 Post subject: WD10SPZX-24Z10T0 F/W: 0012000T Can't Unlock
PostPosted: August 14th, 2022, 11:45
HDD: WD10SPZX-24Z10T0 F/W: 0012000T
I don't have unlocked PCB 800066 (Palmer)
used MRT 2.1.7.1(First) to unlock rom then wrote the unlocked ROM in PCB which had already Patched ROM (0005008J), but no spinup (locked ROM Spin)
Then i asked one friend who have PC3K to Patch the ROM, That also gives the same result.
Attached Original + Patched ROMs( MRT and PC3K)
WD10SPZX-24Z10T0.rar [1.75 MiB]
Downloaded 334 times
Then Tried with https://firmware.hddsurgery.com/dl.php? ... 7NKHF4.zip
It also gives the same result. Both Original ROMs SPIN , Both Patched ROM - Error with No SPIN
is anything wrong with Patched ROM
Unlocking Process works with 0005008J but not work with 0012000T
 Post subject: Re: WD10SPZX-24Z10T0 F/W: 0012000T Can't Unlock
PostPosted: August 14th, 2022, 16:52
Weird.
Here is a thread where a user has exactly the same ROM version, with exactly the same PC3K unlock patch, exactly the same ROM code, yet his drive will spin up:
https://groups.google.com/g/datarecoverycertification/c/abVcl_BJHcQ
PostPosted: August 15th, 2022, 3:01
Check motor contacts on pcb, they're very delicate on this type of pcb.
If contacts are a little squized against pcb itself then drive will not spin or spin just sometimes.
Use a pair of tweezers to pull up contacts so that they can touch against motor contacts fermly, then screw the pcb fermly on hdd.
P.S.
Do not use to much force, be gentle with those tiny contacts.
Also, you should check ROM solder joints. If needed resold it properly on pcb by using a bit of flux.
My firmware database:
PostPosted: August 15th, 2022, 3:38
P.S.
I m getting same ERR when PCB alone Connected. ROM Solder Joints are also good.
PostPosted: August 15th, 2022, 12:42
What are the markings on the MCU? I'm wondering if your MCU has different kernel firmware which may make it incompatible with PC3K's unlocking patch.
In that other thread the MCU ID was "88i1053A0 0x(5460)". "A0" is the "custom code or die revision". You can find that at the end of the third line on the MCU.
http://www.hddoracle.com/viewtopic.php?f=59&t=205&p=14552#p14552
Does "Jakiro's" unlocked ROM spin up your drive? If so, then that would point to something in the adaptives.
https://groups.google.com/group/datarecoverycertification/attach/fa1d392fbd75/ROM_palmer_unlocked.bin?part=0.1
PostPosted: August 16th, 2022, 1:34
I have two PCBS both image
PostPosted: August 16th, 2022, 12:45
There is a 3 year difference in the manufacture dates, but the "custom code or die revision" is A0 for both.
PostPosted: August 17th, 2022, 9:56
Started PCB only with One unlocked ROM 0050008J
Then wrote original Locked ROM (Write ROM) and saved ROM modules
Edited Head map to 01 only
on Power Reset get the same err as shown First Post image.
Any change in the ROM gives err
Users browsing this forum: No registered users and 30 guests
