 Post subject: Phison PS2251-50-F controller
PostPosted: May 2nd, 2023, 13:56
Does anyone know if this controller stripes data across both NANDS in a flash drive with 2 NANDS (like a RAID)? Or does it dump to one NAND before using the other? Thanks
 Post subject: Re: Phison PS2251-50-F controller
PostPosted: May 2nd, 2023, 18:31
You could find your answer here.
http://www.pc-3000flash.com/solbase/task.php
PostPosted: May 4th, 2023, 23:14
Whether to use the pair element depends on the firmware mode, not on the controller model. You have to actually analyze the corresponding case to get accurate information
http://flash-matrix.com/
PostPosted: May 5th, 2023, 4:16
Yes. Usually Block pair, than join by page. So it mix between both chips.
Users browsing this forum: Bing [Bot] and 128 guests
