 Post subject: Burned WD PCB no external bios chip. I need help
PostPosted: May 30th, 2022, 7:48
My problem seeing at picture
Can I read bios with wiring. And wiring points??
Sexy Womans from your town
 Post subject: Re: Burned WD PCB no external bios chip. I need help
PostPosted: May 30th, 2022, 8:59
You can either move the mcu or fix the pcb. It looks a burnt mess but have tried clearing it off - is there any actual pcb damage, I assume you have a donor for replacement parts.
PostPosted: May 30th, 2022, 9:09
I have swapped this components. nothing changed
PostPosted: May 30th, 2022, 9:35
Replace the entire PCB and generate ROM from SA.
I can see it's 2060-701444 from sequoia drive 160 GB, Am I right?
PostPosted: May 30th, 2022, 9:53
WD3200AAJS-65VWA0
MRT has bug when writing ROM to internal ( embedded)
I have reported 2 years ago still same.(writing FF FF FF to first sectors)
2060-701444 yes congragulation to you : )
PostPosted: May 30th, 2022, 13:30
Write the regenerated ROM code to a working donor HDD in SATA mode.
PostPosted: May 30th, 2022, 19:09
I lost my mind. Thats true .
I would try it. Tested a PCB ( diffrent number) has internal ROM. Writing properly in SATA mode.
Thank you for awaking me : )
PostPosted: May 30th, 2022, 19:16
Be aware that your PCB has a damaged Vcore supply and a damaged preamp supply. The latter may mean that your preamp is also damaged. I would measure the preamp resistances at your HDA pins.
PostPosted: May 31st, 2022, 5:00
Well Frank,
Preamp resistance on HDA pins will differ from HDD to HDD right ,But one might find out what pins they are by seeing the PCB ,In this case which pins do you think we should test
PostPosted: May 31st, 2022, 13:58
Pins 4 and 6 appear to be the preamp supply pins.
Users browsing this forum: Google [Bot] and 54 guests
