 Post subject: WD10TMVW-11TK7S1
PostPosted: May 19th, 2022, 11:12
This pcb is completly burn't. ROM included.
Can someone provide me a loader so I can try and regenerate a ROM with a donor pcb?
Thanks.
 Post subject: Re: WD10TMVW-11TK7S1
PostPosted: May 19th, 2022, 11:53
Thanks.
Just turned brain on a searched again. Already found one. Thanks.
PostPosted: May 21st, 2022, 14:17
Thanks.
Well,
Let me teach you a technique here ,What you can do is use a donor rom ,block it ,use same donor LDR And then read tracks ,Then Search for modules in that track ,you will get lots of stuff that you can use and solve the case .
Users browsing this forum: Google [Bot] and 371 guests
