Post new topic Reply to topic  [ 31 posts ]  Go to page Previous  1, 2
 Post subject: Re: Toshiba MQ04UBD200 compatible heads ?
PostPosted: October 3rd, 2022, 18:14
Those heads are compatible, these drives are relatively easy to work with.
PostPosted: June 7th, 2023, 16:50
Is there a solution to this currently?
I am not asking for a solution, I am asking if someone already has a method so that changing heads does not kill the data On Toshiba SMR drives.
Pc3000/MRT have planned something on this topic?. I have seen something about the next update of pc300 (7.3) But I don't know mention anything about Toshiba ......
PostPosted: June 8th, 2023, 3:26
Yes, there is solution.
PostPosted: June 8th, 2023, 4:13
Thanks Dimitri, it's good to know that there is already a solution.
PostPosted: June 8th, 2023, 4:20
I guess it will be SA write lock, same as Seagate/WD, but Toshiba ROM is totally unknown to me currently..... :(
PostPosted: June 8th, 2023, 4:33
I will wait to see if the new update of pc3000 advances something in this matter, if so I will not waste time, but if nothing advances in Toshiba SMR, we will have to invest time in this matter. At least here these units enter a lot and in a significant percentage it would be necessary to change heads.
PostPosted: June 8th, 2023, 6:18
PM sent
PostPosted: June 8th, 2023, 11:05
Thank you Dimitri
PostPosted: June 8th, 2023, 16:17
There is any news about this topic solution???! Update us
PostPosted: June 8th, 2023, 16:18
northwind wrote:
PM sent
Hi, there is update here about toshiba smr drives?
PostPosted: July 3rd, 2023, 15:33
The new pc3000 uodate solve this toshiba smr problem?
Users browsing this forum: Google [Bot] and 80 guests
