 Post subject: ST1000LM035
PostPosted: May 26th, 2022, 16:55
Need some one to confirm that ROM file is corrupted or not.
The drive stays busy even trying read channel without any success.
Thanks in advance.
ROM.rar [252.66 KiB]
Downloaded 259 times
 Post subject: Re: ST1000LM035
PostPosted: May 26th, 2022, 17:26
have you already manage to unlock terminal?
If you use virtual ldr you should be able to unlock it and do the busy fix patch.
You will need to find virtual loader (module 3D) from donor drive which has same Overlay CompileDate as your patient drive rom, in your case is 20190705.
You can find that date in your rom at address 0x251927 - 0x255147 - 0x514071 - 0x517291.
My firmware database:
PostPosted: May 26th, 2022, 18:29
FWIW, the SMART report is clean and the drive has recorded 3648 Power-On Hours.
ID Flag  Cu Wo Raw data
01 0F 00 52 40 E2 A2 95 09 00 00 00
03 03 00 64 64 00 00 00 00 00 00 00
04 32 00 5E 5E A4 1A 00 00 00 00 00
05 33 00 64 64 00 00 00 00 00 00 00
07 0F 00 42 3C 1D C0 3B 00 00 00 00
09 32 00 60 60 40 0E 00 00 31 DA 2B
0A 13 00 64 64 00 00 00 00 00 00 00
0C 32 00 64 64 55 00 00 00 00 00 00
B8 32 00 64 64 00 00 00 00 00 00 00
BB 32 00 64 64 00 00 00 00 00 00 00
BC 32 00 64 64 00 00 00 00 00 00 00
BD 3A 00 64 64 00 00 00 00 00 00 00
BE 22 00 46 3B 1E 00 1A 20 00 00 00
BF 32 00 64 64 15 00 00 00 00 00 00
C0 32 00 64 64 09 00 00 00 00 00 01
C1 32 00 5B 5B 16 4A 00 00 00 00 00
C2 22 00 1E 29 1E 00 00 00 0E 00 00
C5 12 00 64 64 00 00 00 00 00 00 00
C6 10 00 64 64 00 00 00 00 00 00 00
C7 3E 00 C8 C8 00 00 00 00 00 00 00
F0 00 00 64 FD F1 00 00 00 E6 2F 21
F1 00 00 64 FD EF D5 1D 8D 00 00 00
F2 00 00 64 FD 07 C1 C7 56 00 00 00
FE 32 00 64 64 00 00 00 00 00 00 00
PostPosted: May 28th, 2022, 8:47
The whole story :
The customer came to me to recover the data from the drive.
He said that he poured a coffee on the drive. Then the drive stopped working.
He gave the drive to a computer shop and they told him that the drive has internal issue and they can't help.
After diagnosing I found that the PCB is dead then I replaced it but the heads are damaged.
Heads replaced and the drive spin up and calibrate without any strange noises.
But stays busy and the terminal only shows :
Boot 0x80M
Tried to unlock with MRT and it reported unlocked but the same message in terminal and not even reach the handshake.
Many thanks for your inputs.
PostPosted: May 28th, 2022, 9:35
This is because h0 was switched off in ROM.
Also, the attached ROM was not unlocked.
Try this ROM (rename to .bin)
ROM_modded.doc [1 MiB]
Downloaded 271 times
PostPosted: May 28th, 2022, 9:57
:lol: :lol: :lol:
You were faster than me with 5 minutes to solve this Northwind
Just figured this out now.
Someone messed up with this drive before.
Thanks a lot for your help :)
Users browsing this forum: No registered users and 276 guests
