.rpm bytewise same by 33.24 %
EC.rpm UNIQUE Length in A is 703488 bytes and B is 703488 bytes EC.rpm bytewise same by 33.30 %
ED.rpm UNIQUE Length in A is 703488 bytes and B is 703488 bytes ED.rpm bytewise same by 33.17 %
EE.rpm bytewise same by 100.00 %
F7.rpm UNIQUE Length in A is 159744 bytes and B is 160768 bytes F7.rpm bytewise same by 5.28 %
FA.rpm bytewise same by 100.00 %
FE.rpm UNIQUE Length in A is 1024000 bytes and B is 1024000 bytes FE.rpm bytewise same by 99.92 %
Total files compared 459 :: IDENTICAL FILES 123 :: UNIQUE FILES 336
PostPosted: May 29th, 2022, 5:09
Simran ,
i have a case were this can be used i will definately try and revert back
PostPosted: May 29th, 2022, 13:45
With respect, I feel that the output seems "cluttered". Could I suggest that you use a tabular format instead?
  size A    size B   U/I  same %   file name
  203776    204800    U     4.97   34D4.rpm
   12345     12345    I   100.00   37.rpm
U = unique
I = identical
PostPosted: May 29th, 2022, 14:54
This would have the same info, but might be easier to see:
   12345              I            37.rpm
U = unique
I = identical
PostPosted: June 1st, 2022, 16:11
Hi Fzabkar, surely I will incorporate the presentation bit. I am coding a few more things at the moment.
Also,My mentor always insists so much on presentations. However, this code/presentation was not reviewed by him before I posted (i was excited to post :D )
N
nonetheless, I will adopt your way of presentation. It's pretty cool.
ALSO, The main project is that of a crazy NAND BIT MAP VIEWER under the guidance of my mentor (Sourcerer) is going AMAZING! We have been working on it since about 2 months. I am not sure when the release will be. However, be assured, it's going to be quite nice.
I am again thankful to Sourcer for all the unconditional support he has provided to me. He has taught me not only about C/programming logic/technology
but also he improved me as a human too.
Also by next month-end, I shall be appearing for C programing Entry-level and Associate level certifications. Just doing them for personal satisfaction.
All in all, too much happening with the programming side and some crazy recoveries too...Cant assure I will put the new EXE any time soon. Motivating other people to code something similar in the language of their choice.
Much love to Sourcerer. <3
PostPosted: June 4th, 2022, 16:51
Here is a FreeBasic version (32-bit):
http://www.users.on.net/~fzabkar/FreeBasic_W32/Utils/dircomp.bas
http://www.users.on.net/~fzabkar/FreeBasic_W32/Utils/dircomp.exe
PostPosted: June 4th, 2022, 17:17
Excellent.
Another friend/student of mine from a place called as Rajhamundry in Hyderabad is soon going to post his version.
Users browsing this forum: No registered users and 17 guests
