 Post subject: Compact Flash Cloning
PostPosted: April 4th, 2023, 21:17
I have a bootable CF drive, using an old version of DOS on an older voicemail system
I need to clone same
Source is a 4 GB drive from an existing working system, destination is a 4 GB drive.
I go through the process
Look at the destination disk
All info seems to be there.
Yet none of the 4 drives I've tried to clone, will boot.
I don't see how I could screw this up, but nonetheless, the cloned drives won't work
Any suggestions ?
HDD GURU has works well on SD drives, and other SmartMedia cards I've used on other systems.
Any timely help would be appreciated.
Max
 Post subject: Re: Compact Flash Cloning
PostPosted: April 4th, 2023, 21:53
Perhaps there is an ATAPI - ATA identification issue?
https://www.csse.canterbury.ac.nz/greg.ewing/hardware/pb150/PB150_and_CompactFlash.html
You could use HDAT2 to send the ATA Identify Device and ATAPI Identify Packet Device commands, and then capture the outputs to 512-byte files for analysis with a hex editor.
PostPosted: April 4th, 2023, 22:22
See the references to "fixed drive" on pages 26 and 47 of this specification:
http://www.reactivedata.com/Products/ProductManuals/SanDiskCFProductManual_V3.pdf
Notice that word 0 of the Identify Device info block differentiates between a fixed drive and a removable drive.
Fixed Drives enables booting from the CF Card. No software tool required.
