Post new topic Reply to topic  [ 70 posts ]  Go to page Previous  1, 2, 3, 4  Next
 Post subject: Re: MRT Software Update Advance Announcement 2021.09
PostPosted: June 15th, 2022, 3:55
ccc wrote:
DR-Kiev wrote:
Whats new in update? Did they add SpyGlass2Ultra finally?
Not yet unfortunately.....The last version is 2172 which corrected some bugs in DE and WD utilities.
There was the first 2171 version that was working without asking for programmer, after few days they released another 2171 version (minor update to WD utility,in fact that was the time when the unlock process started to ask for programmer even you want to unlock from file) and the 2172 version that corrected some bugs. If you have the first 2171 version you can still unlock from file without programmer.
Rgds
download link not work
PostPosted: June 15th, 2022, 4:00
I see that the link has expired.
MRT 2.1.7.1 offline first version:
https://www100.zippyshare.com/v/7Uu8JtMQ/file.html
Rgds
www.datasave.ro
PostPosted: June 16th, 2022, 8:14
thank you so much
PostPosted: August 15th, 2022, 10:43
Anyone know what is the changelog for MRT 2.1.7.3 ?
PostPosted: August 15th, 2022, 15:53
2.1.7.3:
http://us.mrtlab.com/download/
and 2.1.8.1 (for now only in the chinese version)
http://info.mrtlab.com/download/
VEXUS Data Recovery
PostPosted: August 15th, 2022, 15:58
Probably some fix on what was released in version 2172
VEXUS Data Recovery
PostPosted: August 16th, 2022, 11:03
Western Digital module, upgrade to 2.3.8.0:
1. Added family ApolloCR- 810011, Tresul- 800068
2. Added firmware unlock support for board numbers 800022/800041/810012 and 810035
3. Added permanent unlocking of 800xx series (unlocking needs to be used with the new programmer 3.0), removed the terminal handshake process, and supports unlocking by USB board number. The supported board numbers are as follows:
800022/800041/810012, 800065/800067/810003, 800066/800069, 800077, 810011, 810035
4. Added the "Firmware Unlock" button on the family panel and removed the "Unlock Handshake" button
5. Added T2 editor support for 810035, support uploading 190 to hard disk memory
6. Add hex page right-click to save the selection to the file
7. Added the sub-module analysis function in the module (ROM, 109 module)
1) Search and display listings
2) Save the selected module to a file
3) Load from file and replace
8. Added Western Digital backup module size setting
9. Optimize the T2 editor's handling of 190 partial entries corrupted or abnormal data
10. Optimize the family and board number classification of the family panel
11. Optimize the startup process, no serial connection is required to enter the program
12. Optimize and remove the "unlock handshake" function of the ROM tool
13. Optimize and remove the "unlock handshake" function in the shortcut bar on the right
Seagate module, upgrade to 2.0.8.1:
1. Added family panel CF family (Note: reading and writing ROM needs to unsolder the ROM chip, which is caused by the firmware download lock)
2. Added M15_Janus-CF family firmware unlock (ST4000LM024-2U8, ST5000LM000-2U8)
3. Added M15_Janus-CF family virtual boot (ST4000LM024-2U8, ST5000LM000-2U8)
4. Added Preamp type display, path: Edit ROM file - Edit ROM information - Edit SAP logic tag
5. Added ROM logic head bitmap for more families:
75 - ST500LT012
81 - ST1000LM033
86 - ST500LM021
8A - ST4000LM016
8C - ST2000LM007, ST2000LX001
A5 - ST2000LM007
AF - ST1000LM048, ST1000LM035, ST2000LM015, ST2000LM007
6. Added the default read ROM size with family ID of 91 to solve the crash problem caused by abnormal ROM size
7. Added track list view
8. Optimized firmware unlock and virtual boot support for 91, 97, B2, B5 families
9. Optimize the initialization process. When the firmware information has been obtained and the program is re-entered to select the last path, the firmware will be loaded from the file first.
10. Optimize the sorting display of the system file list, and display volume 0 and volume 3 first
11. Optimize the main interface to display the COM connection port number directly
12. Fixed the error that some families reported 0xC00000005 during ROM parsing
13. Repair the module list edit box ID does not follow the module selected by the cursor to update
14. Repair some LM disks to output MCMT analysis results. After the progress reaches 99%, the MRT crashes.
DE module, upgrade to 6.0.0.2:
1. Added Data Explorer support for USB device splitting (800xx series may need to unlock firmware, splitting requires modules 183 and 190)
2. Added Data Explorer factory program to read support for USB devices (800xx series may need to unlock the firmware)
3. Added 3 copy types and color marks: Seagate data 241A, sEDU sector, data all 0 sectors (for the loss of memory 190, some mirror data is 00)
4. Added task statistics. Added sector bitmap statistics and clearing options for the above-added copy types.
5. Added stream scan format: CHM, Z7, WMF, ANI, MID, OGG
5. Optimize the "read successful" green sector type to "read normal and non-0" sector
6. Optimize and greatly improve the speed of marking valid data
7. Optimize the function of saving files and fix the problem of failure to save very small files
8. Optimize the compressed bitmap mapping algorithm and fix the crash when the compressed data is abnormal
PostPosted: August 19th, 2022, 5:59
What the hell does this mean?.....Does anyone know?
www.datasave.ro
PostPosted: August 19th, 2022, 7:10
Maybe a problem with Google Translator
"Added Data Explorer support for USB device headers"
VEXUS Data Recovery
PostPosted: August 20th, 2022, 2:36
Finally, the english ver 2181 is out. It looks like the "usb splitting" was referring to head map in DE. Now it's clear.
www.datasave.ro
PostPosted: November 23rd, 2022, 7:27
Version 2182 is out .....but , as usual, they screwed something, some menus are in chinese ....Can't they do a test before releasing a software??
www.datasave.ro
PostPosted: November 23rd, 2022, 7:32
MRT 2.1.8.2 is currently chinese version .
English version may release in some days .
PostPosted: November 23rd, 2022, 9:35
If so, why do they provide the link to the English version on their site?
PostPosted: November 23rd, 2022, 13:14
I sense that their low cost approach translates to having limited staffing. Having some good beta testers would help, but sometimes companies get beta testers setup who provide absolutely no feedback and are just looking for a free product update.
PostPosted: November 24th, 2022, 5:57
Yes, Luke, I understand that. In the mean time they released a new version with correct english menus. But that was a obvious error that can be spotted very easy. If they can't see such error , what can we expect about many bugs in the program functionality?
For me, for example, the Seagate utility shuts down suddenly when parsing MCMT extends...A thing they claim they corrected in 2182 and 2181 version....I am on 2182 and the utility still shuts itself down.
I really don't understand how they test their software......
Rgds
www.datasave.ro
PostPosted: November 24th, 2022, 23:12
Western Digital:
1. Added new feature to disable and enable module 183 in ROM tools
2. Added a log to notify the status of module 183
3. Fixed the problem about failure to unlock PCB 810035. For version 2173 we need to choose 800022 to unlock 810035
4. Fixed the size error of the modules saved during resources backup
5. Optimized the dump T2 function without rebuilding T2 to mitigate unstable reading issue that occurred during data copy (Usually appeared when there are miss-aligned entries in module 190)
6. Optimized the search function of internal modules
What is the Purpose of disable 183 in Rom ?
PostPosted: November 29th, 2022, 11:23
ccc wrote:
Can you re-share the offline version please, the link is already expired. I appreciate your collaboration.
PostPosted: November 29th, 2022, 15:47
Rodrigo126 wrote:
ok
https://www.mediafire.com/file/x49y1udv ... e.rar/file
PostPosted: December 11th, 2022, 6:42
PostPosted: December 15th, 2022, 6:32
No one Ready share the info Even MRT!!!!!!
