 Post subject: Kingston 480GB SSD only showing as 20MB
PostPosted: July 7th, 2023, 15:02
Hi all, what would the most likely cause of this be?
"Hi, I have a Kingston 480GB SSD.. was working fine, the pc crashed while trying to install a software thought would restart once restarted it came up with blue screen. I held the power button to switch pc off since then its not came back on... it come as 20mb in device manager.. can this be fixed?"
 Post subject: Re: Kingston 480GB SSD only showing as 20MB
PostPosted: July 7th, 2023, 15:12
Fixed - no. Data recovery - maybe.
odzyskiwanie danych
PostPosted: July 7th, 2023, 15:18
Thanks for the reply. So this will be a NAND issue?
PostPosted: July 7th, 2023, 15:21
Yes and no. Most likely firmware which is stored on the NAND.
PostPosted: July 7th, 2023, 16:02
A400? PS3111 should be supported by PC3K SSD if your client wants the data back.
