suddenly the SSD does not work anymore. It is still recognized by Linux/Windows, but there is no partition anymore.
fdisk -l:
Disk /dev/sda: 465.76 GiB, 500107862016 bytes, 976773168 sectors
Disk model: HFS500G32TND-311
Units: sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
smartctl: (Serial Number removed)
smartctl 7.3 2022-02-28 r5338 [x86_64-linux-6.0.10-1-default] (SUSE RPM)
Copyright (C) 2002-22, Bruce Allen, Christian Franke, www.smartmontools.org
=== START OF INFORMATION SECTION ===
Device Model: HFS500G32TND-3112A
Serial Number: XXXXXXXXXXXXXXXXX
Firmware Version: 30060P00
User Capacity: 500,107,862,016 bytes [500 GB]
Sector Size: 512 bytes logical/physical
Rotation Rate: Solid State Device
TRIM Command: Available
Device is: Not in smartctl database 7.3/5319
ATA Version is: ATA8-ACS (minor revision not indicated)
SATA Version is: SATA 3.1, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is: Sat Dec 10 17:01:04 2022 CET
SMART support is: Available - device has SMART capability.
SMART support is: Enabled
=== START OF READ SMART DATA SECTION ===
SMART overall-health self-assessment test result: FAILED!
Drive failure expected in less than 24 hours. SAVE ALL DATA.
No failed Attributes found.
General SMART Values:
Offline data collection status: (0x03) Offline data collection activity
is in progress.
Auto Offline Data Collection: Disabled.
Self-test execution status: ( 0) The previous self-test routine completed
without error or no self-test has ever
been run.
Total time to complete Offline
data collection: ( 0) seconds.
capabilities: (0x19) SMART execute Offline immediate.
No Auto Offline data collection support.
Suspend Offline collection upon new
command.
Offline surface scan supported.
Self-test supported.
No Conveyance Self-test supported.
No Selective Self-test supported.
SMART capabilities: (0x0002) Does not save SMART data before
entering power-saving mode.
Supports SMART auto save timer.
Error logging capability: (0x01) Error logging supported.
General Purpose Logging supported.
Short self-test routine
recommended polling time: ( 1) minutes.
Extended self-test routine
recommended polling time: ( 60) minutes.
SMART Attributes Data Structure revision number: 0
Vendor Specific SMART Attributes with Thresholds:
ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE
1 Raw_Read_Error_Rate 0x000f 166 166 006 Pre-fail Always - 0
5 Reallocated_Sector_Ct 0x0032 100 100 036 Old_age Always - 28
9 Power_On_Hours 0x0032 061 061 000 Old_age Always - 34681
12 Power_Cycle_Count 0x0032 100 100 020 Old_age Always - 1858
100 Unknown_Attribute 0x0032 100 100 000 Old_age Always - 16848174
171 Unknown_Attribute 0x0032 253 253 000 Old_age Always - 0
172 Unknown_Attribute 0x0032 253 253 000 Old_age Always - 0
174 Unknown_Attribute 0x0030 100 100 000 Old_age Offline - 135
175 Program_Fail_Count_Chip 0x0032 253 253 000 Old_age Always - 0
176 Erase_Fail_Count_Chip 0x0032 253 253 000 Old_age Always - 0
177 Wear_Leveling_Count 0x0032 097 097 000 Old_age Always - 20
178 Used_Rsvd_Blk_Cnt_Chip 0x0032 100 100 000 Old_age Always - 34
179 Used_Rsvd_Blk_Cnt_Tot 0x0032 100 100 000 Old_age Always - 516
180 Unused_Rsvd_Blk_Cnt_Tot 0x0032 100 100 000 Old_age Always - 13372
181 Program_Fail_Cnt_Total 0x0032 253 253 000 Old_age Always - 0
182 Erase_Fail_Count_Total 0x0032 253 253 000 Old_age Always - 0
183 Runtime_Bad_Block 0x0032 253 253 000 Old_age Always - 0
187 Reported_Uncorrect 0x0032 100 100 000 Old_age Always - 39
188 Command_Timeout 0x0032 253 253 000 Old_age Always - 0
191 Unknown_SSD_Attribute 0x0032 253 253 000 Old_age Always - 0
194 Temperature_Celsius 0x0002 023 000 000 Old_age Always - 23 (Min/Max 14/47)
195 Hardware_ECC_Recovered 0x0032 100 099 000 Old_age Always - 1017167385
201 Unknown_SSD_Attribute 0x000e 100 100 000 Old_age Always - 0
204 Soft_ECC_Correction 0x000e 100 001 000 Old_age Always - 0
231 Unknown_SSD_Attribute 0x0033 098 098 010 Pre-fail Always - 3
234 Unknown_Attribute 0x0032 100 100 000 Old_age Always - 9823
235 Unknown_Attribute 0x0032 100 100 000 Old_age Always - 16678
241 Total_LBAs_Written 0x0032 100 100 000 Old_age Always - 15803
242 Total_LBAs_Read 0x0032 100 100 000 Old_age Always - 18915
250 Read_Error_Retry_Rate 0x0032 100 100 000 Old_age Always - 8975325
SMART Error Log Version: 1
ATA Error Count: 14094 (device log contains only the most recent five errors)
CR = Command Register [HEX]
FR = Features Register [HEX]
SC = Sector Count Register [HEX]
SN = Sector Number Register [HEX]
CL = Cylinder Low Register [HEX]
CH = Cylinder High Register [HEX]
DH = Device/Head Register [HEX]
DC = Device Command Register [HEX]
ER = Error register [HEX]
ST = Status register [HEX]
Powered_Up_Time is measured from power on, and printed as
DDd+hh:mm:SS.sss where DD=days, hh=hours, mm=minutes,
SS=sec, and sss=millisec. It "wraps" after 49.710 days.
Error 14094 occurred at disk power-on lifetime: 34673 hours (1444 days + 17 hours)
When the command that caused the error occurred, the device was active or idle.
After command completion occurred, registers were:
ER ST SC SN CL CH DH
04 41 00 00 00 00 00 Error: ABRT at LBA = 0x00000000 = 0
Commands leading to the command that caused the error were:
CR FR SC SN CL CH DH DC Powered_Up_Time Command/Feature_Name
61 00 10 88 16 00 40 40 00:08:10.100 WRITE FPDMA QUEUED
61 00 08 88 17 00 40 40 00:08:10.100 WRITE FPDMA QUEUED
ef 90 03 00 00 00 00 00 00:08:10.100 SET FEATURES [Disable SATA feature]
ef 02 00 00 00 00 00 00 00:08:10.100 SET FEATURES [Enable write cache]
61 00 10 88 16 00 40 40 00:08:10.070 WRITE FPDMA QUEUED
Error 14093 occurred at disk power-on lifetime: 34673 hours (1444 days + 17 hours)
61 00 08 88 17 00 40 40 00:08:10.070 WRITE FPDMA QUEUED
ef 90 03 00 00 00 00 00 00:08:10.070 SET FEATURES [Disable SATA feature]
ef 02 00 00 00 00 00 00 00:08:10.070 SET FEATURES [Enable write cache]
61 00 10 88 16 00 40 40 00:08:10.040 WRITE FPDMA QUEUED
Error 14092 occurred at disk power-on lifetime: 34673 hours (1444 days + 17 hours)
61 00 08 88 17 00 40 40 00:08:10.040 WRITE FPDMA QUEUED
ef 90 03 00 00 00 00 00 00:08:10.040 SET FEATURES [Disable SATA feature]
ef 02 00 00 00 00 00 00 00:08:10.040 SET FEATURES [Enable write cache]
61 00 10 88 16 00 40 40 00:08:10.010 WRITE FPDMA QUEUED
Error 14091 occurred at disk power-on lifetime: 34673 hours (1444 days + 17 hours)
61 00 08 88 17 00 40 40 00:08:10.010 WRITE FPDMA QUEUED
ef 90 03 00 00 00 00 00 00:08:10.010 SET FEATURES [Disable SATA feature]
ef 02 00 00 00 00 00 00 00:08:10.010 SET FEATURES [Enable write cache]
61 00 10 88 16 00 40 40 00:08:09.980 WRITE FPDMA QUEUED
Error 14090 occurred at disk power-on lifetime: 34673 hours (1444 days + 17 hours)
61 00 08 88 17 00 40 40 00:08:09.980 WRITE FPDMA QUEUED
ef 90 03 00 00 00 00 00 00:08:09.980 SET FEATURES [Disable SATA feature]
ef 02 00 00 00 00 00 00 00:08:09.980 SET FEATURES [Enable write cache]
61 00 10 88 16 00 40 40 00:08:09.950 WRITE FPDMA QUEUED
SMART Self-test log structure revision number 1
No self-tests have been logged. [To run self-tests, use: smartctl -t]
Selective Self-tests/Logging not supported
Is there a way to get to recover the data?
Via UART? Safe Mode or similar?
Thank you!
