 Post subject: WD30NMVW-11C3NS2 not initialised
PostPosted: February 9th, 2023, 11:25
Hello everyone,
i have an external hard drive WD20NMVW-11C3NS2 3TB does not detect the drive, disk utility shows not intialised, WDUtilities shows 0 bytes and no smart data available. Lmost newbie with these new drives so any help as to where to start will be appreciated. Physicaly it detects as my passport ultra and spins but nothing else.
Kind regards
Zesh
 Post subject: Re: WD30NMVW-11C3NS2 not initialised
PostPosted: February 9th, 2023, 12:16
Probably heads. No DIY.
PostPosted: February 9th, 2023, 13:51
thankks for the reply. any clues as to where to start?
kind regards
zesh
PostPosted: March 19th, 2024, 10:16
hello,
i had the same informations with an external hard drive seagate...how do you solve your problem?
Thank you in advance for your answer.
jeanluc.ferre
PostPosted: March 21st, 2024, 9:15
Looks like you didn't work on WD busy problems, suggestion of heads will be careless move in the beginning. If drive not clicking it is 99.9% WD busy problem. And now I can solve WD busy problem online for users, If he wish to give me access to the drives.
Data Recovery, Remote support & Training https://disksolution.com.pk/
PostPosted: March 21st, 2024, 11:30
I suggest you work on your own WD problems rather than digging up year old threads trying to make yourself look more knowledgeable than you actually are - move along.
PostPosted: March 21st, 2024, 12:25
jeanluc.ferre wrote:
hello,
jeanluc.ferre
It was WD and you Got Seagate Totally different scenario will be.
I did not saw the date but it was too early to suggest heads and do you know
Model: WD30NMVW-11C3NS2
Date: 23 JUN 2015
Product of: Malaysia
PCB Revision: 2060-800041-000 REV P1
ROM F/W version: 0001001C
Heads map: 0,1,2,3,4,5,6,7,8,9
10 Heads* definitely it is still now a hard job for you and for me.
PostPosted: March 22nd, 2024, 3:23
Why? Pebble Beach drives are much easier to work with, compared to other families.
He also said *probably* heads, so there's that too.
PostPosted: March 22nd, 2024, 9:32
Online
+1 - agree with Northwind, 10 headed Pebble Beach is a nice drive to work with.
Also the the "WD busy problem" happens because of weak heads, so "probably heads" is very likely.
Digitalsupport Data Recovery
https://digitalsupport.dk
PostPosted: March 27th, 2024, 2:27
What is worse to work with?
PostPosted: March 27th, 2024, 4:06
WD/HGST He.
Users browsing this forum: No registered users and 86 guests
