 Post subject: Removing ---Mrt UnLock---
PostPosted: April 8th, 2023, 19:48
Hi
I got ST500DM009 and in terminal: ---Mrt UnLock--- it seems the customer took it to another lab that used MRT
Can someone help me remove the Unlock and restore the original ROM so i can use PC3000
ROM.zip [406.15 KiB]
Downloaded 577 times
 Post subject: Re: Removing ---Mrt UnLock---
PostPosted: April 8th, 2023, 22:28
What about using this ROM to restore it?
https://firmware.hddsurgery.com/dl.php?file=20714&filename=ST500DM009-2F110A-CC43-ZA49BKZA.zip
You could patch your drive's adaptives into the donor. Hopefully the code is compatible with the SA.
PostPosted: April 8th, 2023, 22:34
I deleted the fw unlock code with my mrt.
Here's the file:
MRT ROMChange.zip [399.35 KiB]
Downloaded 610 times
MRT SCREEN
My firmware database:
PostPosted: January 18th, 2024, 19:31
Here's the file:
thanks
Users browsing this forum: No registered users and 97 guests
