 Post subject: Wrong pinout? More then 1 CE? 16Bit bus support?
PostPosted: October 21st, 2022, 23:36
I have been bashing my head against the wall with this one, perhaps the pros will find this question funny, but I have to ask anyways.
To start:
1) This micro sd card should be 64GB. I have not rulled out the possibility of a fake card.
However, after connecting it to PC3K flash it detects the card, and provides this ID:
Bus= 8 bit/ IO0x-0 ->  ID= 0xADDE14AB  (ID EXT= 0xADDE14AB 424AADDE)R/B OK! - OK! Parts detect... 1 OK! 2 Not Found! 3 Not Found! 4 Not Found!
Does this mean I should have active CE1 and CE2 and CE3 pins to find this extra 3 banks?
If i analyze this chip ID I can understand that it is a:
AD = Hynix
DE = 8GB
But... if we look at DE bit representation, it means that it can be a 16-bit bus instead of 8?
In my mind that makes sense, because if in a 8 bit bus, one bank is 8GB, 4 banks would be 32GB wich is half of the capacity of the full memory.
Perhaps I'm over complicating this. Can someone shed some light?
File comment: original pinout
310622933_1814590048885734_1572139422202698282_n.jpg [ 716.77 KiB | Viewed 6623 times ]
 Post subject: Re: Wrong pinout? More then 1 CE? 16Bit bus support?
PostPosted: October 22nd, 2022, 4:24
IMHO card is fake. Try assembly data and you will see.
PostPosted: October 22nd, 2022, 7:59
Can't do anything on it, i need to figure out why I don't have access to the other 3 banks...
No ECC detected, no XOR, no interleave.
Raw recovery only reports mp3 headers.
PostPosted: October 22nd, 2022, 10:12
So probably new XOR, new ECC, new assembler as most of flash cases now ;)
PostPosted: October 22nd, 2022, 10:56
Thing is, the card is over 4 years old.
Would you be interested in analyzing the dump?
PostPosted: October 22nd, 2022, 11:05
I can look.
PostPosted: October 22nd, 2022, 11:15
arvika wrote:
I can look.
I'll upload to ftp later today.
Any idea about other parts or does this chip might only have 1 part?
PostPosted: October 22nd, 2022, 11:21
If chip is fake, probably it have only one bank.
PostPosted: October 23rd, 2022, 9:55
After fast check:
- card is fake
- it use BB
- need new XOR, ECC, new asembler
Users browsing this forum: No registered users and 45 guests
