Forum rules
 Post subject: Looking for HP Branded SAS HDD ST300MM0006 HPS1 Firmware
PostPosted: June 23rd, 2023, 2:41
im looking for hp branded seagate hdd firmware for model number ST300MM0006 Firmware HPS1
 Post subject: Re: Looking for HP Branded SAS HDD ST300MM0006 HPS1 Firmware
PostPosted: June 23rd, 2023, 4:02
Well,
what is the issue and what are you trying to achieve by this please
PostPosted: June 23rd, 2023, 4:04
I’m looking to make normal Seagate hdd to this specific model since my workstation software is not accepting other firmware
PostPosted: June 23rd, 2023, 4:05
I have many identical Seagate st300mm0006 with 004 firmware installed with sector size 512
PostPosted: June 23rd, 2023, 16:04
Can you dump the vendor specific VPD pages?
You can do this using sg_vpd:
https://linux.die.net/man/8/sg_vpd
This command dumps page 0, which is a list of supported VPD pages.
sudo sg_vpd --page=0 /dev/ice
The above tool is a component of the sg3_utils package:
https://sg.danny.cz/sg/sg3_utils.html
The vendor specific pages are in the range 0xC0 - 0xFF.
You can dump these pages as follows:
sudo sg_vpd --raw --page=nn /dev/ice > VPD_nn.bin
"nn" is the page number. "If a number is given it is assumed to be decimal unless it has a hexadecimal indicator which is either a leading '0x' or a trailing 'h'."
PostPosted: June 24th, 2023, 2:55
ST300MM0006 = Seagate Savvio 10K.6 300GB, SAS 6Gb/s
Have you already tried to force flashing this?: https://files.hddguru.com/download/Firm ... g-0004.zip
Older Seagates are sometimes not locked or prevent flashing generic fw.
