 Post subject: WD10EZEX head swap parameters
PostPosted: March 13th, 2023, 12:10
I have a WD10EZEX-08Y20A0 drive that needs a heads swap. I searched on ebay but it's very hard t find a donor with the same second part of the Model number.
I found a donor with a compatible DCM but the date and the second part of the drive don't match.
Are these 2 drives compatible? (the first one is the patient drive and the second one is the donor drive)
 Post subject: Re: WD10EZEX head swap parameters
PostPosted: March 14th, 2023, 4:05
They look compatible, however you should check the most important thing, which is the preamp version.
PostPosted: March 14th, 2023, 7:51
Hi Northwind,
The Preamp version is the same.
I swapped the heads, and it works like a charm!
Thank you,
PostPosted: March 30th, 2023, 20:07
How to check the preamp version?
PostPosted: March 31st, 2023, 16:18
ROM - 0A module
Users browsing this forum: No registered users and 40 guests
