 Post subject: Erase/decrypt a Toshiba KHK6XLSE SSD
PostPosted: February 14th, 2023, 9:51
Have some of those drives decomisioned from servers, which I have not access anymore. They are TPM/hardware encrypted and not accesible, is there a way to erase/unencrypt them to be able to use them again? thanks
 Post subject: Re: Erase/decrypt a Toshiba KHK6XLSE SSD
PostPosted: February 14th, 2023, 11:14
Do they support PSID Revert?
PostPosted: February 14th, 2023, 11:24
I cannot see at the label anything related to the PSID... here a photo from the label:
and the "datasheet"
https://gzhls.at/blob/ldb/1/8/2/2/2f9a7099ad92546fe49ea5690b9f7e0a1b52.pdf
PostPosted: February 14th, 2023, 13:19
Did you try secure erase standard and extended through hdparm, with known master/user password set before by the same hdparm? Also Toshiba has its own ssd monitoring utility with secure erase option.
https://storage.toshiba.com/docs/servic ... n_note.pdf
PostPosted: February 14th, 2023, 16:38
Yes, tried before posting to change password and the output is an i/o error
The thing is that it isn't frozen and enhaced erase is possible (it says)
Didn't find the tool for toshiba ssd drives, does it work with enterprise ssds?
PostPosted: February 14th, 2023, 20:30
Try to set USER password, with "--user-master m" , an after that try to set "--user-master u" or just start erase as user or master with seted password, if disk allowed to set it. I have the same with HK4 it wouldnt accept user, but accept master, and after that accept erase. Try to add "--security-mode m" or "--security-mode h" then trying to set it.
PostPosted: February 14th, 2023, 20:52
Also you can try default master password --user-master m and 32 spaces ass PWD.
PostPosted: February 14th, 2023, 21:36
As toshiba tool you may try KIOXIA SSd Utility. https://europe.kioxia.com/en-europe/per ... ducts.html storage utility , legacy ssd utility.
PostPosted: February 14th, 2023, 21:55
Also try PSID-Master password as "12345678901234567890123456789012"
PostPosted: February 15th, 2023, 18:44
Thanks a lot for your answers.
Do you mean with sedutil? used --scan with it and the drive isn't Opal compilant
Could you elaborate a little more? I am pretty new about hdparm
Tried different kioxia utils without luck. I'm going to try contacting kioxia/toshiba...
PostPosted: February 16th, 2023, 9:39
No its not opal drive, so it was mistake, not as PSID ,but as Master password with hdparm, 1234567890... or 32 spaces. As for hdparm, you tried to set User password with "--user-master u" option, does you tried to set Master password with "--user-master m"? Sometimes disk allow to set master password, when user password is enabled. Also when you trying to erase it, you must specify the type of password with "--user-master" m or u.
PostPosted: February 16th, 2023, 13:45
Pitifully nor m nor u let me change the password, I will try today with the "12345678901234567890123456789012" password
Thanks again.
Users browsing this forum: Google [Bot] and 38 guests
