 Post subject: wd50ndzw slow read
PostPosted: January 4th, 2023, 15:31
Hi All. Hopefully someone has experienced this and can shed some light on the possible causes. I have seen quite a bit about WD SA issues causing Slow Reads/Writes, but nothing specifically on this drive.
The drive will read/copy data correctly in DMDE, and will show up and can be cloned in HDDSuperClone. Problem is, copying ~60GB of files took close to 2 months, and cloning is transferring at ~40k/sec.
Does anyone know of any potential fixes, or possible causes for this behavior?
 Post subject: Re: wd50ndzw slow read
PostPosted: January 4th, 2023, 17:12
It's a miracle that the drive is still alive.
That is called Slow Issue and haunts many WD drives.
You can fix it with pc3k or any other hardware tool (even with hddsuperclone, but I have never done it).
Read this:
https://forum.hddguru.com/viewtopic.php?f=1&t=28538
PostPosted: January 4th, 2023, 18:08
Amazing. I seem to have missed this in my searching. I will definitely look into this and see if this helps at all.
Thank you for your suggestion.
PostPosted: January 5th, 2023, 3:35
Am unable to get drive to initialize/become ready in WDMarvel. Detects the drive fine, and can read the Serial and Model.
Ran firmware through fzabkar's WDRomv17, and it says bad Module 47. Looked at the exported module 47 and appears to be shot.
Would someone be willing to verify my rom for me?
PostPosted: January 16th, 2023, 17:13
Acelab say that is not a good idea to do the "slow read" fix on this smr drives, it can cause further issues and will not make the drive fast.
Many pros here just let this type of drives clone slowly as they can, and wait days / weeks.
https://forum.acelab.eu.com/viewtopic.php?f=155&t=10720
My firmware database:
PostPosted: January 16th, 2023, 17:16
There would be two copies of module 0x47, an active copy and an inactive one. As long as the active copy is OK, the drive will spin up.
PostPosted: January 16th, 2023, 17:18
https://forum.acelab.eu.com/viewtopic.p ... r+slow+fix
WOW !!! Sorry, it's a wd50ndzw ... I was not aware. I did reply as if it were an older drive.
A lot of info still need to be known from new smr drives :wink:
I'm still waiting for a solution in the future, i also hope that will come out a soution to repair dynamic translators on smr toshiba drives... very few people know about it and pc3000/MRT still don't have a solution for that.
PostPosted: January 16th, 2023, 19:14
I am curious if a few tricks can be used to speed this drive reading up using hddsuperclone. Specifically maxing out the cluster size using direct USB mode, and maybe soft/hard resets with the read twice option (see the videos for more info).
https://www.youtube.com/watch?v=yX7HfHH0O6Y
https://www.youtube.com/watch?v=5JqP6HpUP8w
http://www.hddsuperclone.com
Home of HDDSuperClone
PostPosted: January 16th, 2023, 20:04
Slow Responding fix in RAM does occasionally work on SMR drives.
PostPosted: January 17th, 2023, 5:49
The problem on smr hdd is that 2nd level translator get changed (written) while we clone UA, this makes the drive slow... and could break 2nd translator.
The solution from AceLab is to lock writings on UA (at SA level), this will prevent changes on 2nd level translator, faster reading and keep alive weak heads.
PostPosted: January 17th, 2023, 10:01
That would be great if it worked. I have had 3 cases over the last few months where UA is locked and the secondary translator still gets corrupt.
PostPosted: January 17th, 2023, 14:17
Spildit wrote:
What about locking writing to UA and then patch 02 on RAM ?
How do you lock writing on UA ?
It is automated via PC-3000.
PostPosted: January 17th, 2023, 14:18
Acelab shows how to use TLER command (time limited error recovery)
https://youtu.be/47eXzxZk-0E?t=1458
PostPosted: January 17th, 2023, 14:29
PostPosted: January 17th, 2023, 14:32
TLER is different from locking the UA, or were you referring to something else?
PostPosted: January 17th, 2023, 15:09
Try setting the TLER (ERC = Error Recovery Control) level to its lowest possible value using HDAT2.
https://www.hdat2.com/files/hdat2en_481_v10.pdf (page 66)
PostPosted: January 17th, 2023, 19:33
As i understood from acelab video, TLER does more than setting low value for error recovery control.
It does disable a lot of modules on SA
PostPosted: January 17th, 2023, 19:36
Probably i did some confusion, locking writings on UA is another option on pc3000.
I don't own pc3000, i just watch some videos and read on forum about it.
PostPosted: January 17th, 2023, 19:47
I found where is located the lock UA option
is in the 190 module editing, that's the 2nd level translator module.
PostPosted: January 17th, 2023, 20:28
Quickest way to lock UA is via the SA menu.
Users browsing this forum: Majestic-12 [Bot] and 42 guests
