Post new topic Reply to topic  [ 426 posts ]  Go to page Previous  1 ... 15, 16, 17, 18, 19, 20, 21, 22  Next
 Post subject: Re: New version of R-Studio
PostPosted: March 17th, 2022, 17:02
A new build of R-Studio (9.0.190296): Several important improvements and bugfixes.
PostPosted: April 6th, 2022, 16:42
A new version of R-Studio for Mac (7.0.7009). Catching up with R-Studio for Windows. The T80+ license, runtime and multi-pass imaging, sector maps, VMDK virtual disk format, etc. Plus many improvements and bugfixes.
PostPosted: April 27th, 2022, 10:32
A new build of R-Studio(9.0.190312). New RapidSpar options: Create Image/Complete Runtime Image; improved estimation of recovery chances, expanded message codes for deletion/move errors, and a lot of bugfixes.
PostPosted: July 18th, 2022, 14:50
New R-Studio version (9.1.191020):
* Support for the XFS file system;
* Support for Intel Software RAIDs;
* Data wiping for drives.
Additionally for the Technician versions:
* More extended options to control DeepSpar USB Stabilizer.
* Runtime imaging for individual folders/files;
* Imaging of drive's file system (FS map) only;
* Drive and file maps for all supported devices;
* Drive imaging to a physical drive rather than to an image file;
* New file hash functions sha1 and sha256 to forensic logs;
And improvements and bugfixes.
PostPosted: July 28th, 2022, 15:06
A new build of R-Studio (9.1.191026)
New features:
+ Support for 4k sector size for USB Stabilizer has been added.
+ A new command Close All Images has been added to close all opened images.
Improvements:
* The update process of USB Stabilizer drivers has been improved.
PostPosted: August 18th, 2022, 15:38
A new version of R-Studio for Linux (5.1.191031) has been released.
New features:
Improvements:
* R-Studio sets now the access rights of the current user to created files.
* Info about multi-pass imaging phases has been added to the log.
* A new option Check sectors status has been added to the Recheck Recovery Chances dialog box.
And many bugfixes
Also, a new build of R-Studio for Windows (9.1.191029). Improvements and bugfixes.
PostPosted: September 5th, 2022, 17:57
A new R-Studio for Windows build (9.1.191039) with bugfixes:
- R-Studio may have processed huge ext4fs file systems for too long time. Fixed.
- The Hexadecimal editor didn't close an opened disk when disk wiping started. Fixed.
- It was impossible to stop disk actions with malfunctioning disks. Fixed.
- The Map of file command was active in the left pane of the R-Studio's panel. Fixed.
- Not all information was copied from the Get Info window. Fixed.
- The Files and Folders checkboxes were disabled by default on the Find/Mark dialog box. Fixed.
- File search and mask returned incorrect results for the Modification date. Fixed.
- The Yes to All and No to All buttons appeared on the Save scan info dialog box even when only one tab was opened. Fixed.
PostPosted: September 6th, 2022, 13:55
Would it be possible to make a video with a couple of examples of R-Studio's find/search function using *, or expression, for files/folders.
You could load the video to your forum and post link here when ready.
Thank you.
PostPosted: September 20th, 2022, 13:13
Thank you.
We will do that.
PostPosted: September 20th, 2022, 13:15
A new version of R-Studio for Mac (7.1.191047): keeping up with R-Studio for Windows.
New features:
The following items have been added:
+ A new command Close All Images to close all opened images.
+ Support for the XFS file system;
+ Support for Intel Software RAIDs;
+ Data wiping for drives.
+ Runtime imaging for individual folders/files;
+ Imaging of drive's file system (FS map) only;
+ Drive and file maps for all supported devices;
+ Drive imaging to a physical drive rather than to an image file;
+ New file hash functions sha1 and sha256 to forensic logs.
And
New versions of R-Studio and R-Studio for Linux. Several improvements and bugfixes.
PostPosted: October 20th, 2022, 14:08
New build of R-Studio
New features
+ The Options and I/O monitor buttons have been added to the Drive Copy Wizard progress dialog box.
Improvements
* S.M.A.R.T. attributes detection has been improved.
* Symlink processing has been improved.
* Opening of partitions with the Ext file system has been accelerated.
And bugfixes.
PostPosted: January 12th, 2023, 17:00
A new version of R-Studio.
New features
+ Data storage types (SSD, HDD, USB, etc) info has been added to the Drives pane.
R-Studio Technician:
+ A new option "Skip files with bad sectors" has been added to runtime imaging of individual folders/files.
+ A new option "Unused clusters only" has been added to the multi-pass and complete runtime imaging options.
+ New file formats for recovery lists have been added: HTML, XML, JSON, and CSV. The new formats, especially the HTML one, allows the customers to easily edit recovery lists in their web browsers and then send edited lists back.
Plus improvements and bugfixes.
PostPosted: February 7th, 2023, 15:19
A new build of R-Studio (9.2.191126)
New features:
+ Disk scan has become available during multi-pass imaging.
+ Search/mark/mask can be specified by bad sectors and runtime imaging status.
+ A completed runtime image can now be either resumed or re-written.
+ The creation time and accessed time data has been added to the forensic report.
PostPosted: March 27th, 2023, 17:10
A new build of R-Studio(9.2.191140).
New features
+ All S.M.A.R.T. attributes can now be copied through one action (The Copy All button on the S.M.A.R.T. panel).
+ The Options tab is added to the Wiping progress indicator.
Improvements
* Progress display for the I/O monitor window has been improved.
* Last used paths are now saved in several new fields.
* The Cross link info has been added to the Get Info panel.
* Saving and loading of Broken File Name and Hidden Attribute parameters have been improved.
* Any files from Extra Found Files will not be recovered if there are their duplicates in the file systems (Root) when the Do not recover duplicate files from Extra Found Files option is selected. Earlier this option took effect only for recovered files.
PostPosted: April 10th, 2023, 2:31
Great!!
PostPosted: May 17th, 2023, 17:52
A new version of R-Studio for Mac (7.2.191153). Many new features, improvements, and bugfixes to match its Windows counterpart.
New features
+ Search/mark/mask can be specified by bad sectors.
+ All S.M.A.R.T. attributes can be copied through one action (The Copy All button on the S.M.A.R.T. panel).
+ Search/mark/mask can be specified by runtime imaging status.
+ New file formats for recovery lists have been added: HTML, XML, JSON, and CSV. The new formats, especially the HTML one, allow the customers to easily edit recovery lists in their web browsers and then send edited lists back.
And many improvements and bugfixes.
PostPosted: August 10th, 2023, 13:17
A new version of R-Studio (9.3).
New features
* Support for the ReFS 3.10 file system.
* Support for Bitlocker Drive Encryption. R-Studio can decrypt both BitLocker Drive Encryption and BitLocker ToGo volumes using either a password, recovery key, and a .bek file. R-Studio Technician/T80+ can also use FVEK (Full Volume Encryption Key) or VMK (Volume Master Key) data for decryption.
* Support for VHD/VHDX/VDI disk image formats. All R-Studio versions can load these files, R-Studio Corporate and Technician/T80+ can create them.
* Read-only support for the dmg files (Apple Disk Image: all versions ), e01/(ewf) files (Expert Witness File Format: R-Studio Technician/T80+), and aff files (Advanced Forensic Format: R-Studio Technician/T80+).
* Support for creation of encrypted RDR image files (the main disk image format for all R-TT, Inc products).
* Support for SCSI/NVME translation for external USB/NVME boxes. Among other things this makes it possible to obtain S.M.A.R.T. attributes for such devices.
Improvements
* All data from the Properties tab can be copied in one command.
* Multi-pass Imaging Phases can be enabled/disabled on-the-fly.
* Symlinks can be exported to custom recovery lists either as real folders or as symlinks.
* Search for files has been added to the HTML custom recovery lists.
PostPosted: August 22nd, 2023, 13:37
A new build of R-Studio (9.3.191230): several important improvements and bugfixes, including the issue with NTFS deduplication.
PostPosted: October 2nd, 2023, 16:22
A new version of R-Studio for Mac: keeping up with its Windows counterpart.
PostPosted: October 9th, 2023, 12:24
A new version of R-Studio for Linux (5.3.191246). Keeping up with its Windows counterpart: ReFS 3.10 file system, support for Bitlocker Drive Encryption, VHD/VHDX/VDI, dmg files, e01/(ewf), etc.
