Hello to all,
I will try to be quick and concise:
I'm not a professional, I'm a private person, who works in programming and computer science in general, and I'm also very adventurous in the matter and I like to learn.
So I have a personal hard drive that broke down 9 years ago, I was never interested in it before because I had no time and I was waiting for the technology to evolve in order to look into it.
To be clear right away: I have not called and will not call a data recovery company, the data on it dont worth it, but I still want to recover as much as possible (if I brick the disk, no problem). Moreover, I only want the data, once this is done, this disk will end up in the dumpster. So much for the important points about my intentions.
The initial failure: installed in secondary on my computer, from one day to the next, the disk was corrupted without any obvious reason: the disk appeared in raw format requiring a formatting. So I restarted the computer (naive that I was): the disk never showed up again. Mounted in SATA directly, on a USB dock or even in simple reading on a BIOS: nothing! So I put it away in the meantime.
The HDD:
Brand: WESTERN DIGITAL (WD)
Mdl: WD15EARS-00Z5B1
S/N: WMAVU1092642
WWN:50014EE0AC800FEF
Date: 29 Nov. 2009
DCM: HBNYNT2MA
LBA: 2930277168
Some time later I took it out again on the advice of a friend who told me that I could try to change the PCB, which I did: I bought a PCB with the same number 2060-701640-002 REV A. The donor's rom chip was flashed according to the patient's. The first time I plugged it in, the disk started spinning but nothing else. It was a little bit better than before. Then I put it away again, waiting for better.
Today: having time to waste (or not), and being curious, I got informed about disks, their architecture, their internal functioning (fascinating!). In two months, I scanned a lot of articles, videos and forums (including this one but I never participated).
After testing WDMarvel in demo, I switched to the PRO version.
Here is what I did:
Disk status: spinning platters, recognized by windows OS but not initialized and no information.
Recognized on WDMarvel but incomplete: Serial number in XYZ, capacity recognized as 250GB (while it is a 1.5TB).
And my next blunders (I know I was wrong on many manipulations, but I was ready to try): I managed to read all the modules, and I found that the ROM version was the same on the SA (so proof that the chip was well flashed).
All modules were recognized except 2: Module 02 and another module but I don't remember which one. I saved everything (ROM+Modules) except the two modules that I could not read (SCSI ERROR). Then based on modules found on a forum, with a serial number close to mine, I downloaded module 2, I modified it based on module 402E of my backup (I think it was 402E...). And I wrote module 2... The disk then disconnected and since then I had a lot of problems in the SA. I spare you all my actions, I tried many things to get to the current state, including a complete SA format in order to try to rewrite the whole SA (many errors in the SA when I tried to read the modules: many bad sectors.
Currently: the disk is recognized but still in the same way with a serial number XYZ. I manage to load in RAM the original modules number 1 (DIR toRAM), number 2 (READ/Write to Ram -> CONFIG-FILE), the two overlays 1B and the second number which escapes me: I push "detect" again and the disk is recognized as originally (serial number good) but just the size remains at 0 GB. And it is several times that I rewrite modules by changing the DIR to write elsewhere on sectors surely more healthy. I manage to put back several modules as seen on the picture below.
However, when I try to see if it stays after a soft reset, the disk locks up again and I have to start all over again by going through the kernel mode.
File comment: Photo
Now you know everything.
So I have two questions:
- Is it already possible to repair this disk while being at this level?
- Is it possible to re-install all the SA at once on another DIR?
I insist that this disk will end up either repaired, or destroyed software-wise, but will not go to a center.
Thanks in advance to those who had the courage to read this long story and who can possibly help me!
PS: english is not my first language like you guess, my apologises if i make wrong shortcuts or use the wrong terms.
