 Post subject: Choice and advice
PostPosted: November 8th, 2021, 19:05
Hello friends,
Came out burned by a bad experience with Seagate two years ago, it took me three months to recover the data thanks and only thanks to this forum.
At a quick glance which one would you advise if at all?
MG07ACA14TE https://www.amazon.it/gp/product/B07DHY ... BO6Q&psc=1
or
MG08ACA16TE https://www.amazon.it/gp/product/B0832B ... BO6Q&psc=1
In hard-disk interface it's written ‎Serial ATA-600 for MG08ACA16TE and ‎ATA133 for MG07ACA14TE. Is that really the case for the latter one?
Many thanks
 Post subject: Re: Choice of
PostPosted: November 8th, 2021, 19:16
Both are SATA-3.3 and both are CMR models:
https://toshiba.semicon-storage.com/content/dam/toshiba-ss/asia-pacific/docs/product/storage/product-manual/eHDD-MG07ACA-Product-Manual.pdf
https://gzhls.at/blob/ldb/1/7/e/d/90b9bdef0a4256a095e6593b2df8e17f761c.pdf
https://toshiba.semicon-storage.com/content/dam/toshiba-ss/asia-pacific/docs/product/storage/product-manual/eHDD-MG08-Product-Overview.pdf
 Post subject: Re: Choice and advice
PostPosted: November 8th, 2021, 19:28
Thank you fzabkar.
What is the difference between MG07ACA and MG08ACA other that storage?
PostPosted: November 8th, 2021, 19:53
They seem to have the same technology, so it's just a matter of storage capacity.
Any other similar model worth to mention you would personally advice?
PostPosted: November 9th, 2021, 16:07
I don't see any significant difference. The 16TB has a greater data density (because both drives have 9 platters). One document specifies power loss data protection, so that may be something to consider.
Here is a photo of the 14TB PCB (MG07ACA):
https://www.harddriveparts.com/images/G0022A.jpg
IC5, IC6 and IC7 appear to be the serial flash memories which provide the nonvolatile backup for data loss protection.
PostPosted: November 9th, 2021, 16:38
I believe this is the 16TB PCB (MG08ACA):
https://www.harddriveparts.com/images/G0044A.jpg
It also appears to have several "ROMs" at IC4, IC5 and IC6. I'd have to see a better photo to be certain, though.
PostPosted: January 30th, 2022, 18:21
I went for the 14 TB. Thanks fzabkar
PostPosted: February 10th, 2022, 19:07
I was wondering if there is any good software I can use to run some basic test on the drive?
From the outside it seems to be perfect but the popular site I bought it from has this customary habit to send stuff inside used or recycled boxes.
Plus it has been thrown by the courier on my alleyway from the other side of the gate, part of the plastic envelop (see photo below) was damaged I assume due to transport and it didn't come inside the anti-static bag. Should I worry a bit?
PostPosted: February 11th, 2022, 4:06
It will probably go brick at the first powerup if it got damaged. So i recommend testing it for 1-2 days, if it fails you can get it replaced, if not, then it's not worse than anything else.
BUT! Hopefully you will have a backup after the story above :)
PostPosted: February 11th, 2022, 15:46
More or less my strategy. I just loaded it with 1 TB of unimportant data and left it connected along with the other drives. So far I haven't detected anything unusual.
Thanks for your reassurance pepe
PostPosted: October 7th, 2022, 17:48
And here I am.
Maybe not that quick but it seems quick enough.
I have had it connected more or less idling ever since I published this thread. It's always been there in silence, showing its icon. Today I needed to copy some data so i open its folder; i just had time to check a few sub-folders when the window suddenly disappeared. Strange I thought. I then reopen it and start the copying. The process went a bit on but then stopped followed by this message:
download/file.php?mode=view&id=23037
I tried a few times and it seems the problem persisted, the drive's head (I presume) makes a sound the moment it stops.
I recorded it, you find it attached.
The drive is supposed to be still under warranty. I guess the best is returning it...
Any advice on how to make sure all data are properly erased?
Many thanks you for your support
(What a hassle...)
Voice 004.zip [2.33 MiB]
Downloaded 299 times
PostPosted: January 14th, 2023, 14:43
Update:
In the end I got a refund and kept the drive.
I have been keeping the drive busy since then, I split the space in two partitions and filled them up in turns. It was showing the issue for a few times but after a while it went back to normal. Not a device I can rely for important stuff. What a shame..
Users browsing this forum: Google [Bot] and 62 guests
