Post new topic Reply to topic  [ 30 posts ]  Go to page 1, 2  Next
 Post subject: Ransomware encrypted .vhdx files. What software can mount?
PostPosted: September 12th, 2022, 0:13
Hi Gurus!
I have an urgent matter :( I have several ransomware-encrypted .vhdx files that contain critical data that unfortunately doesn't exist in a fresh backup somewhere :(
https://do-it-rmm.s3.us-west-1.amazonaws.com/encrypted+vhdx+files.png
A colleague told me that it's likely that only the only the catalog or $MFT might be encrypted so it won't mount... I should be able to get the data?
He told me you guys are the best and will likely have recommendations.
Please help! I'll be up all night waiting for a reply.
Thank you!
 Post subject: Re: Ransomware encrypted .vhdx files. What software can moun
PostPosted: September 12th, 2022, 3:33
your data got effected with 3 different ransomware hackers i dont think it can be recover without key.
PostPosted: September 12th, 2022, 4:41
Where is this conclusion coming from?
No.
You got infected with Phobos Ransomware which, after studying and researching it for several years, I found that it has no weaknesses.
HOWEVER,
depending on what kind of files these virtual drives contain, I might be able to help. But it won't be cheap.
PostPosted: September 12th, 2022, 10:13
I mostly am looking for the Quickbooks files(s) on one server.
So I would be wasting my time with Kernel for VHD? :(
PostPosted: September 12th, 2022, 10:14
How can you tell just from that screenshot?
PostPosted: September 12th, 2022, 11:03
Phobos, no known method to decrypt. Depending on file type partial repair may be possible as I found when examining this JPEG file: https://www.instagram.com/p/CdyLVH6ojkt/
PostPosted: September 12th, 2022, 11:38
Kernel for VHD only shows me tons of NTFS filesystem chunks with similar useless files in them...
PostPosted: September 12th, 2022, 11:51
What's "not cheap" in this case? Please message me or by all means post your price. Thank you!
No.
HOWEVER,
PostPosted: September 12th, 2022, 13:42
Maybe get 2nd opinion using UFS.
PostPosted: September 12th, 2022, 14:39
I'll pass.
quickbooks files are not my piece of cake and I don't know how to reconstruct them from partial results.
Sorry!
I'd take Arch Stanton's last advice: Use UFS, scan and mount the vhdx files you have and then select "scan for lost data" on them.
Obviously, expect partial recovery results at the very best scenario.
PostPosted: September 13th, 2022, 2:16
Thanks for the advice. I may scan one of the other servers as lots of more recent documents are missing and could be good to recover, hopefully, easier than Quickbooks.
PostPosted: September 13th, 2022, 2:28
StylishJedi wrote:
Hi Gurus!
Thank you!
upload here a sample JPG/DOC/XLS/PDF files to tell you,,, one sample is enough +the msg which has the key
PostPosted: September 13th, 2022, 3:18
Just for the sake of knowing: have you contacted the hackers and know the price they want?
It's bad, but sometimes it's the only way. Unfortunately, I have paid a few...
ACELab partner
PostPosted: September 13th, 2022, 6:40
I know some *clients* paid via BTC and did not get anything
so
Will you pay the unknown 1000$ or pay the known 500$ (just saying)
PostPosted: September 13th, 2022, 10:46
Yes they wanted $22000 for a small company with 7 workstations and a few VM servers
Fortunately they didn't get to one of the backups but it had been tampered with and turned off months before, so data is a bit old.
PostPosted: September 13th, 2022, 10:58
einstein9 wrote:
StylishJedi wrote:
Hi Gurus!
Thank you!
The problem is the DOC/XLS/PDF that are relevant and needed are all on the VM's that are encrypted. Can't get to them :(
PostPosted: September 13th, 2022, 11:38
But did you scan the VHD's with anything else than Kernel in the meantime?
PostPosted: September 14th, 2022, 2:29
@ StylishJedi
Without sample Docs as mentioned will be difficult to judge really,,, you don`t have even any sample default doc/pdf/jpg from the OS
but it has to be encrypted
@ Arch Stanton
The VM is encrypted there is no way on earth to read whats inside it without decrypting
@pclab
Just to add here, i know a big company who already PAID about 15,000$ and the hacker gave them the utility & key to decrypt their DB but guess what !!
it decrypted the old useless DB files and when they asked for the rest they asked for more $$$..
The money is gone and no data,,, back to square one :idea:
PostPosted: September 14th, 2022, 3:27
Yeah, we need to have some luck as well.
Fortunately the 3 or 4 cases I already paid came out all OK.
ACELab partner
PostPosted: September 14th, 2022, 5:29
einstein9 wrote:
@ StylishJedi
@ Arch Stanton
Yes! But as I mentioned earlier and showed using the JPEG example the ransomware does not encrypt every byte of the file. It encrypts 'bands' so to speak. What I do not know is the percentage that actually gets encrypted. So this is what I'd be examining and try determine if larger files have a chance of surviving. So, interval and number of bytes that's encrypted. And see if UFS for example can handle the missing portions and treat it as if it were file system damage/corruption.
Users browsing this forum: No registered users and 31 guests
