 Post subject: WD20EZAZ-00L9GB0 F/W: 4.1TH No User Area
PostPosted: February 25th, 2022, 7:41
HDD: WD20EZAZ-00L9GB0-04.A8H.1-0073004R F/W: 4.1TH
Here attached Full Backup
https://drive.google.com/file/d/1zfSLPPBYis1lZbyyWYtnVcHiZ28kW2Oo/view?usp=gmail
When Normal Start HDD it gets ready and immediately goes to Bsy.
When Disabled 02 in Rom then hdd ready then loaded 02 without problem. HDD gets Full ID with Capacity and can read all modules without err including 190. All modules checksum OK in WDMarvel.
When try to access User Area Hdd goes to Bsy state and Restart.
How to solve this issue?
 Post subject: Re: WD20EZAZ-00L9GB0 F/W: 4.1TH No User Area
PostPosted: February 27th, 2022, 11:00
1. With 02 enabled Hdd restarted and goes to Bsy
2. With 02 disabled and loaded to ram hdd Ready. When try to read sector 0 (any Sector) hdd goes to Bsy
3. When Tried to Regenerate Translator, Hdd restarted and goes to Bsy ( 02 disabled and enabled in ram)
4. When tried with T2 Editor in MRT during Translator regen hdd restarted and goes to Bsy
5. When tried with T2 Editor without Translator option hdd keeps Ready. can only read zero sector, when tried any other sectors hdd restarted and goes to bsy
All Modules backed up. PCB is original, No SED and unlocked with MRT 2.1.7.x
Attached here 02, 31,32,33
Modules_02-31-32-33.zip [9.52 KiB]
Downloaded 425 times
Please Guide Experts
PostPosted: February 28th, 2022, 1:47
02.rar [1.71 KiB]
Downloaded 427 times
After Writing this 02.rpm Hdd gets ready without any problem. But when try to read any sectors then
Any Solution
PostPosted: February 28th, 2022, 6:57
Problem Solved.
Getting Data From that HDD.
PostPosted: May 23rd, 2022, 2:28
I have the same problem with one of the hard drives to be recovered. I did the same steps you did but not in MRT, with the help of PC3k and unlocked PCB. If you could help me with the final step, it would be a great help. I tried to get sector access in DE using "Read from utility option" but none of the methods were success. Please leave msg. Thank you
PostPosted: May 27th, 2022, 22:24
gps31 wrote:
Problem Solved.
Well,
What was done " Heads Replaced " .
PostPosted: May 31st, 2022, 1:38
No Head Change
PostPosted: May 31st, 2022, 4:44
gps31 wrote:
No Head Change
Then ,
I am asking because we all ask for help and most of us help each other ,Once someone solves it ,he should definately tell what was done ,Otherwise this spoils the very essence of a forum
PostPosted: May 31st, 2022, 4:58
Have to agree with Amarbir on this.. It's a pretty poor show to post a request for help and then just a "problem solved" message without disseminating any solutions found or given, it does nothing to further collective knowledge.
PostPosted: May 31st, 2022, 5:01
Well,
i am sure GPS is a good technician and will let us know in the thread
PostPosted: May 31st, 2022, 5:08
I'm sure GPS31 is, it's something I've seen a number of times from a number of users and I struggle to understand why.
PostPosted: June 4th, 2022, 0:31
Nothing special
Just Used Mrt T2 Editor and uploaded to RAM
All sectors Accessed without any issue.
PostPosted: June 4th, 2022, 5:56
gps31 wrote:
Nothing special
:mrgreen: ,
Your Magic Trick For Recoveries of These Drives ,Which means you are still to get the cases i am getting in These VeniceR Shi*** Drives
PostPosted: June 4th, 2022, 8:36
In This case https://forum.hddguru.com/viewtopic.php?f=1&t=42380
First means when i received it shows like that after it becomes as shown Now in Picture. I understand that your 4TB issue is like that so only i send PM.
In the above post discussed 0x190 is also full of garbage but that copy is worked for me
This hdd was first handled by one recovery firm and he too send the list of files and folders, Latter he returned it customer( i don't know what happened between them).
PostPosted: June 4th, 2022, 10:34
Well,
Parsing Mod 0x190 was there in PC3k Ages before MRT ,But MRT is not a tool thats brain dead ,support is rest is not
