 Post subject: Corrupted data (PDF, SLXS) after recovery with MRT
PostPosted: May 7th, 2023, 20:27
Banned User
WD 10SPZX no physical damage it started working very slow. the client need certain files which I used MRT file explorer to find and save but most of the pdf and SLXS are corrupted and can not be opened. I was wondering if there is a way to repair them. I tried to open some of them with HxD and this is what I got.
will cloning the hard drive to another hard drive fix this problem?
 Post subject: Re: Corrupted data (PDF, SLXS) after recovery with MRT
PostPosted: May 8th, 2023, 3:09
The 2nd file header seems to me its an excel file (healthy), but the file has a PDF extension
rename & try
PostPosted: May 9th, 2023, 17:01
perhaps drive reads from wrong location, so file repair will fail coz there is probably no good data in these files at all...
PostPosted: May 9th, 2023, 18:06
The "PK" signature denotes compression. What does 7Zip say when you try to open your file?
PostPosted: May 9th, 2023, 19:25
https://www.disktuna.com/repair-fix-a-c ... -write-up/
I have used the method with XLSX files too, assuming it's what you actually mean by SLXS.
PostPosted: May 11th, 2023, 6:40
Banned User
rename & try
Thanks for the suggestion but unfortunately it didn't work. probably i need to fix the slow response issue and clone it.
PostPosted: May 11th, 2023, 6:41
Banned User
yes I agree with you.
PostPosted: May 11th, 2023, 6:42
Banned User
Arch Stanton wrote:
https://www.disktuna.com/repair-fix-a-corrupt-word-document-quick-write-up/
Thanks for the help. tried it on different files but no luck.
PostPosted: May 11th, 2023, 16:24
So then you need to recover them again and correctly this time.
