Hello, can I ask for help?
I have a problem with the Samsung HM750LI drive - it is not detected and I have a donor board. I have the same, working disc model. I replaced the IC from the non-working one, but the situation is the same - the motor does not turn, the disk does not detect.
Terminal output:
Active FW : 00
FWVer : 0001
DDR size detected : SIPC status 00001002
SERVO
Unpack fail
It looks like there is maybe a problem with the FIPS checksum.
Is there anyone here who is able and willing to check the dump for me? Eventually tried to fix it?
I have both dumps - from a working and non-working disk.
dump-not-working.txt [512 KiB]
Downloaded 186 times
dump-working.txt [512 KiB]
Downloaded 176 times
