 Post subject: What Is Recommended Free Software to Manage/Troubleshoot SSD
PostPosted: December 17th, 2022, 22:05
I have an unbranded 8T SSD that is highly suspect.
H2testw found faults in the first T but since then it has gone alright on tests - i.e. H2testw tests and my own copying onto it.
But it constantly gives an error when I try to delete: 'recycle bin is corrupt, delete?' but it won't delete it.
And windows cannot format it.
I need, I think, some software to optimally look at it and figure out just how big it really is and how good it is or at least allow a format of it.
Any recommendations?
 Post subject: Re: What Is Recommended Free Software to Manage/Troubleshoot
PostPosted: December 17th, 2022, 22:23
Start with a SMART report from a tool such as CrystalDiskInfo or GSmartControl.
PostPosted: December 18th, 2022, 5:34
I couldn't see the drive with crystaldisk so I got gsmartcontrol and tried it.
It seems to see a lot of drives. Up to pd3 are my drives: C,D,E and F.
Then it goes to pd9 but all are unmounted except pd6 which is the SSD, labelled drive G: by windows.
It is labelled by gsmart as 'unknown model' and all the others are labelled 'XVDD'
Smart unsupported on G: and all those XVDD's
p.s. just how/what 'backup a day' do you suggest?
PostPosted: December 18th, 2022, 8:29
Is this perhaps one of these external "SSD's" purchased from Amazon or similar? If so then it does not support SMART because it is in fact a USB flash drive. Try ChipGenius instead.
PostPosted: December 18th, 2022, 15:31
Yep. It is a USB flash of undetermined size.
I'm still looking for software to find out more/do more...
PostPosted: December 18th, 2022, 15:51
Silicon Motion SM3257 USB flash controller:
https://www.datasheet-pdf.info/attach/1/4640908223.pdf
