Post new topic Reply to topic  [ 147 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6, 7, 8  Next
 Post subject: Re: ATA password bypassing
PostPosted: January 19th, 2014, 7:45
easy, get a hex editor.
a few are
HxD (free)
hex workshop
WinHex
etc..
file-->new ;)
then the keyboard scan codes are edited in I assume.. I am sure there was a post about this here or HDD Oracle. Do a search for terms like:
keyboard scan codes hex Victoria password
PostPosted: January 20th, 2014, 15:41
Here is a list of scan codes:
http://www.users.on.net/~fzabkar/MSKeyLog.TXT
For example, if your password were "ABC", then the "make" scan codes would be 1E 30 2E.
You would then build a 32 byte password file as follows:
00000000  1E 30 2E 00 00 00 00 00 00 00 00 00 00 00 00 00
00000010  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
... or ...
00000000  1E 00 30 00 2E 00 00 00 00 00 00 00 00 00 00 00
... or ...
00000000  00 1E 00 30 00 2E 00 00 00 00 00 00 00 00 00 00
IIRC those are some of the possible formats, but there may be others.
Victoria for Windows allows you to answer the password challenge with a file containing your password as opposed to typing the characters themselves.
PostPosted: January 20th, 2015, 3:54
Wondering if someone could please help me with this I have already run mhdd and for the 22.bin file and have tried to use it in victoria to unlock my drive but its not happening. Here are the results from the 22.bin file,
I am close to pulling my hair out. any help would be greatly appreciated
PostPosted: January 20th, 2015, 16:32
Hey thank you for that guide but my problem is with identifying the password in the hex string I started at 00000030 9th position in and selected 32 bytes in the string, I saved it in a hex editor and went through the unlocking process in victoria from a password file. when I click on unlock (yes in user mode and high security) I keep getting the error "error after DISPWD"
PostPosted: April 16th, 2015, 21:45
Hey Guys,
I couldn't get the MHDD scripts posted in this thread to dump my drive's password. So, I gave up on that idea and finally found the latest version of ZU.exe online. It cleared my hard drive password, and I was able to use it again. So, I wanted to release a Magic Boot Disk image which includes MHDD and ZU for everyone out there who wants to clear the password and doesn't care about losing all existing data.
Instructions:
    Download the attached ISO.
    Burn to a CD.
    Connect Western Digital drive you want to unlock directly to the motherboard.
    Boot into the BIOS.
    Find the section that configures the SATA mode. Mine was under "Integrated Peripherals".
    Set SATA Mode to "Legacy IDE".
    Set SATA as Primary Channel.
    Save BIOS settings.
    Reboot.
    Boot from the burned CD.
    Pick the default option.
    Run the following command:
zu /p
The drive has now been unlocked. You can reformat the drive and use it.
File comment: Magic Boot Disk with ZU and MHDD
magic_boot_disk_with_zu_mhdd.zip [626 KiB]
Downloaded 7069 times
PostPosted: April 16th, 2015, 22:13
Wasn't able to edit my post, but here's a video to go along with my previous post:
https://youtu.be/njepwJvqnp8
PostPosted: January 19th, 2016, 11:55
Hello everybody,
To begin, i'm sorry for my English
thanks to Spildit for his guide.
But i've got a problem with this guide.
My hard drive Hitachi is Locked : Sécurity On High Locked *Expired (on Victoria)
I have extract the file .bin with Victoria but i can't find my password is this file.
can you help me for find my password ?
thank you
PostPosted: January 19th, 2016, 12:53
@Yanoudak, that appears to be the output of the ATA Identify Device command (Russians refer to this as "passport" for some quaint reason). The password is not stored here.
PostPosted: January 19th, 2016, 13:13
Thanks Fzabkar,
What is the process to get password informations ?
Thanks again for you answer
PostPosted: January 19th, 2016, 13:15
If ZU can't do it for you, then I don't know any other DIY method.
PostPosted: April 29th, 2021, 17:40
Can this help me find my master or user password of my ATA Locked ST1000LM024 (Samsung)?
Don't need any of the data whatsoever, just need the drive for my modified Xbox 360.
I've been at this for almost four days now, not sure what else to try. My PC reads the drive perfectly with MHDD, PartedMagic, etc. I just don't remember my user password from years ago and none of the master passwords seem to be working. I've read it should be 100% possible to unlock/erase this if my security is in HIGH and not MAX – which it is. Any guidance would be truly appreciated.
If not, I'll just chuck this thing against a sewer drain as I am so damn tired of troubleshooting this thing lol :lol:
PostPosted: April 30th, 2021, 8:24
a security erase should do it for you i think. I cannot interpret how MHDD or other sw could read a pw locked drive perfectly (without the pw of course).
PostPosted: April 30th, 2021, 13:27
Hi pepe. Thanks for the reply here. I mean, I've tried everything. MHDD just keeps saying fail. I think I tried every command there is lol
I believe every command asks for some type of password unfortunately. Let me know if you can guide me on this. I'll get my PC and HDD up and running with MHDD again!
PostPosted: June 20th, 2022, 3:06
Was hoping this would be the solution for my WDC WD2500BEVT hdd however running the script gives me NO DRQ.
any other possible solutions? I know this is an old post
PostPosted: April 4th, 2024, 14:40
I ran the script and it gave me the .BIN file, but i couldn't find the key. Can somebody help me find it?
42.zip [456 Bytes]
Downloaded 490 times
PostPosted: April 4th, 2024, 15:00
000003B0                          1E CA 18 57 C5 B0 BE E5
000003C0  91 30 46 9A 1D A9 3F 35 9D F9 FC 6A 00 00 00 00
000003D0  00 00 00 00 00 00 00 00
PostPosted: April 5th, 2024, 10:06
Thanks for replying. When i copy the code into victoria, it changes to different characters. Also, i get an [ATA protocol]DRQ!!! Press RESET or restart drive error. Reseting it ends me with timeout. Any ideas? I don't know how to write the code in BIOS and im new to removing passwords.
PostPosted: April 5th, 2024, 12:41
Copy these 32 bytes to a file using a hex editor, and then present that file to Victoria.
PostPosted: April 5th, 2024, 14:17
I forgot to mention that unlock option is disabled in api mode and its security status is ON, MAX, LOCKED. under PIO it throws the DRQ errors even when i try to passport it and it seems like i can't find the drive in PIO. Any ideas?
PostPosted: April 5th, 2024, 14:27
https://www.hddoracle.com/viewtopic.php?f=95&t=166&p=334#p334
Users browsing this forum: Google [Bot] and 87 guests
