 Post subject: Lenovo DS2200 raid 6 parameters
PostPosted: December 18th, 2022, 16:37
Anyone know the Ds2200 raid 6 parameter default settings. Right, left, stripe size etc.
Thanks in advance
 Post subject: Re: Lenovo DS2200 raid 6 parameters
PostPosted: December 18th, 2022, 23:24
Thanks in advance
Hello ,
How many hdd are there in this RAID .I mean populated HDD's ? .
PostPosted: December 19th, 2022, 11:49
12 and 1 is a spare.
PostPosted: December 19th, 2022, 15:14
uses a qlogic chipset
PostPosted: December 20th, 2022, 12:36
Well,
what all tools are you having to handle all 12 drives in total ? .
PostPosted: December 20th, 2022, 13:47
I have what I need I need the parameters
PostPosted: December 20th, 2022, 14:35
ThinkSystem DS6200/DS4200/DS2200/DS EXP Storage Manager Guide:
https://download.lenovo.com/storage/01gw902_ds-series_smg_en.pdf
FWIW, Lenovo's "Best Practices" (page 144) recommends that the number of data disks in a RAID-6 be a power of 2, in which case the optimal stripe size would be 512KB. Otherwise the stripe size is 64KB.
PostPosted: December 22nd, 2022, 15:18
I have already been though every pdf they have on this unit.
As usual the tech they have beat it up first.
2 Sans 24 drives 3 Volumes.
I was able to get 2 of the volumes back. The client wiped one out and I am scanning the other now VMFS.
Still have to rebuild the Volume 1 on A01 to many drives quarantined and the trust command is not working to un-quarantine the drives. So I have to build this one out (11 4tb drives)
Thanks anyway.
PostPosted: December 22nd, 2022, 15:32
If I'm not mistaken it's not a RAID but SAN, so data is not stored linear, most likely (meaning it's not a regular RAID)
PostPosted: December 27th, 2022, 12:33
So like JBOD extended ?
PostPosted: January 12th, 2023, 14:47
Thanks guys anyway
I will just work on it in the SAN.
thanks
Users browsing this forum: Google [Bot] and 11 guests
