 Post subject: Best Chip Off solution for SSDs
PostPosted: May 18th, 2023, 10:23
Hello guys, good day. I'm looking for informations about chip off tools solution for flash drives, mostly SSD's, that are not supported by PC3k.
Witch one would you guys recomend between Rusolut VNR, PC3k Flash or Flash Extractor.
Sorry for this dumb question, but this is the next step i'll do and I want some insights from people I really respect.
Thank you for any answer.
Edit: Sorry, now I've seen that I sent this on "convencional hard drives" topic. My bad.
 Post subject: Re: Best Chip Off solution for SSDs
PostPosted: May 18th, 2023, 11:03
AFAIK usually impossible due to encryption etc..
PostPosted: May 18th, 2023, 11:13
Arch Stanton, I see lots of publications from arvika, and other exceptional guys here, about lots of cases that this is not an issue.
It's only difficult to reconstruct NAND translator.
PostPosted: May 18th, 2023, 12:14
For example chip-off from Sandisk 20-82-00469-2 is possible via Flash-extractor and VNR. VNR will take longer but it has also file carver and another tool to get better results but recovery is possible only via block number so no big files will work.
Most of SSDs are not possible to recover via chip-off.
odzyskiwanie danych
PostPosted: May 18th, 2023, 13:28
melvin, Thank you for your clarification. I really didn't know that chip-off solutions are useless for big files.
This Sandisk example you used is exactly the one I'm intended to buy a chip-off solution. I've denied dozens of this here because I don't have a solution.
PostPosted: May 18th, 2023, 14:46
I have two videos abouth them on YT but in polish. Big, fragmented files, like databases are not possible to recover for now. Till we get a way to create a translator.
odzyskiwanie danych
PostPosted: May 18th, 2023, 17:40
It's why I said usually.
PostPosted: June 3rd, 2023, 7:45
parmindo :mrgreen: ,
This guy is a smart fellow too :lol:
Users browsing this forum: No registered users and 94 guests
