 Post subject: 2060-771814-001 - SATA replacement
PostPosted: February 12th, 2013, 9:10
Hi all,
2060-771814-001 USB - 88i9146-TFJ2 looking for a SATA to convert to.
Should this work:2060-771692-005 SATA - 88i9146-TFJ2
Thanks.
Data Recovery Cape Town
 Post subject: Re: 2060-771814-001 - SATA replacement
PostPosted: February 12th, 2013, 9:18
Im not sure. In my experience I use only PCB 771812 (SATA) for 771814(USB). 771812 is found on Jamaica 4KV series.
If you try with 771692 it would be good to hear if it works for you :)
PostPosted: February 12th, 2013, 10:06
PM sent
PostPosted: February 12th, 2013, 11:49
This will work. TESTED
This won't. TESTED :)
PostPosted: February 12th, 2013, 11:50
Thank you gents.
PostPosted: March 5th, 2013, 14:15
Hello! Can anyone help with a similar problem - a hard disk WD10TMVM 1.0Tb. Connecting the USB 3.0. Problem - not determined in Windows, not in BIOS.
HDD space WD10TMVM 1.0Tb electronically controlled 2060-77814-001.
Question: Is it possible to recover data from the disk? Can I return to normal HDD enclosures WD10TMVM 1.0Tb?
Thank you for your attention.
Sincerely, Alex
PostPosted: March 5th, 2013, 15:28
Sincerely, Alex
Tjose are dificult drives, even for pros. If data is important to you and you want to recover it, best advice is to take it to a data recovery center near you.
Thank you very much for your quick response. Will refer to specialists. Thank you.
PostPosted: January 8th, 2018, 11:16
2060-771820-000 Works - tested
PAD-dataservice
http://www.pad-dataservice.dk
PostPosted: January 18th, 2023, 4:59
Colleagues I have a WD 320 GB WD3200BMVW-11AMCS4 drive based on a 2060-771814-001 board
on USB, which has failed, (you can hear squeaking inside)
I have a second working drive WD3200BPVT-00JJ5T0 Based on the board 2060-771820-000
Tell me if these boards are compatible ? If so, which IC should be soldered ?
Thank you for your help
PostPosted: January 19th, 2023, 6:41
Most likely not something you can recover on your own, so not much point in swapping the boards. 771820 is compatible with 771814 btw, need to swap U12.
PostPosted: September 17th, 2025, 9:37
I am currently trying 2060-771820 REV A from WD3200BPVT-22JJ5T0 (Jamaica 4KV) to replace 2060-771814-001 REV A on WD10TMVW-11ZSMS5 (Helios). The chip on 771820 is a Winbond one, whilst thus on the 771814 is labeled "PFlash".
PostPosted: September 17th, 2025, 9:42
why U14 to U12? U14 is rom for the bridge...
PostPosted: September 17th, 2025, 9:48
Thank you. I realized that meanwhile.
The U12 chip on the 771814 does well exist, but is differently branded and shaped.
I edited my previous message as I could not delete it.
I am trying now and will post back.
Users browsing this forum: Majestic-12 [Bot] and 210 guests
