Discussions related to PC-3000
Please no pirated software here!
ROM of a WD10SMZW-11Y0TS0 with S/N close to WXM1xxxxx
March 12th, 2020, 6:19
Hello dear community
I'm seeking for the ROM of a WD10SMZW-11Y0TS0 with S/N close to WXM1xxxxx
I have only two but they don't help also others
Additionally, have you tried to rebuild the ROM of these drives from SA?
Thank you
Re: ROM of a WD10SMZW-11Y0TS0 with S/N close to WXM1xxxxx
March 12th, 2020, 6:48
This is Palmer (USB)
Need an unlocked PCB end version ROM to select compatible.
No copies of adaptive modes ROM in SA. Difficult case if you lost your native ROM.
March 12th, 2020, 7:08
Hello I own three unlocked boards for it
Acelab in the ticket replied that it can be tried, but you need a compatible ROM
March 12th, 2020, 7:20
Corsari,
there is
05.66B_04.67
05.06B-03.65
05.06B_03.64
02.1AP_01.3C
06.06H_B1.3K
02.26P-B1.3K
03.48U_03.61
02.1AP_01.3C
which one to send?
March 12th, 2020, 12:47
Tomset,
hello thank you!
I don't know which could be the right one
Can you kindly zip them all? Ill send you a private message
This can turn in an interesting test
Thank you
March 12th, 2020, 20:37
Corsari,
Rather, it will be an endless process. )
I will gather resources and lay out. Take some time.
March 12th, 2020, 22:50
https://drive.google.com/open?id=1YnZly ... Lw9NsZ4Tk6
March 13th, 2020, 1:23
thank you really much
so far I did noticed a weird data
I had some four ROMs collected here and in the palmers where I moved and saved the ROM
If you go to SA Regions the Dir address is 0 for both C0 and C1
while usually it is often a different offset and it varies from drive to drive
looks weird
March 13th, 2020, 7:50
Though the first impressions with now some ROMs tested
is that there is something that doesn't "return" in the situation
With every ROm the drive goes DRD DSC and DOESN'T clicks
but later no way to get SPT and following steps to try to access the SA
March 13th, 2020, 7:56
so it should be until you pick up very close adaptive.
What about the native ROM?
March 13th, 2020, 8:09
Something went wrong moving it to the unlocked board
it arrived with missing board :-(
November 8th, 2022, 10:05
Tomset wrote:Corsari,
there is
05.66B_04.67
05.06B-03.65
05.06B_03.64
02.1AP_01.3C
06.06H_B1.3K
02.26P-B1.3K
03.48U_03.61
02.1AP_01.3C
which one to send?
Hi Tomset,
Can you send me one version from your list?
ROM Modules:
ROM version............................. : 02.26P
ROM F/W version......................... : 0002000P
Overlay F/W version..................... : 02.26P
Servo F/W version....................... : B1.3K
Thank you.
November 8th, 2022, 11:44
I think Tomset is not with us anymore.
See the ROM attached.
WD_rev_02.26P.zip
(651.52 KiB) Downloaded 520 times
November 8th, 2022, 13:00
Doomer wrote:I think Tomset is not with us anymore.
Sorry. I did not know.
Doomer wrote:See the ROM attached.
Thank you for the file.
This seems to be different ROM F/W version than mine.
ROM Modules:
ROM F/W version......................... : 0002000T
November 8th, 2022, 17:48
I've seen only version of 2.26P
Not sure how important 0002000P would be for you tasks AFAIK this is a security FW version.
November 9th, 2022, 4:49
What? :shock: What happened?
November 9th, 2022, 11:52
Cancer, from what I heard.
November 9th, 2022, 17:58
MasterT wrote:This seems to be different ROM F/W version than mine.
Found it
WD_rev_02.26P_2000P.zip
(651.49 KiB) Downloaded 535 times
November 12th, 2022, 13:04
Huh ,
Is he Well but sick or he is expired doomer ?
November 12th, 2022, 14:18
Amarbir[CDR-Labs] wrote: Is he Well but sick or he is expired doomer ?
He died on August 7th, 2022
