Post new topic Reply to topic  [ 25 posts ]  Go to page Previous  1, 2
 Post subject: Re: wd50ndzw slow read
PostPosted: January 17th, 2023, 20:45
Try setting the TLER (ERC = Error Recovery Control) level to its lowest possible value using HDAT2.
https://www.hdat2.com/files/hdat2en_481_v10.pdf (page 66)
I don't think it would be possible to set the value low enough without firmware modification. I played around with this (the read not the write) on the few drives I had that supported it, and the values are limited to how low you can set it. Plus the values are based on 100ms increments, and 100ms is plenty of time for a successful read or write. You would need to be able to set it to 0, which is the default value which tells the drive to use its default recovery timeout.
http://www.hddsuperclone.com
Home of HDDSuperClone
PostPosted: January 17th, 2023, 23:30
If you have an old WD drive that is supported by WDTLER, then dump SA module 02 before and after changing the TLER setting. I suspect that module 02 is where this setting is stored. If so, then make the same changes to module 02 in unsupported drives and see what happens. I would check whether these changes affect the defaults for the ATA ERC command.
PostPosted: January 18th, 2023, 1:59
Sorry I have not responded, I have been away from the forum for a couple days, and just checked back in. Glad I could have stimulated some discussion. :)
I could be wrong, as I am trying to learn this stuff by watching all of these discussions, but isn't Module 02 in the SA? One of the issues I am having with this drive is that I cannot read the SA with WDMarvel, because it does not become busy. I would be willing to try performing that Module 02 Fix, but alas, WDMarvel and HDDSuperTool both cannot get to the SA to perform any functions.
Let me better lay out what we have tried.
Brought the drive in because it was not recognized in customers machine.
Hooked it up to RapidSpar, and it was recognized and tested fine.
We performed a clone immediately, and while RS cloned it fairly quickly, About 70% of the files in the image were unrecoverable.
To get it off of our primary diagnostics machine, we put it on the DR machine in my office and tried to access the files on the drive with DMDE. DMDE saw the files and recovered files that were not recoverable on the RS.
It plugged along for just short of 2 months, but recovered the main 60GB of the files the customer needed asap. Decided I would try a clone with both DMDE and HDDSuperClone, but both reported between 180 to 250 days for completion at an average rate of 30k/sec.
Pulled the firmware off using my eeprom reader to see if I could find anything wrong with it.
So it appears that the files and structure are intact, but it is just responding really slowly. I dont want to have it running any more than needed at this point, because I dont know what is wrong with it.
PostPosted: January 18th, 2023, 2:01
maximus wrote:
I am curious if a few tricks can be used to speed this drive reading up using hddsuperclone. Specifically maxing out the cluster size using direct USB mode, and maybe soft/hard resets with the read twice option (see the videos for more info).
https://www.youtube.com/watch?v=yX7HfHH0O6Y
https://www.youtube.com/watch?v=5JqP6HpUP8w
I also considered this, but was not near my machine when I did so. I can certainly give it a shot when I get back to the shop.
PostPosted: January 18th, 2023, 21:59
Spildit wrote:
Without a PC-3000 you might be stuck with this one... :cry: :cry: :cry:
Well that is unfortunate. I would like to thank everyone for their insight and assistance in helping me try to figure this out.
Users browsing this forum: Google [Bot] and 253 guests
