 Post subject: failed to load overlay 00000005 error in terminal
PostPosted: July 16th, 2023, 7:16
I have one hard disk which details is below.
Model : Unknown Barracuda 7200.12
Family : YETIST_3_*/4_0(64A1)(3-12-4-1)
Admin : PH0G2D.CCD6.JQ019Y.
Firmware : CC6B
Speed : 7201 RPM
Head : 2
Capacity : 976773168 (500G)
S/N : W2A2DWFR
In Terminal following error occured
RW: Disc Ctlr Initialization Completed.
ExecuteSpinRequest
(DOS) Table Read FAIL
DOS: MAGIC CONFIG NUMBER MISMATCH
(DOS) Table Read FAILvqvqvqvqvqvqvqvqvqvqvqvqvqvqvqvqvqvqvqvq
SIM Error 1002vqvqvqvqvqvqvqvqvqvqvqvqvqvqvqvqvqvqvqvq
SIM Error 1002
No HOST FIS-ReadyStatusFlags 2002A185
ASCII Diag mode
F3 T>
ASCII Diag mode
F3 T>m0,2,2,,,,,22
DiagError 0000500E Process Defect List Error
R/W Sense 00000002, R/W Error 841C0087, List Offset 00000000, List Index 002540AB, File Error 000000D0
F3 T>
hard disk haven't any clicking noise. when read sys files error is
Any help appreciate.
sorry for my bad English.
P.S. : I haven't expensive tools like PC3000, MRT Etc...
 Post subject: Re: failed to load overlay 00000005 error in terminal
PostPosted: July 16th, 2023, 12:53
0x841C0087 - Unable to recover the Primary Defect files.
Look at the answer to the Ctrl-X immediately after the first F3 T> after the restart.
Check for reading both copies of the SYS-File 0x001B, 0x0028 (if it gives without 5 overlay).
F3 T>r1B,3,0
If it reads, he will offer to accept file the Y-modem.
F3 T>r1B,3,1
F3 T>r28,3,0
F3 T>r28,3,1
If critical files were not reserved earlier - in a green bucket ...
I forgot to warn - you have a record in the service area spoils the files.
Therefore, performing commands from the Internet in the terminal is a bad idea.
Users browsing this forum: Google [Bot], Rendersmith and 56 guests
