 Post subject: Netapp FW to LOD
PostPosted: June 16th, 2022, 4:44
Hi All
Has anyone ever converted a netapp .DLP file to a .LOD?
i was hoping to not have to use a netapp system to upgrade the firmware.
 Post subject: Re: Netapp FW to LOD
PostPosted: June 16th, 2022, 14:14
Can you show us an example?
PostPosted: March 1st, 2023, 20:47
fzabkar, do you want an .DLP file?
PostPosted: March 2nd, 2023, 14:14
Yes, if you like. I suspect that the only difference may be a Netapp header. However, the end result may still be that the LOD file will be rejected by the firmware updater, even if it is presented in the correct format.
PostPosted: March 2nd, 2023, 14:47
Here It is...
D_ST16000NM002G_30604625_NE02_XXXX_000.txt [2.41 MiB]
Downloaded 315 times
PostPosted: March 2nd, 2023, 15:44
To create a Seagate .LOD file, you need to strip off this header:
00000000  44 72 69 76 65 5F 44 6F 77 6E 6C 6F 61 64 5F 46  Drive_Download_F
00000010  69 6C 65 5F 48 65 61 64 65 72 00 00 00 00 00 00  ile_Header......
00000020  01 00 00 00 D0 00 00 00 68 A1 26 00 6D CC E4 0E  ................
00000030  53 65 61 67 61 74 65 00 00 00 00 00 00 00 00 00  Seagate.........
00000040  53 54 31 36 30 30 30 4E 4D 30 30 32 47 00 00 00  ST16000NM002G...
00000050  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
00000060  00 00 00 00 00 00 00 00 4E 45 30 32 00 00 00 00  ........NE02....
00000070  01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
00000080  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
00000090  00 00 00 00 07 00 00 00 4E 45 30 32 00 00 00 00  ........NE02....
000000A0  4E 45 45 41 00 00 00 00 4E 45 42 32 00 00 00 00  NEEA....NEB2....
000000B0  4E 45 42 31 00 00 00 00 4E 45 42 30 00 00 00 00  NEB1....NEB0....
000000C0  4E 45 30 31 00 00 00 00 4E 45 30 30 00 00 00 00  NE01....NE00....
000000D0  41 63 74 69 6F 6E 5F 44 65 73 63 72 69 70 74 6F  Action_Descripto
000000E0  72 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  r...............
000000F0  01 00 00 00 98 00 00 00 00 00 00 00 00 00 00 00
00000100  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
00000110  00 00 00 00 00 00 00 00 03 00 00 00 00 A0 26 00
00000120  00 00 00 00 0A 00 00 00 3B 05 00 00 00 00 26 A0
00000130  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
00000140  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
00000150  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
00000160  00 00 00 00 00 00 00 00
PostPosted: March 5th, 2023, 18:33
Thanks.
After striping this content should I just flash It using SeaChest?
PostPosted: March 5th, 2023, 20:18
I think that should be OK. Just be aware that mixing OEM and retail firmware is inadvisable because it may brick the drive or result in unexpected behaviour.
PostPosted: March 6th, 2023, 6:43
aledr wrote:
Thanks.
Maybe you need LOD? I got one
PostPosted: March 6th, 2023, 7:14
That would be nice.
For which disk model?
Users browsing this forum: Rendersmith and 98 guests
