 Post subject: Hdd raw copy tool is possible open .imgc ?
PostPosted: May 16th, 2023, 4:33
hi i have a meccanical hdd is demage i recover data in .imgc but the hdd not have S.O. because is secondary hdd contain only data , when i try to re-flash over a new hdd arrive till the end but if i attach under my pc not saw partion , is possible open a file .imgc and look inside of recover the data? thanks
 Post subject: Re: Hdd raw copy tool is possible open .imgc ?
PostPosted: May 16th, 2023, 15:35
Any data recovery software should open the *.imgc file if the file is a RAW copy of the drive.
What software did you use to make this *.imgc file?
R-studio, UFS explorer and DMDE will open any raw copy whatever the extention is (such as img, bin and so on).
Slim Farza
Arobas Uldry Tunis
I.T. support and data recovery.
http://tunis.ausarl.ch
PostPosted: May 16th, 2023, 15:51
Isn't .imgc a compressed image?
PostPosted: May 16th, 2023, 16:31
if he used hdd raw copy tool http://hddguru.com/software/HDD-Raw-Copy-Tool/ then it's a raw. But it will depend on confirmation of faustf.
Slim Farza
Arobas Uldry Tunis
PostPosted: May 16th, 2023, 16:36
Examples of possible uses
Software QA engineers: restore your OS hard drives at any moment from a compressed image
PostPosted: May 17th, 2023, 2:44
yes i used Hdd Raw copy Tool thanks at all for answer :)
Users browsing this forum: No registered users and 146 guests
