 Post subject: Suggestion [ ST4000DM004-2CV104 ] V11 F3 Family HDD
PostPosted: July 28th, 2022, 14:12
What are your suggestions for this seagate ST4000DM004-2CV104 terminal report
Boot 0x0100MAF55L40001
SpinUp
TCC:0027
Trans
Tech Unlock Handshake: 0x3A968F2E
Reply:
Rst 0x0100MAF55L40001
(P) SATA Reset
NVCScram Saved HB Size:020A
LD: MD_Alloc:00000090 HB_Alloc:0000 MD_Alloc:80380000 HB_Alloc:8032 DiscRestore MD_Saved:00000090 HB_Saved:00000000 MD_CRC:A7A8
PP: MD_Alloc:0000B400 HB_Alloc:0000 DiscRestore
PVTSize: 0004768C CompSize: 00008408 DeCompSize: 0004768C MD_Saved:00008408 HB_Saved:00000000 MD_CRC:3375
MC: MD_Alloc:00003000 HB_Alloc:0000 DiscRestore
DataLength: 00000310 MD_Saved:00000310 HB_Saved:00000000 MD_CRC:4C0E
DSP03D2
2Sync:0 4............................................................................................................................................................................................................................................................................................................
MCMainPOR: Start:
Media Cache Data Base 01D1C0BEB0 ODUmpEndHostLba = 0AD07530 IDUmpStartHostLba = FFFFFFFF
Check MCMT Version: Current
Both copy is same!
MSPSequenceNumber(Disc) 00000007
MSPSequenceNumber(MCMT) 00000000MS UDE detect during recon LPCDisc=00 2DF0D9EC 0023
MS Read Fails: 6F86CF60,000032A0
RECOV Servo Op=02A5 Resp=0005
NECS: CorruptedSectorsRecon - Head:0000000E Tail:00000000
LastWrittenDiscLBA : FFFFFFFFFFFFFFFF
MCMainPOR: MediaCacheDiscStateFlags 0000002A MCStateFlags 000200C1
6Gb Max Speed lowered to 3Gb for Intel bug
Send Status: COMRESET seen
FIS34
ENP03D2
2Sync:1 C
[BRO - 0002] 002DF0D9EC - 002DF0E03F Extents - 0001 Blk - 00000000 D - 0000000E
Starting LBA of RW Request=002DF0D9EC Length=00000654
ProcessRWError -Read- at LBA 002DF0DDB8 Sense Code=43110081
RECOV Servo Op=0295 Resp=0005
SP Regen FAIL
SPRegen [0000|400000A6] @LBA=0x2DF0DDB8
ITA 0: 1.000
ITA 1: 1.000
Hd 2 Err Blk 2DF0DDB8 BER pre -1.000000
Power C8 Duration 64 attempt 0
ITA 0: 1.000
ITA 1: 1.000
BER after -1.000000
Power C8 Duration 64 attempt 1
Skip Error Type Decision due to Small Sector count 0x0001ProcessRC: 00000000,00000000SkipLen: 00000000ReadContinuous: 2DF0DD16,0000032AUnrecovSectorCount:01E2,0316NumUDEs: 000001E2,00000000,00000316Passed: 00000080,00000144,000002D9Out: [SpawnDiscNodes: 2DF0DDB8,000001E2-6F86CF60,000032A0] ==> BRO is in progress SkipLBA: 2DF0DDB8,2DF0E02C
RAW ON After Spinup for counter=0x00000020, BlkAddr=0x003AD94F1A
Had a Tough Time making it stable But now its again acting up ,Head 02 was disabled while cloning folders selected by client .It was 2TB but i managed to clone 1.5TB disabling head 02 in DE .
 Post subject: Re: Suggestion [ ST4000DM004-2CV104 ] V11 F3 Family HDD
PostPosted: July 30th, 2022, 6:41
No One ,
:mrgreen: :mrgreen: :mrgreen:
PostPosted: July 30th, 2022, 6:47
What's your goal here?
Recover without H2 or get that side as well?
In the latter case a head swap is unavoidable (with all its implications and complications), unless you can get it work somehow.
PostPosted: July 30th, 2022, 10:13
Pepe Sir ,
Initial goal is to make the drive stable and clone all platters that worked like 00 01 and 03 ,Then do a head swap .
PostPosted: July 30th, 2022, 11:29
and did you change head map? Would not be surprised if it didn't work btw.
i have specially patched firmwares for these coz they don't really like head map changing out of the box.
PostPosted: March 27th, 2024, 2:28
What is it (firmware patch) ?
could you please enlighten us, how to headmap this type of drives
PostPosted: February 27th, 2025, 3:18
Barracuda Sucks 2 TB,4Tb :roll:
