 Post subject: SoC Coolsand RDA SC6533G adapter for embeded NOR available
PostPosted: July 7th, 2023, 10:09
After Speadstrum and MediaTek we did it again !!!
SC NOR Adapter for Coolsand RDA SC6533G SoC is a programmer in the form of a USB key that allows access to data contained in the internal NOR memory embedded in Coolsand RDA SC 6533G. These processors (SoC) are most often found in budget phones, the so-called Features phones like as well as many smartwatches. Due to the lack of an SPI or I2C access protocol, the only possibility of accessing the data after a device failure (e.g. breaking the motherboard to prevent access) was to perform a chip SWAP to a functional device. Our adapter revolutionizes data recovery from such cases - just after ChipOFF, place the processor in the adapter and connect the adapter to the USB to enable data reading.
Features:
- physical reading of NOR memory directly from [i]ALL processors based on Coolsand RDA SC 6533G [/i](e.g. damaged devices) regardless of the manufacturer
- communication in DLOAD mode by just pressing button
- reading deleted Messages, Lists of calls made, Contacts using appropriate investigative software
NOTE: To perform the reading, appropriate software is required that allows communication with the SPD loader like Infinity BOX, Miracle BOX or MSAB XRY
More info: https://multi-com.eu/,details,id_pr,22920,key,nor-adapter-for-coolsand-rda-sc6533g.html
Best regards,
Boguslaw Rzepka,
Multi-COM Ltd., Poland
 Post subject: Re: SoC Coolsand RDA SC6533G adapter for embeded NOR availa
PostPosted: July 7th, 2023, 16:24
Does your adaptor cost less than a replacement phone?
PostPosted: July 8th, 2023, 4:21
Haahaa ,
Frank you nailed it :mrgreen:
PostPosted: July 8th, 2023, 9:31
Nailed….. really :) ? I think you miss point of adapter. Those are mainly used in Forensic and proffesional DR Labs to minimalise risk of evidence loose where cost Factory is less important than final positive effect. While you always can make ChipOff (Cold for safe purpose or Hot) then SWAP is not always an option. Why ?
A) ChipON when making SWAP so applying additional heat to chip can make chip failure (die vias connection Lost) if for example device was putted in water for many days/weeks
B) While most Forensic investigator can perform ChipOff then making SWAP can bring them problems
C) there are always can be a problem in finding exactly same device to make SWAP - those feature phones are mainly used in diffrent Type of crimes when after use device are broken at half
D) its fast :) After making Cold or hot ChipOff you can get evidence in minutes instead of days (donor purchase, preparing donor, swap)
If none of those apply for you, then you don’t need adapter for your Business :)
Best regards,
Boguslaw Rzepka,
PostPosted: July 8th, 2023, 15:55
@Bolo, I think your tools are great, but I would think that the economics doesn't make sense for most operators. Of course, if you specialise in your area, then you would be able to recover your investment in a short time, and your tools would be a godsend.
Users browsing this forum: No registered users and 93 guests
