 Post subject: Need Advice on Failed Recovery by Ontrack
PostPosted: May 23rd, 2022, 0:32
Hi Everyone,
I sent a dropped portable WD HDD to Ontrack with the hopes that they can recover the data since after dropping the portable HDD, it still worked then died after a few days. But unfortunately, Ontrack was not able to repair my HDD. Here are the details they have sent to me.
>Drive has Internal Mechanical Failure and media corruption that is blocking us to access into sector level.
>It required a close matching spare part to bypass the media corruption (which has a slim chance of success).
>We are unable to get a close enough match after searching for weeks. As such, this case is unrecoverable.
My question is
1. Should I send it to other data recovery company? Any suggestions on other reliable Data Recovery Companies?
2. Can it be recovered if in the future if somehow someone developed a software that can access the media corruption without the need of matching spare parts (donor drives)? I am hoping that my platters are still intact since they didn't say anything about scratches or broken platters.
My HDD Details is listed below
Media Model Number: Western Digital My Passport 0748
Media Serial Number: WX51EB264199
 Post subject: Re: Need Advice on Failed Recovery by Ontrack
PostPosted: May 23rd, 2022, 14:21
What is the actual model number on the label of the HDD (not enclosure)?
PostPosted: May 24th, 2022, 1:52
Unfortunately, I threw away the labelled sticker inside the enclosure. :(
PostPosted: May 24th, 2022, 2:47
You threw away the label secured to the drive itself? you'd really have to work hard to do that, it's not something you can do by accident.
PostPosted: May 24th, 2022, 4:00
Then tell us PCB number.
I have a WX51EB.. in my Spyglass collection
Digitalsupport Data Recovery
https://digitalsupport.dk
PostPosted: May 24th, 2022, 10:18
I recovered several drives they claimed unrecoverable, but the question is not this simple, there are more factors to it.
answering your 2 questions:
1. i doubt the platters are intact, they usually get damaged in some extent during such an impact.
2. No software will ever cope with hardware failures of such degree,
PostPosted: May 25th, 2022, 23:45
Thanks for your replies. Appreciate it.
As for the PCB, i'll have to check and attach the picture later. :)
PostPosted: June 28th, 2022, 0:49
Hi Everyone,
Attaching Photos of PCB and external HDD
Sorry for the delay.
PostPosted: June 28th, 2022, 0:54
I know that my somehow my HDD is probably unrecoverable since i dont have a donor drive that matches with my HDD but still hoping that in the future that someone will develop a hardware that doesnt need a donor drive to access data.
Is that possible?
Thank you
PostPosted: June 28th, 2022, 15:22
nope, but why do you want to do it yourself?
It might still be possible by experts right now.
PostPosted: June 29th, 2022, 14:35
We’ve recovered two drives just this week, that Ontrack had deemed unrecoverable.
PostPosted: June 29th, 2022, 17:04
Looks like a Firebird family, which could be a pain to get it working.
Donors have gotten difficult to find.
+1 pcimage (plus they have a donor stock of drives)
+ pepe
Either are great.
PostPosted: June 29th, 2022, 18:13
i have loads of these plus can recover rom if needed, plus can use any type of heads...
However, i do not like that naked cover, it actually sucks. Do you still have the label with you?
PostPosted: July 1st, 2022, 21:20
If that is the correct plastic shell, that model is usually a ShrekLT model WD20NMVW-11AV3S0 inside. At least that's what I've always documented finding in there on past cases I've handled. Much easier to find a donor for that than it is for a Firebird.
Recovery should still be possible unless there is severe platter damage. But, it's impossible to really know based on a report written by an Ontrack sales guy. It could very easily be just a case of someone being too lazy to investigate what the drive is given the missing label.
Get a second opinion from a reputable lab on here.
PostPosted: July 1st, 2022, 23:23
It's definitely a Shrek (4 platters / 8 heads)
I have received two cases (both are Shrek) which Ontrack claimed they're unrecoverable.
One has a ring on the upper side.
Both successfully recovered 65% and 95% respectively.
They always refuse such cases for unknown reasons.
PostPosted: July 1st, 2022, 23:26
Shreks are still popular. Find it hard to believe Ontrack does not have parts. Something weird is going on.
PostPosted: July 2nd, 2022, 21:39
They probably looked at the DIY attempt and said, nope.
PostPosted: July 18th, 2022, 1:09
Thanks for all your replies! I’ll probably send it to another recovery lab for 2nd opinion :)
Users browsing this forum: michael chiklis and 66 guests
