 Post subject: T32000542AS FW:CC34 0mb
PostPosted: June 16th, 2023, 12:37
Hello guys,
I have an old drive here, model ST32000542AS FW:CC34 he detect with 0mb... I try to fix the 93 module in both heads (this usually solves this problem) but with no success.
Any command to fix the translator or reset the SMART return "Terminal : reply timeout error" and doesn't work.
The SN it's correct and the drive start with no more problems like noise of the heads...
Has anyone seen something like this before?
 Post subject: Re: T32000542AS FW:CC34 0mb
PostPosted: June 16th, 2023, 13:50
Are you using the correct UART voltage?
PostPosted: June 16th, 2023, 14:21
Yes, i can read all modules normally and write with no problems... :|
PostPosted: June 17th, 2023, 9:37
are you able to execute any command on terminal manually?
PostPosted: June 19th, 2023, 12:08
Yes, i can execute commands in the terminal manually
Users browsing this forum: No registered users and 97 guests
